On Feb 4, 10:54 am, "Jim Vincent" wrote:
wrote in message oups.com... Several years ago in soaring magazine there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. Many years ago there were tests of Schwiezer releases that showed that they did, indeed jam. These should all be replaced ASAP. Anyone with a brain can look at a Schwiezer release and see why it will jam under high loads. 2c I'll bite....why will it jam under high loads? This is extremely difficult to describe without a diagram, but the way the release is constructed causes pressure to be applied to the mechanism in such a way that higher forces are required in the cockpit as upward pressure on the mechanism is applied (towplane low, glider high). Too much pressure can cause this force to be great enough that the pilot will not be able to deliver such pressure in an emergency situation. 2c |
![]() wrote in message ups.com... On Feb 4, 10:54 am, "Jim Vincent" wrote: wrote in message oups.com... Several years ago in soaring magazine there was an article about a glider kiting and the tow pilot was unable to release. However the cause was not that the schweizer release jammed, it was the result of a poorly installed and secured release cable housing. The cable ties used to secure the release cable housing to the airframe failed, which then resulted in excessive slack in the release cable. This excessive slack meant that the tow pilots release handle was incapable of pulling on the schweizer release lever. Many years ago there were tests of Schwiezer releases that showed that they did, indeed jam. These should all be replaced ASAP. Anyone with a brain can look at a Schwiezer release and see why it will jam under high loads. 2c I'll bite....why will it jam under high loads? This is extremely difficult to describe without a diagram, but the way the release is constructed causes pressure to be applied to the mechanism in such a way that higher forces are required in the cockpit as upward pressure on the mechanism is applied (towplane low, glider high). Too much pressure can cause this force to be great enough that the pilot will not be able to deliver such pressure in an emergency situation. 2c Kevin, do you have any known examples of this happening? Flying off the winch is very similar to a glider high scenario, yet I've never had a problem releasing even under tension. |
Tow Hook on Cessna 180 - Update | Stuart Grant | Soaring | 13 | April 10th 20 10:48 AM |
Nose hook addition | Jack | Soaring | 2 | April 29th 06 08:08 AM |
SZD55 Launch hook info | Sleigh | Soaring | 3 | December 28th 05 08:57 PM |
Weight Limitation for the Front seats of a C172 | Brad Zeigler | Piloting | 3 | August 15th 05 02:43 AM |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
