What's the pin for?
Old March 14th 07, 01:09 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
BT
Default What's the pin for?
"6 and 2, counted and stowed" (B-52 checklist response)
6 gear pins and 2 steering lock pins
BT
"PapaGeorge" wrote in message
nk.net...
Most fighters have three pins...both mains and nose gear. PapaGeorge
"Bob Moore" wrote in message
6.128...
Mxsmanic wrote
What does it mean when the crew of an aircraft look for "the pin" held
by the ground crew after pushback?
They are looking for the Nose Gear Ground Locking Pin to insure
that it has been removed prior to flight. If not, the nose gear
will not retract.
Bob Moore
ATP B-707 B-727
Old March 14th 07, 05:59 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
C J Campbell[_1_]
BT
C-130 had a bunch of pins, too, but I don't remember how many.
Waddling Eagle
World Famous Flight Instructor
Old March 14th 07, 02:18 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
Mxsmanic
PapaGeorge writes:
What do they do?
I thought aircraft usually had interlocks that would prevent gear from
retracting as long as they had weight on them.
Old March 15th 07, 04:17 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
Kev
The "squat switch" interlocks people usually speak of are to prevent
the gear control from being used with weight on the wheels. Nothing
to do with actually mechanically holding the gear down.
Many gear are designed so, yes, they tend to stay in place by
themselves. But put a tug on the front wheels, and you could push
the gear out of place.
Some planes, for example the Airbus, also depend on powered hydraulics
as a separate aid to holding the gear in place. They suggest that
pins be put in place if a tug is used to move an unpowered plane (such
as for maintenance).
Kev
Old March 15th 07, 06:15 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
Mxsmanic
Kev writes:
Somehow that doesn't surprise me.
Old March 20th 07, 07:41 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
"Kev" wrote in news:1173932233.850178.56640
@n76g2000hsh.googlegroups.com:
Actualy, no they don't. and you can lower the landing gear in any 'bus
through completely mechanical means and it wil stay down with no
hydraulics powering the system whatsoever..
They suggest that
They do that in any type of airplane...
Bertie
Old March 15th 07, 12:39 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
Jim Macklin
Most fighters and bombers also have arming safety pins too.
nk.net...
PapaGeorge
| 6.128...
"the pin" held
insure
nose gear
| will not retract.
| Bob Moore
| ATP B-707 B-727
Old March 15th 07, 05:45 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
Dan[_7_]
"Jim Macklin" wrote in message
That is correct. I was an Aviation Ordnance man.. Worked on A4b Skyhalks..
Guess that is showing my age.
You could play little tricks with the pins.. None of us ever wanted to be on
recovery for night ops.. If any ordnance came back, it could not be brought
back to the mags at night. We would have to post a watch on the trailer.
Pull the pin on the bomb rack when arming and gauranteed no bombs coming
back.
Probably the most inportant pin was in the pilots ejection seat. It was an
added safety feature. The landing gear alone should have disabled ejection.
but.... At NAS Jacksonville.. A guy playing around in the cockpit pulled the
ejection curtain with plane in the hangar, without the pin in. He made quite
a splash on a 50 foot high hangar ceiling. So saftey features always don't
work. All aviation rules are written in blood they say.. So if a pin should
be in. put it in.
Mxsmanic
Bob Moore writes:
will not retract.
Thanks. What's the purpose of this pin on the ground? (I assume it isn't
there just to prevent the gear from retracting while the aircraft is on the
ground (?).)
Old March 14th 07, 08:24 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting
Robert M. Gary
will not retract.
Bob Moore
ATP B-707 B-727
In the Navy the pins also cause the gear to be rigid so it doesn't
sway when the ship does. I remember once an A-7 arrived without the
pin in its normal on-aircraft storage place, there was a mad search to
find it. The concern was it may have fallen out of the storage and
fallen onto someone on the ground. Turns out some line guy on the ship
had forgotten to put it in where it was suppose to go, it was later
found hidden in his locker.
-Robert
