#11
Yeah, I remember back in 1988 seeing on TV the airshow at Ramstein
where the Italian aerobatic team had a mid-air. It injured over 400 people and killed 70. Airshow regulations were changed to better protect the audience. That's the point here - learn from this tragic accident, recognize there was a problem with the "show" as it was being conducted, and change things so people don't get hurt or killed in the future. -John On Feb 11, 2:16 pm, Stefan wrote: Ever seen an airshow? |
At 19:18 11 February 2007, Stefan wrote:
Stewart Kissel schrieb: The logic here still escapes me....soaring contest organizers are to ask the FAA for a waiver...so that an activity that the vast majority of pilots do not choose to do, and consider unsafe...will be permitted? Ever seen an airshow? Many, and the proffesional well trained, checked and authorised pilots who fly in them. The rules for a display pilot, in the UK at least require a standard of airmanship that is verifiable. Every display pilot has a minimum level to which he is cleared, only the best of the best get cleared to the lowest level. |
Stewart Kissel schrieb: The logic here still escapes me....soaring contest organizers are to ask the FAA for a waiver...so that an activity that the vast majority of pilots do not choose to do, and consider unsafe...will be permitted? Ever seen an airshow? OH, you mean where pilots are trained and pass tests before being allowed to make aerobatic manuevers. Where pilots may not be fatigued and dehydrated from tough 5 hour cross country flight. Where workers on the field delineate safe areas for the public to stand. Where airplanes are sequenced into airspace, rather then screaming in on final glider from all directions? Where airshow pilots *may* participate in regular physical fitness programs to improve their stamina? Where the purpose of the airshow is aerobatic manuevers, not cross country competition with the need for high-g pull up at the end. Yes, I have seen several of these. Are you stating we should categorize cross country soaring competitions as 'air shows'? Low passes look and sound cool...in an uncontrolled environment conducted by fatigued pilots, who are also going to immediately enter into the most dangerous part of the flight(landing)...I don't see your analogy fitting. Maybe we should have the airshow pilots fly arond in the sun for 5 hours before starting their routines? Do glider aerobatic competitions start by first fatiguing the pilots? |
On Feb 11, 2:40�pm, Stewart Kissel
wrote: At 19:18 11 February 2007, Stefan wrote: Stewart Kissel schrieb: The logic here still escapes me....soaring contest organizers are to ask the FAA for a waiver...so that an activity that the vast majority of pilots do not choose to do, and consider unsafe...will be permitted? Ever seen an airshow? OH, you mean where pilots are trained and pass tests before being allowed to make aerobatic manuevers. *Where pilots may not be fatigued and dehydrated from tough 5 hour cross country flight. *Where workers on the field delineate safe areas for the public to stand. *Where airplanes are sequenced into airspace, rather then screaming in on final glider from all directions? Where airshow pilots *may* participate in regular physical fitness programs to improve their stamina? *Where the purpose of the airshow is aerobatic manuevers, not cross country competition with the need for high-g pull up at the end. Yes, I have seen several of these. *Are you stating we should categorize cross country soaring competitions as 'air shows'? Low passes look and sound cool...in an uncontrolled environment conducted by fatigued pilots, who are also going to immediately enter into the most dangerous part of the flight(landing)...I don't see your analogy fitting. Maybe we should have the airshow pilots fly arond in the sun for 5 hours before starting their routines? Do glider aerobatic competitions start by first fatiguing the pilots? Respectfully: Why don't you guys put pink skirts around your glider and have an old lady contest. You're just killing the fun. You all preach a good line with perhaps 1000' setback for launches next, bubble wrap to follow so that everyone's tush don't get scratch. After the contest you'll drive with your girlie glider down the highway at 80 mph with total disregard for the mother and her twins coming the other way. Those who want guarantees, stay home and wait, for death will arrive. More NASCAR fans die every year sitting in the stands than all the world combined from "Maximum Performance Finishes", EVER!! As tragic as the accident in UK was, the facts and statistics do not support a change in finish height. Ya, I know, say that to the widow, but one "specific type" accident over a defined time line determines trends, which in this case , there is none. The vast majority feel that MPFs are an important part of competition racing and all should maintain a watch to assure that they're done by everyone, safely. R |
but one 'specific type' accident over a defined time line determines trends, which in this case , there is none. So the space shuttle only having problems with O-rings on one occasion is not a trend? First you guys use the argument that these are inherily safe, then when something like this happens....the agument becomes it is the fault of the spectator or pilot. Flying 5' above the ground outside of an airport is stupid, true or false? |
