A Pilot Gives Thanks
Old February 3rd 07, 09:16 AM posted to rec.aviation.piloting
Ben Jackson
Default A Pilot Gives Thanks
On 2007-02-03, Matt Barrow wrote:
Here's a very similar case which was a runaway trim.
http://www.ntsb.gov/ntsb/brief.asp?e...24X01192&key=1
What really stunned me about that report is that the probable cause
chain does not end with the pilot.
Ben Jackson AD7GD
http://www.ben.com/
Old February 3rd 07, 02:46 PM posted to rec.aviation.piloting
Ron Natalie
Larry Dighera wrote:
Ummm... If I were Willard, I'd have pulled the autopilot circuit
breaker. Strange no one thought of that.
My autopilot has no fewer than four ways to disable it. All except
the circuit breaker you're required to test during preflight.
Old February 3rd 07, 08:56 PM posted to rec.aviation.piloting
Matt Barrow
"Ben Jackson" wrote in message
Okay...I had a lot of "medicine" last night; could you elaborate on that?
Old February 4th 07, 09:14 AM posted to rec.aviation.piloting
Ben Jackson
Almost every NTSB report that involves the failure of an airplane system
that could have been mitigated by the pilot, no matter how terrible the
user interface, is ultimately blamed on the pilot. In that particular
report there's even a discussion of the steps the pilot could have taken
to fix the runaway trim condition, so I didn't expect them to give the
pilot any slack just because he was busy using both hands and all his
strength to keep the nose up...
Ben Jackson AD7GD
http://www.ben.com/
Old February 4th 07, 12:54 PM posted to rec.aviation.piloting
Mxsmanic
Ben Jackson writes:
It's ultimately blamed on the pilot because if the pilot doesn't do
everything possible, he'll probably be killed. Saying that it was
really not the pilot's fault doesn't help much if he's dead.
In other words, a pilot should do everything he can to save himself,
whether the interface is good or not.
Old February 4th 07, 07:56 PM posted to rec.aviation.piloting
Matt Barrow
/quote
The investigation revealed that the K6 relay failure would constitute a
single-point type failure in the electric pitch trim system.
(Key)
Pulling the circuit breaker, which is called for by the checklist in the
event of a trim runaway, would have arrested the trim movement _provided_
(emphasis mine) the circuit breaker was opened prior to the trim reaching
its stop.
Further examination of the system revealed that the autopilot autopilot/trim
disengage switch would not have disengaged the electric trim motor during
the type of failure experienced in the accident airplane.
/end
Sounds like he had just a few seconds to react, and the first order of
business was to disengage the AP, the he had to identify the problem as
runaway trim.
Not bad, for an 80 year old fart.
Stupid Question Crash Lander Piloting 35 July 23rd 06 02:39 AM
Sports Pilot Television Expands Market Coverage AJ Piloting 0 April 10th 06 11:17 PM
