mobile phones
Old March 5th 07, 05:35 PM posted to rec.aviation.soaring
Brian[_1_]
Default mobile phones
why do it in the air?
I've done it to call the Tower and get a landing clearance after my
radio faile
Brian
Old March 5th 07, 12:45 AM posted to rec.aviation.soaring
Tony Verhulst
If many consider it unsafe to drive
and talk, why do it in the air?
Well, I don't but, some would answer because it is unusual to be passing
obstructions at high speed an arms length away in a glider - gaggles not
withstanding.
Tony V.
Old March 5th 07, 02:20 AM posted to rec.aviation.soaring
Bill Daniels
"chipsoars" wrote in message
On Mar 4, 4:37 pm, "Peter" wrote:
What is the maximum altitude (about) when the mobile phone becomes
useless?
PeterK
I've had it ring at 2500'agl at which point I told whoever (my wife
and curtly too) that I was busy flying and then shut it off (I forgot
to shut it off prior to launch). If many consider it unsafe to drive
First, there are hundreds of thousands of pilots trained to verbally copy
and read back complicated airtraffic clearances while flying extremely
complex aircraft. For these pilots, a duplex phome conversation while
flying a simple glider is childs play. However, if it bothers you, don't do
it.
BTW, I don't think using satellite phones aboard an aircraft is prohibited
by FCC regulations.
Bill D
Old March 4th 07, 11:12 PM posted to rec.aviation.soaring
Tuno
Depends on the type of cell phone (2d generation, 3GPP etc) and where
you're flying.
My phone (model LG 8300) with Verizon service stops working in central
Arizona above pattern altitude. But it works great in the boonies of
Nevada all the way up to the 17,999'.
~ted/2NO
Old March 4th 07, 11:23 PM posted to rec.aviation.soaring
jeplane
The answer to your question will depend on what type of phone you
operate, the area you are in, or even the type of airplane, which
might interfere with reception.
However, you should not forget that the use of cell phones aboard
airborne aircrafts is banned by the FCC in 47 C.F.R. § 22.925:
(Oct 1, 2006 revision) states "Cellular telephones installed in or
carried aboard airplanes, balloons or any other type of aircraft must
not be operated while such aircraft are airborne. When any aircraft
leaves the ground, all cellular telephones on board that aircraft must
be turned off."
Richard
ASW19
Phoenix AZ
Old March 5th 07, 12:11 AM posted to rec.aviation.soaring
I really wish I could carry my cell phone and use in flight as safety
backup to contact the glider port etc. if out of radio range. But all
that space taken up by the paper copies of the FCC and FAA CFR's just
does not leave space for my cell phone in the cockpit... :-)
Darryl
be turned off."
Richard
ASW19
Phoenix AZ
Old March 5th 07, 02:51 AM posted to rec.aviation.soaring
Tuno
*yawn* It's also against the law to loiter within the walls of
Chester, England after sunset.
Old debates ...
~tuno
Old March 5th 07, 03:41 PM posted to rec.aviation.soaring
Mike the Strike
Old debates ...
~tuno
Only if you're Welsh - I used to live in Chester and loitered there
frequently after dark!
Old March 5th 07, 05:03 AM posted to rec.aviation.soaring
Marc Ramsey
be turned off."
47 CFR 22.295 applies only to "cellular telephones" (i.e. the old analog
things that operated in the 800 MHz band) licensed under Part 22. Most
of us now carry PCS (personal communications services) phones licensed
under Part 24, and as far as I can tell, the FCC has no regulations
against their use in flight...
Marc
Old March 5th 07, 04:26 PM posted to rec.aviation.soaring
Eric Greenwell
be turned off."
My cursory Google search backs up Marc's comments (not that I doubted
him - I was just curious about the details). So, unless someone can find
contrary documents, this may be the end of one of our favorite perennial
threads. May "Cell phone use in gliders" rest in peace.
And perhaps it's time to call them "mobile phones" instead of "cell
phones". I thing the Europeans have done that for years, already.
Cell phones on GA aircraft Mxsmanic Piloting 18 October 16th 06 08:12 PM
GET FREE CELL PHONES and CAMERA PHONES! ssgg Home Built 0 February 13th 06 02:34 AM
Fun with Wx on Cell Phones B4RT Rotorcraft 0 October 9th 05 02:45 PM
Cell phones in the air Roger Worden Soaring 35 March 30th 05 11:01 PM
Cell phones with GPS Roger Halstead Piloting 0 December 24th 03 03:04 AM
