#11
On Feb 5, 9:46 am, Mxsmanic wrote:
chris writes: In this country (NZ) we seem to hear 'rolling' from people who have been trained at uncontrolled airfields and seem to bring that with them when flying into controlled airfields. The rest of us don't generally say it until we get to an uncontrolled airfield.. Do you say anything prior to the take-off? If so, what do you add by saying "rolling"? (If not, I can understand why you'd say it, although by the time you _are_ rolling, it's a bit late to warn anyone who might be in your way.) -- Transpose mxsmanic and gmail to reach me by e-mail. At a controlled airfield 'rolling' is quite redundant, since before you can takeoff you must have received a clearance to takeoff and then have read it back. Rolling is useful at uncontrolled airfields because there is no ATC, therefore no clearance required to takeoff so it lets other pilots who might be on downwind or finals know you'll be off the runway in a few seconds and they will be able to land. At an uncontrolled airfield I will often make a radio call when lining up and another for rolling.. |
The way I have heard 'rolling' used, and the way I have sometimes used
it myself, is if given a clearance along the lines of "Cessna XYZ, cleared for take-off, no delay" or "Cessna XYZ, cleared for take-off - expedite, landing traffic". In this situation, when you acknowledge the clearnace, you could say "Cleared for take-off, Cessna XYZ". This does not confirm to the controller that you heard the 'expedite', and so may cause the controller to repeat the instruction. Or you can say "Cleared for take- off, no delay, Cessna XYZ". Or "Cleared for take-off, rolling, Cessna XYZ" or even "Rolling, Cessna XYZ". As previously advised to in a thread a while back in this group, when given a take-off clearance with an 'expedite' in it, I tend to glance up the final approach path, then push the throttle in, then key the mike for the acknowledgement. It's nice when controllers do things efficiently, saving me 0.1 hour at rental rates, so I try to be as responsive as possible in return. |
If tower says clear for immediate takeoff, I announce 'rolling'. They
can tell ATC. On Feb 4, 3:46 pm, Mxsmanic wrote: chris writes: In this country (NZ) we seem to hear 'rolling' from people who have been trained at uncontrolled airfields and seem to bring that with them when flying into controlled airfields. The rest of us don't generally say it until we get to an uncontrolled airfield.. Do you say anything prior to the take-off? If so, what do you add by saying "rolling"? (If not, I can understand why you'd say it, although by the time you _are_ rolling, it's a bit late to warn anyone who might be in your way.) -- Transpose mxsmanic and gmail to reach me by e-mail. |
chris writes:
At a controlled airfield 'rolling' is quite redundant, since before you can takeoff you must have received a clearance to takeoff and then have read it back. Rolling is useful at uncontrolled airfields because there is no ATC, therefore no clearance required to takeoff so it lets other pilots who might be on downwind or finals know you'll be off the runway in a few seconds and they will be able to land. At an uncontrolled airfield I will often make a radio call when lining up and another for rolling.. Thanks, that seems logical. -- Transpose mxsmanic and gmail to reach me by e-mail. |
However, although it makes sense, pilots are not required to acknowledge or
read back a take off or landing clearance. |
![]() "Mxsmanic" wrote in message This is the way I do it, mostly. If the controller makes it clear that I must take off immediately, I acknowledge the clearance and also indicate that I'm actually moving. Conversely, if the controller does not make it clear that I must move quickly, and if for some reason there is any significant delay between my readback of the clearance and my actual take-off, I will advise the controller when I'm actually rolling. -- Transpose mxsmanic and gmail to reach me by e-mail. NOTICE!!!! Mxsmanic is NOT a pilot, has NEVER flown an aircraft and is NOT qualified to issue competent information regarding any aspect of the operation of any aircraft. |
Casey Wilson writes:
NOTICE!!!! Mxsmanic is NOT a pilot, has NEVER flown an aircraft and is NOT qualified to issue competent information regarding any aspect of the operation of any aircraft. The current topic is communication with ATC, not flying by the seat of the pants, and in this context, real aircraft experience is irrelevant. If you think otherwise, please explain why, specifically. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Under what conditions, if any, would you explicitly tell ATC that you are rolling, that is, actually rolling on the runway for take-off? I hear this used occasionally, but I don't know if there are any formal circumstances that merit it, or if it is just at pilot discretion, or what. It is normally independent of the readback of the take-off clearance (which precedes it), although sometimes I hear "Rolling" without a readback of the clearance. What is the name of Dagwood's wife? |
