Robert M. Gary wrote:
Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert I'm guessing that's why there's wing struts ![]() wings to the fuselage? -- Mike |
![]() Mike wrote: Robert M. Gary wrote: I'm guessing that's why there's wing struts ![]() wings to the fuselage? On the Cessna I don't remember how many "wing nuts" there were holding the wing on, I just remember the very small area in which the wing attaches to the body. There must be insane amounts of stress on that small area of metal. On the Mooney, there is but one single wing. The spar runs right under the seats. No one has problems with wings coming off but the Mooney design makes me more comfortable. -Robert |
On the Cessna I don't remember how many "wing nuts" there were holding the wing on, I just remember the very small area in which the wing attaches to the body. There must be insane amounts of stress on that small area of metal. Most of the lift is transferred via the struts, not at the wing root (now I'll be darned if I can remeber where I read that...). The wing basically pulls on the strut, and the wing root only has to keep it from tipping one way or another. Anno. |
![]() Robert M. Gary wrote: Mike wrote: Robert M. Gary wrote: I'm guessing that's why there's wing struts ![]() wings to the fuselage? On the Cessna I don't remember how many "wing nuts" there were holding the wing on, I just remember the very small area in which the wing attaches to the body. There must be insane amounts of stress on that small area of metal. On the Mooney, there is but one single wing. The spar runs right under the seats. No one has problems with wings coming off but the Mooney design makes me more comfortable. -Robert The 172 has a 7/16" bolt on the front spar attach, and a 3/8" at the rear, IIRC without going downstairs and looking it up. Both are in double shear. The bolt is stronger than the aluminum fittings, and the fittings are much stronger than they look or need to be. The airplane is rated for 3.8g positive, with 150% design limits beyond that, and I can't remember the last time I heard of a 172 shedding a wing unless the pilot tried to fly through a thunderstorm, in which case he'd have died anyway. The stabilizer is weaker than the wing in many light aircraft. The struts are connected with 1/2" bolts in double shear. The Mooney's one-piece wing spar is made of many smaller pieces, all held together with tiny rivets. No stronger than the 172, I bet. The Mooney's POH should give a g rating for the airframe. Which reminds me: a friend recently told me of an accident in the Southeastern US where a new Commercial pilot flew a Monney into a thunderboomer at night. They found the wreckage scattered far and wide, and the Mooney engineers that examined the bits and pieces estimated that the aircraft experienced an upward acceleration of between 20 and 23 Gs. The passenger, complete with seat, went through the bottom of the airplane and was found some distance behind the rest of the mess. Even if the airplane had held together the occupants would have been incapacitated or killed by the damage wrought by the acceleration. Dan |
![]() wrote: Robert M. Gary wrote: Mike wrote: Robert M. Gary wrote: The 172 has a 7/16" bolt on the front spar attach, and a 3/8" at the rear, IIRC without going downstairs and looking it up. Both are in double shear. The bolt is stronger than the aluminum fittings, and the fittings are much stronger than they look or need to be. The airplane is rated for 3.8g positive, with 150% design limits beyond that, and I can't remember the last time I heard of a 172 shedding a wing unless the pilot tried to fly through a thunderstorm, in which case he'd have died anyway. The stabilizer is weaker than the wing in many light aircraft. Agreed. I understand 172's are not falling from the sky, just an emotional reaction to seeing what is actually holding the wings on. I wonder what holds the wings on the C-177 if the struts old the wings on the c-172. The Mooney's one-piece wing spar is made of many smaller pieces, all held together with tiny rivets. No stronger than the 172, I bet. The Mooney's POH should give a g rating for the airframe. The 3.8g limit you mention for the c-172 is just a function of the certification category. Since the Mooney and the 172 share the same category they are both 3.8g's with 150% minimum overdesign by definition. Note sure what the actual structural limits are though. The manufactors don't tell us the actual limits, just the certification limits. The Mooney is known for being amazingly strong though. Rememeber the picture of the 201 coming off the line with several dozen people standing on the wing? They flew that plane afterwards w/o problem. I have a friend who survived a nasty accident in his 201 and credits the steel tube cabin for saving his life. Which reminds me: a friend recently told me of an accident in the Southeastern US where a new Commercial pilot flew a Monney into a thunderboomer at night. They found the wreckage scattered far and wide, and the Mooney engineers that examined the bits and pieces estimated that the aircraft experienced an upward acceleration of between 20 and 23 Gs. The passenger, complete with seat, went through the bottom of the airplane and was found some distance behind the rest of the mess. Even if the airplane had held together the occupants would have been incapacitated or killed by the damage wrought by the acceleration. Do you have a reference for this? A possible date range, the state if happened in or something I can search on? I'd like to pull up the NTSB on it. -Robert |
![]() "Robert M. Gary" wrote in message oups.com... Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert Try standing at the back of an empty 757, on a positioning leg. I could swear that you can see the fuselage gently flex as it flies- a bit like a fish going through water. Now that does scare the sh1t out of you. |
Chris wrote:
"Robert M. Gary" wrote in message oups.com... Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert Try standing at the back of an empty 757, on a positioning leg. I could swear that you can see the fuselage gently flex as it flies- a bit like a fish going through water. Now that does scare the sh1t out of you. I certainly believe that. I was on a flight out west a while ago, and I guess the pilot realized he was going to overshoot the centerline on the turn to final, so he/she banked more suddenly than usual. Definitely heard the flex, that's for sure ![]() -- Mike |
Ummm.. re" things that move..float or fly..."
Those that don't bend or flex, - break.. ![]() Dave On Wed, 10 Jan 2007 16:41:32 -0500, Mike wrote: Chris wrote: "Robert M. Gary" wrote in message oups.com... Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert Try standing at the back of an empty 757, on a positioning leg. I could swear that you can see the fuselage gently flex as it flies- a bit like a fish going through water. Now that does scare the sh1t out of you. I certainly believe that. I was on a flight out west a while ago, and I guess the pilot realized he was going to overshoot the centerline on the turn to final, so he/she banked more suddenly than usual. Definitely heard the flex, that's for sure ![]() |
The more you know the more you can do.
Nothing like assembling a sailplane, loading it full of water and bombing down a ridge at red-line for a few hours. Then you just pull the wings and tail back off and trailer it home. Robert M. Gary wrote: Mike wrote: Hi, I'm interested in learning more about airplane construction, say maybe a Cessna 172. I know the basics of airframes and power plants, but what I'm having a hard time finding is actual diagrams and depictions of the actual assembly. For example, wing root connections, engine mounts, supporting structures, etc. I imagine this might be available in a mechanics manual, but I don't know where else to look. I've scoured the Internet with no success. When I saw how the wings are attached on a Cessna it almost made me not want to fly one. Not much holding them on. Rational or not, I feel better in turb in my Mooney knowing the entire cabin is sitting on the one piece wing. -Robert |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
