#11
WestCDA wrote
I don't see that anyone has mentioned the demonstrated crosswind component, which is in the P.O.H. for certified aircraft. You may do better, but that's the best number the manufacturer achieved with a new aircraft and a very good pilot. I would suggest that it might be the highest number that the lawyers would permit to be included in the flight manual. Bob Moore |
crosswind component, which is in the P.O.H. for certified aircraft. You may do better, but that's the best number the manufacturer achieved with a new aircraft and a very good pilot. I would suggest that it might be the highest number that the lawyers would permit to be included in the flight manual. I have never looked it up, but my first instructor asserted that it was the amount of crosswind in which it was demonstrated that the (tricycle gear) aircraft would safely complete a landing without any crosswind correction being applied. Again, I have not verified the assertion; but it is certainly not the worst case condition under which the aircraft can be landed safely by a highly proficient pilot... Peter |
"Peter Dohm" wrote in message
... I don't see that anyone has mentioned the demonstrated crosswind component, which is in the P.O.H. for certified aircraft. You may do better, but that's the best number the manufacturer achieved with a new aircraft and a very good pilot. I would suggest that it might be the highest number that the lawyers would permit to be included in the flight manual. I have never looked it up, but my first instructor asserted that it was the amount of crosswind in which it was demonstrated that the (tricycle gear) aircraft would safely complete a landing without any crosswind correction being applied. Again, I have not verified the assertion; but it is certainly not the worst case condition under which the aircraft can be landed safely by a highly proficient pilot... Peter Just the highest crosswind experienced and 'safely handled' during the certification process, it appears. Here's a link to an article on the subject, and it seems to agree with other references I found regarding the DCC. http://www.swaviator.com/html/issueMA05/Basics3405.html "The 15-knot Demonstrated Crosswind Component is not a limitation, per se; it's just a simple statement that sometime during certification the airplane was landed successfully, without using any unusual skills, in a 15-knot crosswind. But, remember the pilot who demonstrated the crosswind landing was a very experienced test pilot. Are you as competent as he or she was?" |
Even a steady 25 knot wind directly down the runway _can_ catch the
unwary off guard (windshear). I'll never forget that lesson... OAK was calling a 15 knot wind, no gusts, coming right down the nines... I had my instructor with me at the time. I noticed during the crosswind that my correction seemed rather extreme (over 30 degrees) to stay on course, turned final, and maintained a book 75mph IAS down final. All of a sudden I hit the windshear layer, 35 knot wind above, 15 knot wind below- and suddenly I had no where NEAR the kinetic energy I was expecting, still 100 feet above the ground and well short of the threshold. My instructor saved that one, and Iearned a valuable lesson. One of two times in my flying life I've made the 'Your Plane!' call. On Jan 20, 9:01 am, "Vaughn Simon" wrote: wrote in ooglegroups.com... Clearly this is a personal decision, based on your perceptions of your own skills, the aircraft you are flying, the specific conditions on the day (E.g. how gusty, reports of LLWS & turbulence), your risk tolerance, etc. The title of this thread may be a little misleading to a newbie. Wind down the runway is a GOOD thing that actually makes landings and takeoffs easier and safer. Ground speed is less on landing, ground roll is less on takeoff and the takeoff angle over the runway is far improved. In the pattern, winds can make the downwind portion go so fast that a new pilot might get behind the airplane, but if you are flying a slow plane and doing a crab for a proper base leg track, you have a wonderful view of the runway while on your base leg, and your turn onto final can actually be far less than 90 degrees. Short field landings into a headwind are far easier, and can actually fool you into believing you have skills that you don't. Crosswinds and gusty conditions are a 'nuther whole matter. If you go out to the airport and find those conditions, rather than canceling, it might be a good time to seek an idle CFI and use the opportunity to work on skills and self-confidence. Vaughn CFIG |
On Sat, 20 Jan 2007 22:39:03 GMT, "WestCDA" wrote:
I don't see that anyone has mentioned the demonstrated crosswind component, which is in the P.O.H. for certified aircraft. You may do better, but that's the best number the manufacturer achieved with a new aircraft and a very good pilot. If the calculated crosswind based on the wind speed, direction, and available runway exceeds the DCC for your aircraft, it's cause for at least caution if not an outright scrub of the flight. That statement, for small Part 91 aircraft, is not the case. The demonstrated crosswind component is merely what the wind happened to be on some day when the crosswind was blowing at least strongly enough to meet certification requirements. The 14 CFR 23 requirements are that this value be at least 0.2 Vso. ======================================== § 23.233 Directional stability and control. (a) A 90 degree cross-component of wind velocity, demonstrated to be safe for taxiing, takeoff, and landing must be established and must be not less than 0.2 VSO. ====================================== It is not even close to being a limitation. --ron |
