Icing tape - lessons learned.
Old February 8th 07, 11:50 AM posted to rec.aviation.piloting
Dylan Smith
Default Icing tape - lessons learned.
On 2007-02-07, BDS wrote:
I didn't listen to the tape but the descriptions that mentioned a sudden out
of control dive sure sound like a tailplane stall to me. It can take a
tremendous amount of force on the yoke to recover, and recovery technique is
not intuitive because it is not the same as the technique(s) used for a
normal wing stall.
Other nasty things can happen in icing too. You may remember the
incident with the ATR in Roselawn, Indiana (which has a substantially
similar airfoil to a Caravan, I'd imagine). Ice built up behind the
area behind the deicing boots in a ridge. The aircraft was on autopilot.
When the autopilot disconnected, the ailerons underwent a "hinge moment
reversal" - so instead of wanting to remain neutral, snapped to full
control deflection very suddenly. The plane went inverted, and the crew
split-S'd out of it. Unfortunately, the aircraft disintegrated during
the split S from the G forces.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old February 7th 07, 04:10 PM posted to rec.aviation.piloting
Nathan Young
I think the lesson is stay aware of icing conditions, and if you must
absolutely fly in/near icing conditions - you better put the airframe
into the instrument scan.
Icing cannot be ignored, but that is precisely what this thread has
hypothesized.
First, the Caravan was flying in an area near icing. Strike One.
Second, this thread has hypothesized that the pilot failed to use
pitot heat, boots, and/or let the autopilot fly the plane into the
stall. Strikes 2,3,4.
Avoiding any one of these items likely would have precluded the
incident.
Scary Icing ATC tape Jay Honeck Piloting 95 February 6th 07 05:35 PM
Lessons learned during a rough ride today...(Longish) Jay Beckman Piloting 6 June 9th 06 12:44 AM
A Week Off the Grid: Lessons learned Vaughn Soaring 5 September 13th 04 01:17 AM
Runway Lights -- Lessons Learned John Clonts Instrument Flight Rules 0 August 29th 03 10:41 PM
Runway Lights -- Lessons Learned John Clonts Piloting 0 August 29th 03 10:41 PM
