Staying current/proficient
Old January 31st 07, 01:45 PM posted to rec.aviation.ifr
JB
Default Staying current/proficient
Example, say you start an approach in IMC. You break out and are able
to fly the rest of the approach VMC. Do you count this approach toward
currency?
I've seen this debated online over and over and over again. I think
the predominant view is that if you are in/above a layer and fly any
part of the charted approach by relying solely on instruments, it is
loggable. So if you on the approach course and can't see the ground,
then fly thru even a thin layer and break out 2500 AGL, its still
loggable.
But again, there are LOTS of view on this. I'm just reporting what
I've read, so DON'T shoot the messenger.
--Jeff
Old January 30th 07, 11:31 PM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Tuesday, January 30, 2007 12:26 PM
Posted To: rec.aviation.ifr
Conversation: Staying current/proficient
Subject: Staying current/proficient
Hi All,
Open question to folks, what strategies do you use to stay current or
better yet, proficient?
Check ride is right around the corner. I got signed off for the ride
today. So the currency question is in the back of my mind now. Most of
my flying is x-ctry (2/month) with some local scenic flights.
thanks,
KC
Kevin,
You should understand that almost every other instrument rated
pilot has the same problem - stay proficient and current. I solve this
by pairing up with some of the other pilots in our local CAP Squadron
and making sure we shoot some approaches or execute some holds at least
once a month. I get most of the work one month and the safety pilot gets
it another month. We each get to benefit from the other's faux pas. It
seems to work out such that we can all stay fairly proficient for about
1/2 the cost of me finding an instructor to ride along.
The x/c stuff is easy to handle because you're already flying
pretty regularly. It's the approaches, holds, departures, and local area
stuff that we need to work on.
Old January 30th 07, 11:48 PM posted to rec.aviation.ifr
A Lieberma
Kevin Clarke wrote in news:f5Mvh.16320$pQ3.8
@newsread4.news.pas.earthlink.net:
Owning my own plane helps alot, so the availability factor is not a problem
for last minute go decisions.
I actively seek IMC whenever I can which forces me to be proficient. I am
up to almost 680 hours with just shy of 40 hours IMC.
I have not had foggles on since training.
Look forward to your checkride report!
Allen
Old January 31st 07, 02:58 PM posted to rec.aviation.ifr
Paul kgyy
I use a PC simulator. If I'm planning a flight somewhere and the
weather looks uncertain, I will do the actual flight on the sim with
crosswinds and low ceilings, including the missed approach with hold.
I always file IFR on cross country flights except where the conditions
are good VFR and IFR involves a long detour (kgyy-kluk for example).
I had also been doing IPCs every 6 months but now my instructor has
relocated so I will probably need to use a pilot friend to fly safety
pilot with me.
Old February 1st 07, 12:01 AM posted to rec.aviation.ifr
Ray Andraka
Kevin Clarke wrote:
Hi All,
thanks,
KC
Several things:
1) file and fly in the system every time you go cross country, even if
the weather is severe clear VMC. Staying in the system keeps you
practiced with the procedures and keeps you sharp on maintaining
altitude and heading, as well as with the radios.
2) Always fly the instrument approach when you arrive at your
destination, regardless of the weather (since you're IFR, your request
for an instrument approach into your destination can't be turned down as
long as it is for the approach officially in use). Just don't bury your
head in the cockpit. I find it is actually harder to fly a good
approach in VMC than in IMC because of the division of your attention
between the panel and outside. By flying the approach, you stay sharp
on all aspects of doing an approach except actually being in IMC. You
also develop a better feel for where you are relative to the ground and
the airport this way.
3) Fly with an instructor and do an IPC every 6 months. Having an extra
set of eyes evaluate your performance gives you an opportunity to
correct bad habits before they become ingrained. It also shows the
insurance company that you are committed to doing regular recurrent
training, which may give you a break on your insurance, plus you'll get
an opportunity to practice stuff that doesn't come up in day to day
flying like holds, unusual attitudes and partial panel (all of which are
required parts of an IPC). If you are already reasonably proficient
(and you will be if you follow all 3 of these recommendations and fly
reasonably frequently), the IPC should take no more than an 2 hours of
instruction time...just enough time to do a few approaches, a hold and
unusual attitude.
Old February 11th 07, 08:08 PM posted to rec.aviation.ifr
Andrew Sarangan
On Jan 31, 7:01 pm, Ray Andraka wrote:
Kevin Clarke wrote:
Hi All,
thanks,
KC
Several things:
Great advice. Filing IFR in even under VMC will pay off. Not only does
it polish up your ATC skills, it will also simplifly your navigation
through busy complex airspaces. Example: every time I go to Detroit, I
get "cleared as filed" but I know from experience that Toledo always
amends my clearance as I get closer. Having done it plenty of times
under VFR, it was really not a big under IMC. That is not the type of
thing you want to handle on your first time in IMC in a busy airspace.
Again, good advice, but don't assume ATC will automatically issue you
an instrument approach because you are IFR. If it is VMC, they will
assume you want a visual approach unless you ask for it.
unusual attitude.
Good advice again, but I am not sure how the insurance company finds
out about your IPC. I was never asked about IPC, just whether I am
current or not.
Old February 11th 07, 08:28 PM posted to rec.aviation.ifr
Jim Macklin
Ask your insurance agent about discounts for regular
recurrent training [not just an IPC] at a school such as
caters to corporate operators. They can and do offer
discounts for regular training.
"Andrew Sarangan" wrote in message
| Kevin Clarke wrote:
| Hi All,
stay current or
off for the ride
mind now. Most of
flights.
| thanks,
| KC
| Several things:
country, even if
keeps you
maintaining
Not only does
navigation
to Detroit, I
Toledo always
of times
the type of
busy airspace.
your
IFR, your request
be turned down as
don't bury your
fly a good
your attention
you stay sharp
being in IMC. You
the ground and
they will
Having an extra
opportunity to
also shows the
regular recurrent
plus you'll get
day to day
(all of which are
an 2 hours of
| unusual attitude.
company finds
whether I am
| current or not.
Old February 11th 07, 11:04 PM posted to rec.aviation.ifr
Peter Clark
Or require it as a condition of the policy in certain types like the
PA46.
On Sun, 11 Feb 2007 14:28:55 -0600, "Jim Macklin"
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Home Built 4 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Owning 1 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Piloting 1 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Jay Honeck Owning 2 July 24th 03 09:11 PM
Oshkosh Get together Roster - Sign in, please! Jay Honeck Piloting 0 July 24th 03 04:15 AM
