Altimeter Calibration Height
Old March 10th 07, 05:37 AM posted to rec.aviation.piloting
Dallas
Default Altimeter Calibration Height
On Wed, 07 Mar 2007 21:37:53 -0800, TheSmokingGnu wrote:
The bottom of the landing gear? The height of the static port?
If you want to complicate your question ask about the other end of the
measurement, MSL.
From where do they measure MSL? Sea surface topography is constantly
changing. Do you measure from the tops of the waves? Bottoms? High tide?
Average tide? Average tide in the Pacific or average tide in the Atlantic?
How do you measure MSL in Panama? How do you get an average when currents,
air pressure variations, temperature and salinity variations are constantly
in flux? What about the melting and freezing of snow and glaciers? How
much time do you need to create this average?
Dallas
Old March 10th 07, 05:10 PM posted to rec.aviation.piloting
measurement, MSL.
Dallas
I know Wikipedia has something of a reputation, but they
put it in simple terms. Read http://en.wikipedia.org/wiki/Sea_level
They say MSL is 20' higher at the Atlantic end of Panama than at
the Pacific end. In the canal, of course, it will be much higher
between locks. That's not sea level anymore, it's manmade lake, about
80' MSL.
Dan
Old March 10th 07, 08:00 PM posted to rec.aviation.piloting
george
measurement, MSL.
Dallas
put it in simple terms. Readhttp://en.wikipedia.org/wiki/Sea_level
80' MSL.
Which is where QFE comes in :-)
Old April 2nd 07, 05:08 PM posted to rec.aviation.piloting
Steven P. McNicoll
"TheSmokingGnu" wrote in message
Here's one that may seem silly: to what height, precisely, is an altimeter
calibrated to?
The bottom of the landing gear? The height of the static port? the chord
line of the fuselage? In a Cessna, the difference between these is
minimal, but on an airliner, you're talking about a possible +/- 10-15
feet (even discounting the radar altimeter).
What is the answer, o Swammi of Salami?
An altimeter indicates altitude at the level of the instrument itself.
Old April 2nd 07, 05:51 PM posted to rec.aviation.piloting
Stefan
Source?
Old April 2nd 07, 05:53 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Stefan" wrote in message
Source?
Logic. Where is the sensing mechanism located?
Old April 2nd 07, 06:26 PM posted to rec.aviation.piloting
Jose
Source?
Poor logic. An altimeter indicates whatever it is set to indicate. It
senses pressure, and moves hands on a dial. Take the case where you are
in a one hundred foot tall aircraft with the altimeter right at the top
of the cockpit with you, a hundred feet in the air. (We'll neglect the
tail for now).
If you don't get an altimeter setting, you will (likely) set the
altimeter so that the hands indicate the airport elevation as indicated
on your charts, even though you and the instrument are a hundred feet
higher.
If you do get an altimeter setting, you'll set it for that. Then the
question becomes (since the altimeter doesn't know that it's in a tall
airplane) whether, at calibration in the shop, it was set to indicate
actual instrument altitude or to indicate something else (like
instrument altitude minus a hundred feet). I bet there are standards
for that. I don't know what they are, but they may well incorporate the
hundred feet deviation, since it is the =installation= that is certified.
Also, even if the static port and the instrument themselves are
separated in altitude, it would be the instrument altitude's pressure
that is sensed, since the "column of air" is connected, and ends at the
instrument.
Jose
Get high on gasoline: fly an airplane.
Old April 2nd 07, 06:33 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Jose" wrote in message
t...
in a one hundred foot tall aircraft with the altimeter right at the top of
the cockpit with you, a hundred feet in the air. (We'll neglect the tail
for now).
If you don't get an altimeter setting, you will (likely) set the altimeter
so that the hands indicate the airport elevation as indicated on your
charts, even though you and the instrument are a hundred feet higher.
actual instrument altitude or to indicate something else (like instrument
altitude minus a hundred feet). I bet there are standards for that. I
don't know what they are, but they may well incorporate the hundred feet
Also, even if the static port and the instrument themselves are separated
in altitude, it would be the instrument altitude's pressure that is
instrument.
In other words, an altimeter indicates altitude at the level of the
instrument itself.
Old April 2nd 07, 06:37 PM posted to rec.aviation.piloting
Stefan
Source?
You are aware that the altimeter displays the true altitude only in very
untypical, special cirumstances, are you?
Old April 2nd 07, 06:47 PM posted to rec.aviation.piloting
Steven P. McNicoll
Yes. I said nothing about that.
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
Cloud Height Indicator Bob Bristow Home Built 0 August 11th 03 07:42 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
