![]() Quote:
Gary, I am a motion-sickness sufferer & also a pharmacist. I've tried all to commercial "over the counter" remedies, & while most (drug type, not herbal) work well enough, the side effects which can include drowsiness, dry mouth & urinary retention preclude safe flying. However, these side-effects vary widely in degree among individuals; some people notice none at all. I suggest you try several types recommended by your pharmacist (not all at once!) while firmly on the ground & see how they affect you. One which I have found personal success with is "Scopoderm TTS" which is a small patch (about the size of a quarter dollar) which you stick on your body the night before you fly & which will give relief from motion sickness for 72 hours. I have never felt sick with these & find them great for competitions etc where you tend to dolphin soar more than normal. I suffer no drowsiness at all with these. BUT you may be different so try before you fly. I maintain a pilot suffering for motion sickness is a more dangerous pilot than one with a slightly dry mouth from his medication. Good luck Brett |
On Feb 3, 11:57 am, Brett
wrote: Gary Emerson Wrote: Greetings, I typically suffer from motion sickness early in the season and sometimes on longer flights if the thermals are rough. I have one of the electronic wrist devices. It's of some benefit, but it's not an instant cure, at least for me. Just curious if there are any new meds or other solutions that might be in the works?? Gary Gary, I am a motion-sickness sufferer & also a pharmacist. I've tried all to commercial "over the counter" remedies, & while most (drug type, not herbal) work well enough, the side effects which can include drowsiness, dry mouth & urinary retention preclude safe flying. However, these side-effects vary widely in degree among individuals; some people notice none at all. I suggest you try several types recommended by your pharmacist (not all at once!) while firmly on the ground & see how they affect you. One which I have found personal success with is "Scopoderm TTS" which is a small patch (about the size of a quarter dollar) which you stick on your body the night before you fly & which will give relief from motion sickness for 72 hours. I have never felt sick with these & find them great for competitions etc where you tend to dolphin soar more than normal. I suffer no drowsiness at all with these. BUT you may be different so try before you fly. I maintain a pilot suffering for motion sickness is a more dangerous pilot than one with a slightly dry mouth from his medication. Good luck Brett -- Brett I'm a physician, glider pilot, and also have had motion sickness at times. I second what Brett says. The ScopeDerm Patches contain scoplomine, a tropane alkaloid drug that comes from the "deadly nightshade" group of plants. Scopolomine is a very powerful drug with strong "anticholinergic" effects. It is actually related to LSD, and in larger doses has the same type of effects in causing hallucinations and psychotic behavior. Of course, the doses used in the patches have been tested to be small enough to minimize the possibility of hallucinations, psychotic behavior, amnesia and somnolence. However, it can induce the dry mouth mentioned in the small dose that is used in the patch. If you are a male, and have "BPH" - benign prostatic hypertropy, which is common in the elderly, ahh.. sorry.. older middle age ;-) bracket of pilots that can afford the latest competition sailplanes and have the time on their hands to indulge in sailplane flying, you could be much more prone to the possibility of urinary retention than are women or younger males. The small doses used in the patches can also affect the ability of the eye to focus and tend to dilate the pupils. Some people who may be walking around with an condition called "narrow angle glaucoma" and do not yet know they have it, may have a sudden attack of increased pressure in the eyes accompanied by severe pain and difficulty seeing from this drug when the pupil dilates. This is not a very common condition, but people who have it do not often know about it until they have taken a medication that dilates their pupils, such as when they go in for an eye exam. This makes it very important as Brett says to try them on the ground before flying with them. I'm not an aviation medical examiner and I'm not really sure what the FAA's position is on using these patches while flying. I know there is a question on the form when you go for an FAA physical that asks if you have "Motion Sickness Requiring Drugs" I'm not sure what happens if you check "Yes". Anybody have any experience with that? I think NASA has tested scopolomine for astronauts 50% of whom get space sickness. However, I read that the most common drug they have used is "promethazine" also known as phenergan. It has less problem with the anticholingergic type of side effects mentioned above but makes one more sleepy. I do believe in the "conflict" theory that motion sickness when there is a conflict between what the eyes are seeing and what the vestibular system is telling your brain. When you can anticipate and predict the motion, it is much easier for your system to adapt and reduce the conflict. That's why you don't get sick as easily when you are flying vs. being a passenger when you cannot control the maneuvers of the aircraft. However, even when you are