Epidemic of cracked windshields in KDEN, explanation unknown
Old February 18th 07, 12:23 AM posted to rec.aviation.piloting,rec.travel.air
Roy Smith
Default Epidemic of cracked windshields in KDEN, explanation unknown
"Matt Barrow" wrote:
"Kev" wrote in message
On Feb 17, 11:15 am, Mxsmanic wrote:
See
http://us.cnn.com/2007/WEATHER/02/17....ap/index.html
So what would cause windshields to crack on many different types of
aircraft
at the same time? It wasn't impact or anything like that. [..]
I don't believe the "wasn't impact" part. I lived in Denver for a
while, and when the winds whip up, stones fly around.
That brought to mind the skit in "Monty Python and the Holy Grail" about
things that will float in water, one of them being small rocks.
But, ducks also float, and they fly. Airplanes also fly. Therefore,
airplanes are small rocks.
Old February 18th 07, 12:29 AM posted to rec.aviation.piloting,rec.travel.air
Matt Whiting
Jim Macklin wrote:
How cold did it get in Denver? Aluminum and plastic have
different contraction rates with cold. Plastic also gets
brittle with cold. Wind flexes wing, which also flexes
fuselages, erg---cracks.
It can't be as cold as the jets routinely see above 30,000 feet. I
suspect the wind was carrying stones or ice chunks or something like
that which cracked the windshields.
Matt
Old February 18th 07, 12:36 AM posted to rec.aviation.piloting,rec.travel.air
Kev
On Feb 17, 7:09 pm, Blanche wrote:
High winds. Low temps (-15F and up) == very cold wind chill factor.
Common misconception. Wind chill only applies to the heat loss of
animals. It does not apply to inanimate objects. The only thing
wind will do to metal, glass, plastic, etc is help cool it faster to
the ambient temperature.
Kev
Old February 18th 07, 12:38 AM posted to rec.aviation.piloting,rec.travel.air
James Robinson
I suspect the the crews turned on the electric windshield heating without
proper warmup when it was very cold, and the cracks resulted from thermal
stresses in the windows. The cracks were reported to have happened in the
air, where flying rocks would be rare, and not on the ground.
Old February 18th 07, 01:16 AM posted to rec.aviation.piloting,rec.travel.air
Mike Young
"Blanche" wrote in message
I would think that's still balmy and calm compared to the flight levels. I
dunno why they cracked. The airlines also don't know, and they have been
thinking about this much longer than we have.
Old February 18th 07, 03:05 AM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Bob Moore writes:
Of course these jet windshields are heated to provide the middle layer
of plastic with some flexibility to resist shattering in case of a bird
strike at low temps. Should the heating system be turned off and cold-
soaking occur(electrical bus turned off for trouble-shooting perhaps),
Boeing had a procedure for re-heating the windshield at very low temps
to prevent thermal shock from cracking the glass layers. This involved
cycling the power switches ON-OFF at one minute intervals for several
minutes. Sounds to me as if the temps at DEN were quite low and the flight
crews just turned the windshield heat ON and forgot about it.
Just one possibility of course.....
It sounds logical. Many models of aircraft were affected, though (and in fact
Boeing wasn't mentioned--if a Boeing windshield cracks, there's a _real_
problem). Mostly those Brazilian planes and some others. Most were on the
ground, not in the air.
Mxsmanic
Blanche writes:
Wind chill applies only to people, not things.
Old February 18th 07, 03:06 AM posted to rec.aviation.piloting,rec.travel.air
Matt Barrow[_3_]
"Jim Macklin" wrote in message
news
Single digits below zero. Nothing.
Certainly not "rocks blowing around".
Denver for a
Old February 18th 07, 03:14 AM posted to rec.aviation.piloting,rec.travel.air
Matt Barrow[_3_]
On Feb 17, 5:14 pm, "Jim Macklin"
On the other hand, they mentioned 100 mph ground winds,
Who is "they"?
and that means
flying rocks to me.
As those are borderline tornado winds, it's more like regular debris.
Matt Barrow
Performance Homes, LLC
Old February 18th 07, 03:18 AM posted to rec.aviation.piloting,rec.travel.air
Matt Barrow[_3_]
"Roy Smith" wrote in message
See
aircraft
Tell us how sheep's bladders can be used to predict earthquakes.
GPS loss of signal explanation Jay Honeck Owning 32 August 8th 06 04:05 PM
An Explanation? Mike Kanze Naval Aviation 0 June 29th 06 09:27 PM
Is the Iowa Mumps Epidemic Affecting Airmen? Larry Dighera Piloting 3 April 28th 06 04:37 AM
Fuel injection explanation [email protected] Piloting 18 June 23rd 04 02:57 AM
Windshields - tint or clear? Roger Long Piloting 7 February 10th 04 02:41 AM
