#11
On Sun, 7 Jan 2007 10:52:24 -0800, Danny Deger wrote
(in article ): "Tony" wrote in message oups.com... I haven't found a decent reference for this -- can anyone help? Consider a clean low speed airplane -- maybe one of the kit built ones. Does anyone have some quantitative measure of how much drag is reduced if the airplane is flown say half or quarter of a wingspan above the ocean? If I recall correctly it is about 20%. It is enough that the Russians built an seaplane with small wings that cruised in ground effect to reduce drag. It is not just a couple of percent for sure. Your technothriller will be valid to assume a substantial reduction in drag by flying in ground effect. I remember there was some discussion a couple years back of building a giant ground effect container ship/plane. It would cross the Pacific in ground effect, then fly the short distance to a coastal airport. Probably not economically feasible, but it could be done. For one thing, why fly it to an airport? All the cranes to unload it are at ports. Seems to me that skipping the flying step would greatly simplify things. |
![]() C J Campbell wrote: On Sun, 7 Jan 2007 10:52:24 -0800, Danny Deger wrote (in article ): "Tony" wrote in message oups.com... I haven't found a decent reference for this -- can anyone help? Consider a clean low speed airplane -- maybe one of the kit built ones. Does anyone have some quantitative measure of how much drag is reduced if the airplane is flown say half or quarter of a wingspan above the ocean? If I recall correctly it is about 20%. It is enough that the Russians built an seaplane with small wings that cruised in ground effect to reduce drag. It is not just a couple of percent for sure. Your technothriller will be valid to assume a substantial reduction in drag by flying in ground effect. I remember there was some discussion a couple years back of building a giant ground effect container ship/plane. It would cross the Pacific in ground effect, then fly the short distance to a coastal airport. Probably not economically feasible, but it could be done. For one thing, why fly it to an airport? All the cranes to unload it are at ports. Seems to me that skipping the flying step would greatly simplify things. Two problems that killed the Russian's ideas (besides money): (1) The huge waves encounted at sea means the thing has to rise out of ground effect, and (2) the span and power needed to fly to the airport ruin the economics of the thing. Dan |
![]() Ron Hardin wrote: The efficiency of ground effect comes from replacing having to throw air downwards, which costs energy (less energy the more air you throw at a lesser speed, ie. long wings), with just hovering over a high pressure area that you only have to set up once, instead of continuously creating it. You get the reduced induced drag of a longer-winged craft without the parasitic drag of longer wings (the point of long wings being to reduce the downward speed of thrown air). The proximity of the ground does two things: It interferes with wingtip vortex formation, the source of a major part of induced drag and which destroys lift over the outer part of the wing at low speeds, and it decreases angle of attack by reducing the upflow ahead of the wing and reducing the downwash. Longer wings lose less area to vortices, making them more efficient at low speeds. The pressure under the wing is not significantly higher in ground effect. Dan |
Ron Hardin wrote:
wrote: The pressure under the wing is not significantly higher in ground effect. It's exactly the same. It holds up the airplane. Little work has been expended to do it, though. It doesn't have to be the same. It is the difference in pressure that provides the force to hold up the airplane, not just the pressure under the wing. Matt |
The Impossibility of Flying Heavy Aircraft Without Training | Immanuel Goldstein | Piloting | 365 | March 16th 06 01:15 AM |
Aeronautical Engineer says Official 9/11 Story Not Possible | Jim Macklin | Piloting | 12 | February 22nd 06 10:09 PM |
Aeronautical Engineer says Official 9/11 Story Not Possible | Bob Gardner | Piloting | 18 | February 22nd 06 08:25 PM |
The Meredith Effect | Corky Scott | Home Built | 19 | September 4th 04 04:01 PM |
Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 05:11 AM |
