gear up landing of a Piper Arrow
Old February 17th 07, 05:09 AM posted to rec.aviation.piloting
Jim Macklin
Default gear up landing of a Piper Arrow
Let the prop strike at full power, you want a new firewall
forward. With a two blade prop, land on the mains, hold the
nose off and shut the engine down, it might even stop with
the blades horizontal.
But if you can get the mains down, you'll have a normal
landing, brakes and steering control. Very little damage to
the structure and probably zero injuries.
"Jose" wrote in message
. net...
| I was always under the impression that it's
| better to land on the plan's belly (with no gear down)
than it is to
| land with only 2 of the 3 gear down.
| Well, if the gear can keep the prop from striking, that's
a good thing.
| Jose
| Humans are pack animals. Above all things, they have a
deep need to
| follow something, be it a leader, a creed, or a mob.
Whosoever fully
| understands this holds the world in his hands.
| for Email, make the obvious change in the address.
Old February 17th 07, 03:59 PM posted to rec.aviation.piloting
Owen[_4_]
buttman wrote:
http://abclocal.go.com/kfsn/
click on "emergency response to troubled plane"
An arrow tried to bounce the plane on the runway to get the stuck
landing gear to come down, but all it did was make the other three
gear get stuck in the down position.
Wow, the follow up report is much more exciting than the landing!
A flight school mechanic & pilot wanted to try the old pull down the
gear from a truck, because they had seen that work in an Internet
video. The airport manager and sheriff dept. disagreed with that and
the end result was the mechanic getting zapped with a Stun Gun!
I would agree that such a maneuver is far too risky for the reward,
although it has paid off in the past for others. Could you fly the
airplane perfectly 6 feet over the runway in a perfect straight line
without so much of a gust moving the plane? A foot or two up or down
and you could cause a lot injury. I wouldn't want to be underneath
risking my neck and arms to find out.
http://abclocal.go.com/kfsn/story?se...cal&id=5038872
Old February 17th 07, 05:20 PM posted to rec.aviation.piloting
Jim Macklin
If you have insurance, the company does not want you adding
extra personal injury risk, they insured for hull damage,
not decapitated mechanic and wrecked truck. The TV shows
won't pay for suicide pictures [yet].
"Owen" wrote in message
the stuck
other three
landing!
pull down the
Internet
with that and
Gun!
the reward,
you fly the
straight line
two up or down
underneath
Old February 17th 07, 09:42 PM posted to rec.aviation.piloting
G. Sylvester
I wonder if "1 injured" will go in the NTSB report (if there is one).
Gerald
Old February 18th 07, 04:32 AM posted to rec.aviation.piloting
Robert M. Gary
On Feb 17, 9:20 am, "Jim Macklin"
It may be questionable if they would pay for the headless A&P anyway.
Its one of those things that if it works you look pretty slick, if it
fails you look really stupid.
-Robert
Old February 18th 07, 04:34 AM posted to rec.aviation.piloting
Robert M. Gary
On Feb 16, 9:06 pm, "Jim Macklin"
Always better to land with the mains down or with them up if
wing and nose. But A proper pre-flight and maintenance
reduces the issue to a rare case. But then lots of people
don't do the maintenance they should do.
Its amazing how often such a stuck gear situation follows immediately
after maintenance or after a really hard landing.
-Robert
Old February 18th 07, 09:58 AM posted to rec.aviation.piloting
Jim Macklin
Recap tires, tires over inflated, low strut or over inflated
strut, tow bar still attached to nose wheel.
I actually had some first hand knowledge of that incident.
Pilot flew in late in the evening, line person had to get
special tow bar for the aircraft. Line boy left it on the
aircraft, to speed up the departure the next morning.
Pilot comes out at dawn, does a "thorough pre-flight" and
takes-off with the tow bar adapter still on the nose wheel
[Piper Arrow]. Aircraft was high time.
Nose wheel stuck 1/2 way up, Pilot flew around for a while
and then landed. Airframe damage was limited to nose and
firewall. In my mind the pilot was solely responsible since
that big chunk of red painted iron was visible.
But the FBO bought the pilot a new engine, prop, and all
other parts and installed them at no charge. I guess they
thought that a jury might not understand the phrase "pilot
in command."
ps.com...
up if
people
immediately
| -Robert
Old February 18th 07, 01:30 PM posted to rec.aviation.piloting
Roy Smith
"Jim Macklin" wrote:
I guess they thought that a jury might not understand the phrase "pilot
in command."
Which is probably a reasonable guess.
Old February 18th 07, 04:56 PM posted to rec.aviation.piloting
Jim Macklin
A jury of my peer would know all about airplanes, firearms,
criminal law, etc. They would know terms such as "ring gap"
or "P-lead" as well as the difference between Bullseye and
Unique or Red Dot and Blue Dot.
But just like me, all attorneys will excuse them form a jury
because they can't be manipulated.
"Roy Smith" wrote in message
| "Jim Macklin"
the phrase "pilot
| in command."
Cessna Cardinal 177 RG II v. Piper Arrow III (70s) v. Piper Arrow III (brand new) [email protected] Piloting 90 September 23rd 06 12:48 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
Piper Arrow Add-on for FS2004? [email protected] Simulators 1 June 30th 05 01:27 AM
Piper Arrow vs Cessna 182 [email protected] Owning 28 June 27th 05 03:26 PM
Arrow auto gear extension oddness Roy Smith Owning 10 March 8th 04 02:27 AM
