#11
![]() "Grumman-581" wrote in message news ![]() : 28, Bob Moore wrote: : I think that you are going to have to work with TAS instead of GS, but : Figure 2.29 on page 179 of Aerodynamics for Naval Aviators has a graph : of all the factors involved. : : Yeah, to be perfectly accurate, I would need air speed and not ground : speed in addition to wind angle corrections, but I was curious if I could : get a good approximation of the bank angle from just what I'm getting from : the GPS without having to add a considerably costlier device like an : accelerometer / gyro with rs232 outputs... The Garmin 18 5Hz puck type GPS : goes for around $150... A bit more than the 1Hz units that are typical for : car navigation, but not entirely out of line for this project... The : accelerometer / gyro systems that I've seen so far with rs232 outputs go : for around $1K-$2K... I understand that there is some new work in : accelerometers for PC-based pointing devices that have brought the prices : down considerably compared to the previous devices like this: : : http://www.watson-gyro.com/products/...A_80_spec.html : Don't know why wind angle would be important. Have to assume a coordinated turn also - a rudder turn would yaw like crazy but not necessarily result in a bank angle.... |
On Thu, 11 Jan 2007 00:05:44 +1100, in ,
d&tm wrote: Its close but is it close enough at greater angles.? what are you using for the conversion of speed.? I used g =9.8 Pi as 3.14159 and v = kts *1852/3600 m/s For conversion of speed, I'm using 6076 ft per nm, 3.14159265358979 for pi, 9.80665 m/s^2 or 32.17398421 ft/sec^2 for g... Interestingly on g, I'ver seen sources that quite it as being defined as 9.80665 *exactly* and others that quote it at 32.1740486... Not sure about the later figure though since it is not exactly correct at least from a conversion standpoint of the 9.80665 figure using the value of 39.37 inches per meter that I remembered... A quick lookup on the net and I find that my memory was not correct and the 39.37 was not an *exact* figure... Plugging in 39.37007874015748 instead and the values agree... For some reason, I had thought that the 39.37 had been defined as an *exact* value... Of course this also means that my memory is faulty on the 2.54 cm/in value also... With regards to higher velocities and decreased values of time for the 360 degree circle, even with a 1 second 360 degree circle and 500 kts, the values match to more digits than I really need (i.e. 88.26219913 and 88.26219912 degrees respectively for SI and US measurement units)... Yeah, I would like to have an exact match, but there's probably some conversion factor that I'm not using enough significant digits with... |
![]() "Grumman-581" wrote in message news ![]() On Thu, 11 Jan 2007 00:05:44 +1100, in , d&tm wrote: snip Plugging in 39.37007874015748 instead and the values agree... For some reason, I had thought that the 39.37 had been defined as an *exact* value... Of course this also means that my memory is faulty on the 2.54 cm/in value also... My understanding is an inch is EXACTLY 2.54 cm. Danny Deger |
Grumman-581 wrote:
For conversion of speed, I'm using 6076 ft per nm, 3.14159265358979 for pi, 9.80665 m/s^2 or 32.17398421 ft/sec^2 for g... Whoever is selling you your floats, doubles, and long doubles must be making a killing. Interestingly on g, I'ver seen sources that quite it as being defined as 9.80665 *exactly* and others that quote it at 32.1740486... http://en.wikipedia.org/wiki/Gravity_%28Earth%29 has the definition of 9.80665 m/(s^2). It does vary with where you are on the planet as well as how far you are above it. http://en.wikipedia.org/wiki/Acceler...due_to_gravity has a few more details. For some reason, I had thought that the 39.37 had been defined as an *exact* value... http://en.wikipedia.org/wiki/Inch#International_inch says that the yard is defined as 0.9144 m. 0.9144 is exactly 36 * 2.54, so the correct statement may be that an inch is exactly 2.54 cm. 36/0.9144 is 39.370079 according to the calculator; rounding off to 39.37 is a whopping 0.0002% error. Standard disclaimers about using Wikipedia as a reference apply. With regards to higher velocities and decreased values of time for the 360 degree circle, even with a 1 second 360 degree circle and 500 kts, the values match to more digits than I really need (i.e. 88.26219913 and 88.26219912 degrees respectively for SI and US measurement units)... Your protractor salesman must also be living quite well. ![]() Matt Roberds |
On Thu, 11 Jan 2007 14:33:45 -0600, in
, Danny Deger wrote: My understanding is an inch is EXACTLY 2.54 cm. Yeah, well I thought that a meter was defined as EXACTLY 39.37 inches also, so I was leaving myself an out, just in case yet another previoiusly held belief turned out to be wrong... According to http://www.pmel.org/Handbook/HBConversion.htm, it appears that 2.54 is an exact figure... Damn, that's a surprise... |
On Thu, 11 Jan 2007 22:43:13 +0000, in ,
mroberds wrote: Whoever is selling you your floats, doubles, and long doubles must be making a killing. I get a discount on them at TWORD-Depot... grin Better to have the accuracy and choose to not use it than to need it and not have it... If performance becomes an issue, you can always decrease the bytes allocated for your variables... |
On Tue, 09 Jan 2007 02:58:02 -0600, Grumman-581
wrote: Anyone know of a formula for determing the current bank angle, given the current velocity and rate of change in heading over a particular period of time? I was thinking of adding an artificial horizon to program that I'm working on and figured that by taking the current velocity as reported by the GPS and the change in heading as reported by the last two course-over-ground measurements from the GPS, I should be able to determine a close approximation of the actual bank angle... Of course, this assumes that the current winds are ignored in addition to assuming a coordinated turn... The current system that I am using only gets updates at 1 Hz which might be a bit low, but I'm thinking of getting the Garmin 18 5 Hz unit which should be sufficiently fast in its update rate... Sounds like a great project... Provide a great deal of valuable "darn-near-real-time" info to a pilot...and at a cost that wont break the bank. Makes sense...therefore... (do I even NEED to finish the comment?) MORE POWER TO YA! Let us know how it works out. --Don Byrer Don Byrer KJ5KB Radar Tech & Smilin' Commercial Pilot Guy Glider & CFI wannabe kj5kb-at-hotmail.com "I have slipped the surly bonds of earth; now if I can just land without bending the gear..." "Watch out for those doves...smack-smack-smack-smack..." |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
