#11
On 13-Jan-2007, Bob Noel wrote: The FAA doesn't have any say wrt airworthiness certifiation of US military aircraft (any FAA certification of military aircraft is at the option of the service). I'll add to this, when I was a comm-nav avionics specialist in the USAF (1980-1991), we didn't have any kind of requirement to recertify the aircraft transponders every two years. We fixed 'em when the crews said they were broken but never worked on them otherwise. Scott Wilson |
A point that needs to be made is that the FAA and DoD ATC systems are
not completely independent and parallel systems; they're thoroughly intertwined. For instance, Ellsworth Approach/Departure handles civilian traffic into and out of Rapid City Regional; Wichita Approach/Departure handles McConnell AFB traffic; military controllers at Sheppard AFB handle traffic for the civilian side of the field (Wichita Falls Muni) in the air and on the ground. Military sorties are under FAA control except under two circumstances: 1. When being handled by a military ATC facility. The handoffs to/from FAA controllers are done in accordance with procedures established in part at the national level and in part by local FAA/DoD working groups. Handling of civilian traffic by military controllers is worked out the same way. 2. When operating in a Military Operations Area (MOA) or a low-level training route. The sortie is directed to the MOA or the entry point of the route by the FAA, then it's on its own (unless there's a military ATC facility controlling the MOA, e.g. Nellis Range Control) under a policy known as MARSA (Military Assumes Responsibility for Separation of Aircraft). The FAA tries to keep civilian traffic out of the way, but is not responsible for mishaps unless the FAA controllers were negligent. When the sortie has flown the route or is ready to leave the MOA it contacts Center, declares itself "no longer MARSA" and is again under FAA control. Emergencies are handled the same way as in civilian aviation, although a military crew may have to justify their irregular actions to two sets of authorities afterward. DoD flight safety regulations are heavily based on FAA requirements and even preferences; the military comes down hard on unnecessary violations of FARs. However, I don't know of a case in which a military pilot who also held an FAA license was punished by both the DoD and FAA for an action in a military aircraft. |
In article . com,
"quietguy" wrote: A point that needs to be made is that the FAA and DoD ATC systems are not completely independent and parallel systems; they're thoroughly intertwined. in fact, the new STARS is a joint DOD/FAA program with the FAA as lead and the DOD follower, and the companion ASR-11 (aka DASR) has the DOD as lead with the FAA follower. In other words, in the NAS, the FAA and DOD will be using the same systems for TRACONs and terminal radars (for the most part). -- Bob Noel Looking for a sig the lawyers will hate |
On Sun, 14 Jan 2007 02:01:33 -0000, Jim Logajan wrote:
The answer is not simple Almost an understatement. Somehow as I read your post I kept thinking of Spaghetti. Thanks Jim, and all. -- Dallas |
Dallas wrote:
This came up in another group and no one had an answer. What is the relationship of the FAA to the military? Is the FAA the final word on regulations for everything in the US airspace with the military using an additional set of their own regulations? The FAA is responsible for Civil Aviation. The military and the government (called public) aviation is not subservient to them. They cooperate only as it suits their interest. |
| Thread Tools | |
| Display Modes | |