doing the flying, the motions from turbulent air are not very predictable. There are definitely certain head motions, which when associated with certain maneuvers of the aircraft, are known to cause very strong vesibular stimulation that could accentuate the tendency to motion sickness or even cause the pilot to put in control inputs that are not proper and dangerous because of the very strong tendency of the brain to react to a vestibular signals that is telling your brain your are tumbling, cartwheeling or spinning - to the point of overriding what the eyes are telling it. In Aviation Medicine, they have have categorized some of these and given them names. This link is an excellent overview of the subject: http://weboflife.ksc.nasa.gov/learni...ularSystem.htm Dan Johnson, a physician, glider pilot and FAA medical examiner who sometimes frequents this group, has done some excellent work and given talks at the SSA convention on his opinion that a number of otherwise difficult to explain accidents, particularly stall/spin accidents in the landing pattern may be the result of some of these type of vestibular illusions inducing the pilot to put in the wrong control inputs that actually cause the stall/spin. He has an excellent article he http://amygdala.danlj.org/~danlj/Avi...SDO/index.html The eyes can even be sort of disabled by the strong vestibular signal and start uncontrollably beating from side to side, a phenomenon called "nystagnus". Adrenaline, and/or having your mind occupied with urgent tasks that absorb all your thinking energy, such as flying xcross country with imminent outlandings also seems to counter the tendency to get sick. A boring flight close to the airport where you are not using 100% of your brain capacity for the flying will allow the visual/vestibular conflict to get the upper hand and start the motion sickness process. One interesting theory on the cause of motion sickness is on the Wikipedia and I am quoting it here, not sure if you can prove it, but it's an interesting idea: "The most common theory for the cause of motion sickness is that it evolved as a defence mechanism against neurotoxins. The area postrema in the brain is responsible for inducing vomiting when poisons are detected, and for resolving conflicts between vision and balance. When feeling motion but not seeing it (for example, in a ship with no windows), the inner ear transmits to the brain that it senses motion, but the eyes tell the brain that everything is still. The area postrema will always believe the inner ear signal over the eyes, as the eyes are more susceptible to trickery (see optical illusion). As a result, the brain will come to the conclusion that one is hallucinating and further conclude that the hallucination is due to poison ingestion. The brain responds by inducing vomiting, to clear the supposed toxin." |
![]() I'm a physician, glider pilot, and also have had motion sickness at times. I second what Brett says. The ScopeDerm Patches contain scoplomine, a tropane alkaloid drug that comes from the "deadly nightshade" group of plants. Scopolomine is a very powerful drug with strong "anticholinergic" effects. It is actually related to LSD, and in larger doses has the same type of effects in causing hallucinations and psychotic behavior. Of course, the doses used in the patches have been tested to be small enough to minimize the possibility of hallucinations, psychotic behavior, amnesia and Aplogies to the group: It was pointed out to me by another physician/pilot that scoplomine and LSD are not chemically related and actually are thought to operate on different neurotransmitters in the brain. They are only similar in their effects in causing hallucinations. He stated that the hallucinations from LSD are different than those from scopolomine and that is also correct, I'm sure. My partner did have one elderly patient accidently forget that she had already placed a patch behind her ear that day, and put another one on at the same time. Because of the excessive dose, she did go on a "trip" that lasted about 4 days even though the patches were removed, and had to be hospitalized, although eventually she recovered with no apparent long term effects.. I don't have experience with any patients on LSD, so I guess to me it seemed like a similar example to use regarding the hallucinogenic effects. But I messed up if it left the impression that scopolomine and LSD are close pharmacologic relatives. I was just thinking to myself, "My God, there might be somebody out there with some LSD laying around that might get the idea that if scopolomine and LSD were related, maybe I'll just try a very small dose of this LSD for my motion sickness." ;-) I couldn't live with myself if that happened, so if anybody got that impression - DONT TAKE THAT LSD AND TRY TO FLY!!!! ;-) But if you've ever seen someone who's tried "Jimson Weed", that IS closely related pharmacologically. So that might have been a better example to use than LSD. BUT DON'T TRY JIMSON WEED FOR MOTION SICKNESS EITHER!!!! ;-) |
Gary Emerson wrote:
Greetings, I typically suffer from motion sickness early in the season and sometimes on longer flights if the thermals are rough. I have one of the electronic wrist devices. It's of some benefit, but it's not an instant cure, at least for me. Just curious if there are any new meds or other solutions that might be in the works?? I've had good luck with ginger Altoids candies. Avoid Pepperidge Farm's banana loaf. You can guess how I know :-P Shawn |
