On Feb 12, 11:38 am, "Dan Luke" wrote:
Got a demo flight in a new Skylane Saturday morning. Very nice airplane. The G1000 stuff was a bit bewildering at first but otherwise it flew just like any good 182... I got a demo ride in the SR22 and Columbia 400 last year. Like you, I was behind the curve a bit with the Avidyne & G1000 panels (and I fly an EFIS equipped Pilatus) The capabilities are pretty amazing, once you read through the (lengthy?) ops manual The bad news is that we were burning 15.5 GPH to get that speed. What pwr & mixture setting? EGTs? |
![]() "Kingfish" wrote: On Feb 12, 11:38 am, "Dan Luke" wrote: Got a demo flight in a new Skylane Saturday morning. Very nice airplane. The G1000 stuff was a bit bewildering at first but otherwise it flew just like any good 182... I got a demo ride in the SR22 and Columbia 400 last year. Like you, I was behind the curve a bit with the Avidyne & G1000 panels (and I fly an EFIS equipped Pilatus) The capabilities are pretty amazing, once you read through the (lengthy?) ops manual The bad news is that we were burning 15.5 GPH to get that speed. What pwr & mixture setting? EGTs? 23" & 2300 rpm, IIRC. The mixture was 25 deg. ROP. Didn't check the EGTs. I wish I'd looked at the CHTs. |
![]() Dan Luke wrote: The bad news is that we were burning 15.5 GPH to get that speed. What pwr & mixture setting? EGTs? 23" & 2300 rpm, IIRC. The mixture was 25 deg. ROP. Didn't check the EGTs. I wish I'd looked at the CHTs. Then something is wrong. At 23 squared that is 65% for me(IO-520) and book flow is 13 gph. |
On Feb 12, 2:53 pm, "Dan Luke" wrote:
What pwr & mixture setting? EGTs? 23" & 2300 rpm, IIRC. The mixture was 25 deg. ROP. Didn't check the EGTs. I wish I'd looked at the CHTs. Dan, that EGT value looks quite close to the "red box" value that John Deakin teaches in his engine management course. Here's a link to his latest article, which covers (or reviews, actually) the EGT/CHT relationship. Good stuff here.. http://www.avweb.com/news/pelican/194452-1.html |
![]() Will wrote: On Feb 12, 2:53 pm, "Dan Luke" wrote: What pwr & mixture setting? EGTs? 23" & 2300 rpm, IIRC. The mixture was 25 deg. ROP. Didn't check the EGTs. I wish I'd looked at the CHTs. Dan, that EGT value looks quite close to the "red box" value that John Deakin teaches in his engine management course. Here's a link to his latest article, which covers (or reviews, actually) the EGT/CHT relationship. Good stuff here.. I believe he said the 23 squared was 65%. If so he is in the red box. You want to be richer then 100 ROP or leaner than peak EGT. |
![]() "Newps" wrote: Will wrote: On Feb 12, 2:53 pm, "Dan Luke" wrote: What pwr & mixture setting? EGTs? 23" & 2300 rpm, IIRC. The mixture was 25 deg. ROP. Didn't check the EGTs. I wish I'd looked at the CHTs. Dan, that EGT value looks quite close to the "red box" value that John Deakin teaches in his engine management course. Here's a link to his latest article, which covers (or reviews, actually) the EGT/CHT relationship. Good stuff here.. I believe he said the 23 squared was 65%. If so he is in the red box. You want to be richer then 100 ROP or leaner than peak EGT. According to the boss of the flight school who was giving me the test flight, that is the setting achieved by using the Garmin G1000's "lean assist" feature. Also according to him, that's Cessna's SOP for the airplane. -- Dan C-172RG at BFM |
"Dan Luke" wrote in message
...it trued 147 knots! Non-turbo at 5,500 feet, 10 deg. C OAT, 135 KIAS. ... The bad news is that we were burning 15.5 GPH to get that speed. The '67 182K I fly typically trues a good bit slower (~120), but I get much better fuel burn. I'm typically burning about 12.5 gph at that altitude. Lessee... 422nm trip @ 147 knots and 15.5 gph = 2.9 hours and $200 (no wind and 100LL @ $4.50/gal). Same trip @ 120 kt & 12.5 gph = 3.5 hr and $197. Three dollars to buy 30 minutes? Tempting deal. My real question is: What power setting were you guys using? I'm usually in the 65-70% range during cruise. -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://openspf.org ____________________ |
John T wrote:
Three dollars to buy 30 minutes? Tempting deal. How much does thirty extra minutes on your tach cost you? If you make those sorts of trips often it adds up to more maintenance dollars for ADs, more hours on the airframe when you sell, parts weraing out quicker and getting closer to TBO. |
![]() "ktbr" wrote: Three dollars to buy 30 minutes? Tempting deal. How much does thirty extra minutes on your tach cost you? Good point. In a typical year, I fly 120 hours. Let's say I average 125 kts, that's 15,000 nm. and $5670 of gas @ $4.50/gal. In a new Skylane, let's say I average 137 kts. That's 15,000 nm. in 109.5 hours. Times gas @ $4.50/gal * 15.5 gph (probably a high number) = $7638. So I would spend $2K more for gas, but put 10.5 fewer hours on the airplane, saving eight hundred bucks or so. Net $1200 more to fly the Skylane vs. the Cutlass RG. Not a bad deal to get the comfort of a 182. -- Dan C-172RG at BFM |
ktbr wrote:
How much does thirty extra minutes on your tach cost you? I see your point (adding another $47.50 to my cost above). There's also the question of "how much is 30 minutes worth to you?" I'm really wondering if the airframe is the root of the speed difference or power settings. I haven't parked next to a glass Skylane, so I don't konw what airframe differences there are. If a different style wheel pant and cowl would buy me 27 knots, I'm all over it. ![]() On the other hand, if most of this comes from running at a significantly higher power setting, it doesn't look as appealing. There may also be a significant difference in powerplant since I'm running a carbureted 230hp engine and I'd bet he's running an IO-540 (260hp?). -- John T http://sage1solutions.com/blogs/TknoFlyer Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
faster 182? | Dan Luke | Piloting | 26 | February 21st 07 02:40 PM |
Jeppesen USB Skybound Faster? | Marco Leon | Owning | 9 | September 18th 04 03:49 AM |
Looking At RAS Faster | B. Iten | Soaring | 10 | April 6th 04 10:21 PM |
Why small radius collects ice faster? | Andrew Sarangan | Instrument Flight Rules | 13 | March 25th 04 04:38 PM |
How much faster w/o slats? | [email protected] | Home Built | 7 | February 7th 04 03:47 PM |
