![]() Montblack wrote: How much does the 15 minutes of air weigh - that you run through an (average) rotax engine? At 4 gallons per hour, the fuel rate is 6*4=24 pounds per hour. (aprox 60% power) The air / fuel ratio of gasoline engines is about 14 / 1, so the airflow rate would be 336 pounds of air per hour. At standard conditions, air weighs about 0.075 pounds per cubic foot, so the air flow rate expressed in cubic feet per minute would be 336/0.075/60=75 cfm. tom |
In recent years a few electric self-launch gliders have appeared in the
marketplace. http://www.lange-flugzeugbau.com/htm...tares_20E.html http://www.apisgliders.com/ApisE.html http://www.alisport.com/eu/eng/silent_b.htm However, none of them have the ability to recharge their batteries in flight. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder wrote in message ups.com... Montblack wrote: How much does the 15 minutes of air weigh - that you run through an (average) rotax engine? At 4 gallons per hour, the fuel rate is 6*4=24 pounds per hour. (aprox 60% power) The air / fuel ratio of gasoline engines is about 14 / 1, so the airflow rate would be 336 pounds of air per hour. At standard conditions, air weighs about 0.075 pounds per cubic foot, so the air flow rate expressed in cubic feet per minute would be 336/0.075/60=75 cfm. tom |
ups.com... Montblack wrote: How much does the 15 minutes of air weigh - that you run through an (average) rotax engine? At 4 gallons per hour, the fuel rate is 6*4=24 pounds per hour. (aprox 60% power) The air / fuel ratio of gasoline engines is about 14 / 1, so the airflow rate would be 336 pounds of air per hour. At standard conditions, air weighs about 0.075 pounds per cubic foot, so the air flow rate expressed in cubic feet per minute would be 336/0.075/60=75 cfm. tom But of course, nearly 80 percent of that air is N2 and stuff that isn't required for the exothermic reaction with the fuel. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Capt. Geoffrey Thorpe wrote:
wrote in message ups.com... Montblack wrote: How much does the 15 minutes of air weigh - that you run through an (average) rotax engine? At 4 gallons per hour, the fuel rate is 6*4=24 pounds per hour. (aprox 60% power) The air / fuel ratio of gasoline engines is about 14 / 1, so the airflow rate would be 336 pounds of air per hour. At standard conditions, air weighs about 0.075 pounds per cubic foot, so the air flow rate expressed in cubic feet per minute would be 336/0.075/60=75 cfm. tom But of course, nearly 80 percent of that air is N2 and stuff that isn't required for the exothermic reaction with the fuel. Not required for the exothermic reaction, but is required to push the pistons. The burning gas heats the excess N2, which expands to push the piston with much lower heat than the welding torch flame that would result otherwise. If you didn't have all that extra non-reactive mass, you'd need some way to provide it, lest you melt your piston in very short order. |
Electric motor for hang glider | Legend Length | Home Built | 11 | August 27th 09 02:14 AM |
Engine noise recording in Motor Gliders | Ian Strachan | Soaring | 2 | October 16th 06 12:32 PM |
Boeing's Electric Taxi Motor | Larry Dighera | Piloting | 43 | December 7th 05 05:41 AM |
Is a Turn Coordinator an electric motor or powered by fan? | kickinwing | Piloting | 5 | June 11th 05 12:25 PM |
More on the electric verses turbojet | cdubya | Soaring | 8 | September 25th 03 09:16 AM |