Gary Emerson wrote:
Greetings, I typically suffer from motion sickness early in the season and sometimes on longer flights if the thermals are rough. Recently, I've begun to wonder if some pilots are experiencing sickness caused (or at least increased) by a contaminated water container. My hypothesis is the container sits around all winter, half full of water, and some crud grows in it. The pilot starts flying again, drinks water with crud in it, and gets sick (or sicker than just motion sickness would make him). After a few flights and several quarts of fresh water now run through the container, the container is relatively clean again, and the pilot no longer gets sick. Plausible? Is there any evidence? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() Very plausible. Replacement bladders for these "camelback' things only cost about $15 - I buy a new one each Spring. I does concern me that several posters mentioned flying while suffering from airsickness. BTDT and I know I wasn't a great pilot under it's effect. Fortunately, age and experience has overcome it. I think of you suffer from airsickness it is a good idea to fly a 2-seater with another pilot for a while each spring until you re-adapt to flight. Bill Daniels "Eric Greenwell" wrote in message news:hocxh.1279$fT1.1038@trndny02... Gary Emerson wrote: Greetings, I typically suffer from motion sickness early in the season and sometimes on longer flights if the thermals are rough. Recently, I've begun to wonder if some pilots are experiencing sickness caused (or at least increased) by a contaminated water container. My hypothesis is the container sits around all winter, half full of water, and some crud grows in it. The pilot starts flying again, drinks water with crud in it, and gets sick (or sicker than just motion sickness would make him). After a few flights and several quarts of fresh water now run through the container, the container is relatively clean again, and the pilot no longer gets sick. Plausible? Is there any evidence? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Bill Daniels wrote:
Very plausible. Replacement bladders for these "camelback' things only cost about $15 - I buy a new one each Spring. Where do you buy them Bill? I just paid $30 at the Boulder REI for a new 100 oz bladder. I use my camel backs (I think we have five of them) for cycling, skiing, hiking, road trips as well as flying. The drying rack they sell is well worth the bucks to keep them mold free. Also, after emptying any left over water, I grab the hose near the bladder and spin vigorously to force the last of the water to the end (that sounds bad doesn't it?). Squeeze the bite valve to drain the last of it. No icky green tubing for a few years now. Shawn |
Try WallMart or Target.
Bill "Shawn" wrote in message . .. Bill Daniels wrote: Very plausible. Replacement bladders for these "camelback' things only cost about $15 - I buy a new one each Spring. Where do you buy them Bill? I just paid $30 at the Boulder REI for a new 100 oz bladder. I use my camel backs (I think we have five of them) for cycling, skiing, hiking, road trips as well as flying. The drying rack they sell is well worth the bucks to keep them mold free. Also, after emptying any left over water, I grab the hose near the bladder and spin vigorously to force the last of the water to the end (that sounds bad doesn't it?). Squeeze the bite valve to drain the last of it. No icky green tubing for a few years now. Shawn |
Eric Greenwell wrote:
Recently, I've begun to wonder if some pilots are experiencing sickness caused (or at least increased) by a contaminated water container....snip Plausible? Is there any evidence? Yes, Eric, I think you're quite right. I've seen some Camelbak tubes which are almost completely opaque with some form of living crud! A friend who was sick at a comp suspected a dirty water bladder - and the problem stopped when he changed to a clean, new one. Since they can never be drained completely, I've taken to emptying my bladders and tubes and putting them in the freezer when they're not in use. So far, no crud after several years - and no sickness. GC |
My wife suffers occasionally and has found great relief
with the electronic wrist device but only if she turns it up to a level that is slightly uncomfortable. I suffer rarely but on those occasions have had the same experience. If you can't tell that it's firing, it won't help. If you start to feel queasy, turn up the intensity. That always works for both of us. Whether the mild electric shocks are bad for you in other ways, I don't know. Forest At 02:12 03 February 2007, Gary Emerson wrote: Greetings, I typically suffer from motion sickness early in the season and sometimes on longer flights if the thermals are rough. I have one of the electronic wrist devices. It's of some benefit, but it's not an instant cure, at least for me. Just curious if there are any new meds or other solutions that might be in the works?? Gary |
Instructors: is no combat better? | ArtKramr | Military Aviation | 103 | March 13th 04 09:07 PM |
Did you ever give up on an IR? | No Such User | Piloting | 24 | November 26th 03 02:45 PM |
Combat Related Special Compensation update for Sept. 8-12 | Otis Willie | Military Aviation | 0 | September 17th 03 03:38 AM |
