#11
Umm... OK.
So may I ask what was wrong with his other two paragraphs? Dave On Sun, 04 Feb 2007 19:09:26 -0500, Ron Natalie wrote: Mxsmanic wrote: A GPS can only determine your track over the ground, which may not be your heading. This is the only thing that you said in your three whole stupid ass paragraphs that was correct or the least bit relevent. Unless you actually learn something about flying IFR in reality rather than ****ing your life away in front of flight simulator you'll never have an understanding of flight. By the way, if you got your lard ass out of your chair and got some excercise, you wouldn't overgross the training ships you might be able to fly. |
Dave wrote:
Umm... OK. So may I ask what was wrong with his other two paragraphs? They all repeat the same stupid irrelvent point. In fact, the key of partial panel appraoch is simple. If you aren't changing altitude and you aren't changing heading (either by GPS or compass) then you are straight and level. In fact, a GPS with a fast enough refresh rate is as good (perhaps) better than a needle-ball gauge and even your average portable is a whole lot better than the whiskey compass. |
Ron Natalie writes:
If you aren't changing altitude and you aren't changing heading (either by GPS or compass) then you are straight and level. GPS doesn't know your heading. It only knows your ground track, which isn't the same thing. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Feb 4, 9:38 pm, Mxsmanic wrote:
Ron Natalie writes: If you aren't changing altitude and you aren't changing heading (either by GPS or compass) then you are straight and level. GPS doesn't know your heading. It only knows your ground track, which isn't the same thing. -- Transpose mxsmanic and gmail to reach me by e-mail. It doesn't matter. If your relative track doesn't change and you're coordinated, then you're not banking. Unless you're in a tornado. |
Mxsmanic wrote: Danny Deger writes: I am thinking about buying a 1946 Taylorcraft that has NO gyros at all on the panel. I really want at least a turn and bank so I want die if I loose reference to the horizon for any reason. I have been told that the heading information from a GPS is good enough to do the function of a turn and bank and allow emergency operations without having a visual horizon reference. Is this correct? A GPS can only determine your track over the ground, which may not be your heading. True, but utterly irrelevant. If there is no wind, both are the same, but if there is any wind, your heading could be significantly different from your ground track. Completely and totally irrelevant. GPS cannot determine your bank angle. No need to. In theory a GPS could determine if you appear to be making a standard turn, if there is no wind. The wind is irrelevant. Speed and rate of turn are all that is needed. All the rest of the drivel snipped. |
Mxsmanic wrote: Ron Natalie writes: If you aren't changing altitude and you aren't changing heading (either by GPS or compass) then you are straight and level. GPS doesn't know your heading. It only knows your ground track, which isn't the same thing. And why do you even remotely care what your heading is? |
"J. Severyn" wrote Actually there are specialized GPS units that can determine attitude and they have been around for at least 10-12 years. Google the "Trimble TANS Vector" and you will see one of the earlier units. http://trl.trimble.com/docushare/dsw...20997-00-C.pdf They operate by using at least 3 antennae (usually four antennae) and directly determine roll, pitch and yaw using carrier phase differences from the GPS satellites. Of course this is not the way the portable units derive the HSI info. That's some cool stuff. It seems as though I recall this subject coming up a few years ago in the homebuilt group, and nobody came forward with a system like this one. I didn't see a price associated with it anywhere. Is this a case of, "if you have to ask, you can't afford it?" g -- Jim in NC |
Brad writes:
It doesn't matter. If your relative track doesn't change and you're coordinated, then you're not banking. A GPS unit doesn't know if you're coordinated. And if your track _is_ changing, it doesn't know why. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Newps writes:
And why do you even remotely care what your heading is? Sometimes you have to maintain a heading; sometimes you have to follow a track. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Newps writes:
True, but utterly irrelevant. It's highly relevant. GPS can't be used as a bank indicator, nor can it be used as a turn indicator. All it can do is measure changes in your track, which it does by checking your position over the ground at regular intervals. It doesn't know the attitude of the aircraft, and it doesn't know if you are actually turning. The wind is irrelevant. Speed and rate of turn are all that is needed. A change in the wind will change your track as measured by the GPS. The GPS does not know if this is a turn or just a wind change. And if you turn, the GPS cannot distinguish that from a wind change, either. -- Transpose mxsmanic and gmail to reach me by e-mail. |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| WTB 2 1/4" Turn and Bank | Bill Batesole | Soaring | 3 | October 18th 05 03:43 AM |
| Turn & Bank Indicator and 2 gallons of poyester resin | [email protected] | Instrument Flight Rules | 0 | February 12th 05 08:52 PM |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| Turn and Bank - RC Allen vs Electrical Gyro Corp | Kevin Horton | Home Built | 0 | December 1st 03 01:46 AM |
