Canals in Missouri?
Old March 18th 07, 08:31 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Canals in Missouri?
"Blueskies" wrote in message
As always, Jay was VFR.
You are required to follow your clearance if you are IFR, where ever they
send you
there you are...
ATC would only divert him around a MOA if he was IFR.
Old March 18th 07, 08:38 PM posted to rec.aviation.piloting
Blueskies
ink.net...
: "Blueskies" wrote in message
: As always, Jay was VFR.
: You are required to follow your clearance if you are IFR, where ever they
: send you
: there you are...
: ATC would only divert him around a MOA if he was IFR.
Yup, that's what I said...
Old March 17th 07, 02:16 PM posted to rec.aviation.piloting
Jim Burns[_2_]
Google Little River Drainage District. They may look like canals, but they
don't "connect" directly to a major river or waterway. They are drainage
ditches. The reason for multiple ditches laying parallel to one another is
simply to increase drainage capacity. The "canals" are used to drain what
is sometimes called the Missouri "glades". The water eventually flows into
the St. Francis river and exits into the Mississippi about 1/2 way down the
eastern Arkansas border at Helena, AR. Started in 1907, it became one of the
largest drainage projects in the world, draining over 1.2 million acres.
Old March 17th 07, 01:37 PM posted to rec.aviation.piloting
Jay Honeck
ditches.
Holy cow! "Drainage ditch" just doesn't seem to adequately describe
something that big... They look to be easily navigable.
Thanks for the info.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination
Old March 17th 07, 02:56 PM posted to rec.aviation.piloting
Jim Burns[_2_]
Next time you fly to OSH, take a look at the Horicon Marsh in WI. You can
still see the canals and the paths made through the marsh when they tried to
drain it between 1910 and 1914. Pretty incredible from the air.
"Jay Honeck" wrote in message
they
drainage
ditches.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 17th 07, 06:03 PM posted to rec.aviation.piloting
Jay Honeck
Interesting -- will do. The only time I've ever over-flown the marsh
was as a student, and I was too busy dodging snow showers to notice...
Jay Honeck
Iowa City, IA
Pathfinder N56993
"Your Aviation Destination"
Old March 17th 07, 06:55 PM posted to rec.aviation.piloting
Steven P. McNicoll
On our flight from Memphis, TN to Iowa City, IA, today, we were
diverted around the Lindbergh MOA.
Congratulations! When did you add the instrument rating?
Old March 17th 07, 10:51 PM posted to rec.aviation.piloting
BT
If I'm getting flight following... and the ATC controller recommends a
divert around a HOT MOA.. and I refuse...
I can expect his next transmission to be, "Roger, radar service terminated,
squawk 1200, good day and good luck."
BT
thlink.net...
Old March 17th 07, 11:33 PM posted to rec.aviation.piloting
Steven P. McNicoll
"BT" wrote in message
terminated, squawk 1200, good day and good luck."
Why do you expect that?
Old March 18th 07, 10:52 PM posted to rec.aviation.piloting
BT
I have been on both sides of the mic. If a VFR aircraft chooses to proceed
through a HOT MOA and mix it up with fast fighters doing ACM (air combat
maneuvers) and I am not controlling the fighters.
He is on his own.
BT
news
First woman in Missouri Air National Guard awarded Bronze Star Associated Press Otis Willie Military Aviation 0 May 8th 04 09:47 PM
NW Missouri aircraft spotting mah Military Aviation 0 October 12th 03 12:03 AM
Where to soar near JefferonCity-Missouri? Jim Culp Soaring 0 September 15th 03 07:15 PM
Where to soar near Jefferson City - Missouri? Peter Soaring 2 September 15th 03 03:29 PM
