Flight planning software minimization algorithm
Old February 26th 07, 03:04 AM posted to rec.aviation.piloting,rec.aviation.ifr
Andrew Sarangan
Default Flight planning software minimization algorithm
On Feb 25, 7:28 pm, "Tony" wrote:
Don't get too tangled up in trying to find some 'optimum'. This is
instructive: do a manual calculation of what you consider might be
three or four 'likely best' routes. When you get done cranking the
numbers, you'll likely find not an important difference in your
several results. It's that old thing when we learned calculus --
nothing very interesting happens near a maxima or minima.
I normally do this stuff manually (using a computer nevertheless, but
manually entering the altitudes and ETDs), and it is a very cumbersome
process. The results are, like you say, are not dramatically
different, but I have found situations where moving the departure time
by a few hours, or planning a different fuel stop can shave off 30
minutes of flight time from a 500 mile trip. When the airplane cost is
$100/hr that could be an important consideration.
Also, in most flight planning situations we use a single cruising
altitude for the entire flight. Adjusting the cruising altitude on a
continuous basis is not handled by any software that I know of. If the
software can come up an ideal altitude profile, route profile and the
best time of departure, the pilot can then use this baseline
information from which to modify parameters to fit his specific
needs.
Old February 26th 07, 07:27 AM posted to rec.aviation.piloting,rec.aviation.ifr
Blanche
needs.
Destination Direct (destroyed, then killed by SAIC) had an option
where you could enter the winds and temps at various altitudes and
depending on the altitudes generated by the planner or altered by
the user, the flight plan was recomputed appropriately.
Jepp's low-end FliteStar can use winds but since I won't open my
firewall to allow it to access the Jepp weather server, I don't
know how well it works. But it also uses a variation of the
Djikstra algorithm - easy to identify it when you watch it attempt
to generate a flight path given certain conditions.
Kinda fun, too.
$10 Flight Planning Software [email protected] Aviation Marketplace 0 February 15th 07 07:55 PM
Best Flight Planning Software for a jet? CaptainCraig Piloting 2 September 8th 06 03:50 AM
Flight planning software Cetacea Instrument Flight Rules 2 May 14th 05 12:13 AM
Flight Planning Software Cetacea Piloting 2 May 13th 05 09:19 PM
flight planning software Russ Bird Piloting 1 November 22nd 04 03:08 AM