EridanMan wrote:
Even a steady 25 knot wind directly down the runway _can_ catch the unwary off guard (windshear). I'll never forget that lesson... OAK was calling a 15 knot wind, no gusts, coming right down the nines... I had my instructor with me at the time. I noticed during the crosswind that my correction seemed rather extreme (over 30 degrees) to stay on course, turned final, and maintained a book 75mph IAS down final. All of a sudden I hit the windshear layer, 35 knot wind above, 15 knot wind below- and suddenly I had no where NEAR the kinetic energy I was expecting, still 100 feet above the ground and well short of the threshold. My instructor saved that one, and Iearned a valuable lesson. One of two times in my flying life I've made the 'Your Plane!' call. Were you a new student at the time? Matt |
On Sat, 20 Jan 2007 10:31:32 -0500, Jake Brodsky
wrote: Bottom line: A good pilot uses experience to know when to stay on the ground and training to deal with the unexpected. I have experience in turbulence, LLWS, and gusty winds, but I won't launch in to it deliberately. That's one of the nice things about flying for fun. If it doesn't look like fun, don't do it. Jake Brodsky that is it in a nutshell. one should always use the superior management skills to ensure that the superior flying skills are not called for. :-) in you example that I snipped you demonstrated a very good flying skill. you kept thinking and flying right to the end and took advantage of every opportunity that presented itself. that will turn dangerous situations into stories on usnet :-) if the weather is bad, the winds deplorable, or the forecast involved and difficult my sincere advise is to find the window seat of the closest airport bar and study the weather over a beer. it all becomes much more obvious over a beer! (for the humour impaired I will explain. if it is marginal dont go. the last beer you drink will see you avoiding the weather for another 8 hours :-) ) Stealth Pilot |
wrote: "Stealth Pilot" wrote in message .. . you should be able to fly in conditions where the windsock is horizontal from any direction. I can't say I agree with this. I think it's worth pointing out that a windsock is horizontal at 150 kts, just the same as it is at 15 kts. We had conditions here a couple weeks ago (Rocky Mountain foothills)where the windspeed at field elevation was gusting to 80 and 90 miles and hour. do you know how to guess at the wind speed from the windsock angle? its a useful skill. Yes, up to the point the windsock is horizontal, after which you need a better tool. I don't see that anyone has mentioned the demonstrated crosswind component, which is in the P.O.H. for certified aircraft. wrong wrong wrong! if the certification test flight is done in nil wind and there isnt a windy day available for ages then the design may have a low or no demonstrated crosswind component ....for the simple fact that there wasnt a crosswind available. you are reading far too much into this figure. it is really just the crosswind component that a demonstration landing was made in for the purposes of certification. You may do better, but that's the best number the manufacturer achieved with a new aircraft and a very good pilot. wrong wrong wrong! that is not what the figure is about at all. If the calculated crosswind based on the wind speed, direction, and available runway exceeds the DCC for your aircraft, it's cause for at least caution if not an outright scrub of the flight. yes caution in that you will need to work hard for the landing. If you're landing at an airport with an overly strong crosswind, and fuel or other concerns don't allow finding another airport with a more favorable runway, lack of control authority may make landing on and maintaining the runway extremely difficult if not impossible. then dont maintain the runway. land diagonally across it. if the wind is so strong that you can only find a taxiway into wind then land on the taxiway.(advise people of what you are doing of course) locally here Bunbury is often unlandable in my aircraft because of strong rotors off the adjacent row of pine trees but 20 miles away there sits Busselton airstrip which is in the open and better oriented to the predominant winds. .....you've got the idea though. Stealth Pilot |
Your instructor was wrong. Seriously wrong, at that.
mike "Peter Dohm" wrote in message ... I have never looked it up, but my first instructor asserted that it was the amount of crosswind in which it was demonstrated that the (tricycle gear) aircraft would safely complete a landing without any crosswind correction being applied. Peter |
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue | Mike | Naval Aviation | 26 | July 11th 06 11:38 PM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