Would this tragic fatality have occured if using the US contest finish
line rules? No. Stop pooping on the US rules. The straight in finish to landing (popular in World level and Grand Prix events) promotes very low (grass top) finishes. Our rules prohibit that type of flying. The Finish line is only used in National events, Regionals should be using the Finish Cylinder. The finish line has a bottom of 50' and an unlimited top, is 3300' in length and is positioned well away from people, vessels, vehicels and structures. When contest organizers properly place the finish line it is perfectly legal to fly down to 50' without any waiver from the FAA. If it is deemed that the finish line is over an area other than "sparsely populated", the bottom of the finish line should be placed at 500' or 1000' AGL as appropriate, or the finish cylinder should be used in its place. If Charlie and his van are the only congestion near the finish line, then he should be avoided by at least 500' slant range, (no requirement to be 500' AGL). There is no requirement to finish at 50', if 500' or above is more your style, then save your Depends from the soiling and finish high. |
Everytime this topic comes up I am more amused. JJ says he will not enter a
contest that allows it, that is his right, and I applaud him. Every pilot knows what he is comfortable with, and where his limits lie. Some people should use those limits better, and all would be fine. As mentioned earlier, NOTHING says you MUST finish at 50 feet and 140knots, so if you want to whine about this subject, just finish high and let everyone else alone. Very simple, and you still get no rude looks accross the table at the next glider meet! Trust me, I have started a few subjects that it has happened to me, right Henry!!! Brian Glick "Stewart Kissel" wrote in message ... Ya, I know, say that to the widow, but one 'specific type' accident over a defined time line determines trends, which in this case , there is none. So the space shuttle only having problems with O-rings on one occasion is not a trend? First you guys use the argument that these are inherily safe, then when something like this happens....the agument becomes it is the fault of the spectator or pilot. Flying 5' above the ground outside of an airport is stupid, true or false? |
R wrote...........
but one 'specific type' accident over a defined time line determines trends, which in this case , there is none. The US has had 10 finish gate accidents with 2 fatalities, is that enough for a trend? The vast majority feel that MPFs are an important part of competition racing and all should maintain a watch to assure that they're done by everyone, safely. R My point in all of this is; SSA sanctioned rules violate FAR 91.119 and we are in a vulnerable position if we have a UK type accident. Kirk believes the AIM allows him to fly any pattern he wishes. I'd like to listen in as he explains his 50 foot pattern to the Federallies. Let's see now, you started your pattern at 50 feet, pulled up to a tear-drop, down-wind and then landed the other way? When they get through shaking their heads, they'll read him the FAR about Minimum Safe Altitude, then the FAR about Reckless Flying, then they'll lift his ticket and well have one less cowboy ruining this sport for the rest of us. JJ |
FAR 91.119 and we are in a vulnerable position if we have a UK type accident. No they don't. Like anything else in life, common sense is required. You have to place the finish line so that you either finish along a runway, or away from people and property. Kirk believes the AIM allows him to fly any pattern he wishes. I'd like to listen in as he explains his 50 foot pattern to the Federallies. Let's see now, you started your pattern at 50 feet, pulled up to a tear-drop, down-wind and then landed the other way? When they get through shaking their heads, they'll read him the FAR about Minimum Safe Altitude, then the FAR about Reckless Flying, then they'll lift his ticket and well have one less cowboy ruining this sport for the rest of us. JJ Again, your interpretation vs mine. I've already talked to some FAA guys about it, and they agree with me. I'm sure you can find some other ones who would violate me on the spot - in fact I know one here in IL. Funny though, a circling approach at minimums is OK, though, to these same guys. Guess it depends on what you are trained to do, and who pays you salary. There is a difference between hotdogging in the pattern and flying a thought-out contest finish. And the FARs and AIM provide ample guidance on what you can - and cannot - do in the pattern. I comply with the regulations. You do not want to see it that way, so be it. But it seems to me that I'm not the cowboy in this rodeo trying to ruin this sport! Unfortunately, it's becoming a moot point since the creeping mediocrity of pilot-selected tasks and 500'/1 mile finishes after a 2 hour task seems to be taking over the sport. I guess my definition of a "contest" is different from some others out there. And a happy monday to you, too! Kirk 66 |
Vector altitude for ILS below GS intercept altitude? | M | Instrument Flight Rules | 23 | May 20th 06 07:41 PM |
How safe is it, really? | June | Piloting | 227 | December 10th 04 05:01 AM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 10:48 AM |
Minimum Safe Altitude (MSA) Standards | O. Sami Saydjari | Instrument Flight Rules | 23 | April 6th 04 03:28 AM |
