On Mar 27, 11:50 am, "Bob Gardner" wrote:
I used to handle that by saying to the new controller "BuzzBomb 234X, 7000 feet, on a vector." A previous controller can't issue an instruction that has any effect in a subsequent sector, to the best of my knowledge, But that clearly isn't the case. My original clearance was to go out to a VOR, then follow one airway, turn 90 degrees go up another airway etc. A previous controller changed my clearance to be direct (a much different route), which had great affect on not only the subsequent controller but about 3 controllers after that as well. -Robert |
oups.com... On Mar 27, 11:50 am, "Bob Gardner" wrote: I used to handle that by saying to the new controller "BuzzBomb 234X, 7000 feet, on a vector." A previous controller can't issue an instruction that has any effect in a subsequent sector, to the best of my knowledge, But that clearly isn't the case. My original clearance was to go out to a VOR, then follow one airway, turn 90 degrees go up another airway etc. A previous controller changed my clearance to be direct (a much different route), which had great affect on not only the subsequent controller but about 3 controllers after that as well. -Robert Something to keep in mind is an IFR clearance doesn't really have much of anything to do with separation. It's simply the route and altitude ATC has assigned to get the aircraft from A to B. It's in the computer and there's enough of it on each sector's strip so that controller knows where the aircraft is coming from and where it needs to end up. There may be (probably are) a dozen or more built-in conflicts with other aircraft on the same or different routes and altitudes. Controllers deconflict and ensure separation in real time. So long as the controller gets the aircraft to the required fix and altitude at the edge of his airspace without any conflicts he's done his job. Another thing worth knowing is some controllers will "bet on the come" with semi-routine route changes. They'll issue them to the aircraft *then* effect the required coordination. Sometimes this doesn't work out exactly right and they have to re-re-route or sometimes the ball gets dropped completely :-/ As long as it doesn't create a "deal" there isn't usually much of a fuss. So all it really takes to change a route is to issue it. As long as each subsequent controller accepts the aircraft nobody much cares what happens three sectors down the road. The new route should be entered into the ARTCC computer so the necessary new info gets forwarded to each controller as the aircraft progresses along the new route. That new route may (probably will) have its own set of a dozen or more built-in conflicts but again, nobody really cares. Those conflicts will be fixed when they need fixing. Ideally, the first controller approving any route change will enter it into the computer. But sometimes that doesn't happen. Maybe the first controller is too busy, too far from the ARTCC computer keyboard, or some other reason. In that case the first controller will call the next sector on a landline to coordinate the change prior to handoff. If the next sector accepts the handoff with the new route then the first controller has done all he needs to do. Now that second controller is obligated to either enter the change into the ARTCC computer or verbally coordinate with the next sector before *he* does a handoff. It goes on that way until *somebody* puts it in the computer or the aircraft reaches its destination. As for issuing instructions that affect other sectors that's concerned with real-time situations when a controller has an aircraft *in another controller's airspace.* In these situations the controller either has to coordinate what he wants to do (many LOAs allow limited control without additional coordination after a handoff but before the aircraft crosses the actual sector boundary), wait until the aircraft crosses into his own airspace, or handoff the aircraft to the controller who's airspace the aircraft is actually in (very common when an aircraft pops up on the wrong freq). |
I used to handle that by saying to the new controller "BuzzBomb 234X, 7000 feet, on a vector." A previous controller can't issue an instruction that has any effect in a subsequent sector, to the best of my knowledge, and the "new" controller can do whatever s/he needs to do without regard for what the previous controller did or said. I was taught that when on a vector, to check in with "New York, Cessna 123, assigned 270 heading". It always amazes me what controllers don't seem to know about me. It's kind of strange to have conversations like: New York: Archer 08X, were you cleared into the Class Bravo !? 08X: Um, yeah, two controllers ago. New York: Oh, OK. |
On Mar 27, 6:13 pm, Roy Smith wrote:
"Bob Gardner" wrote: I used to handle that by saying to the new controller "BuzzBomb 234X, 7000 feet, on a vector." A previous controller can't issue an instruction that has any effect in a subsequent sector, to the best of my knowledge, and the "new" controller can do whatever s/he needs to do without regard for what the previous controller did or said. I was taught that when on a vector, to check in with "New York, Cessna 123, assigned 270 heading". No altitude? -Robert |
![]() Robert M. Gary wrote: I'm curious, how does one controller secure a direct clearance through mulitple other controllers' areas? Sometimes it seems that after a handoff the receiving controller doesn't know what your clearance is (but certainly must have that area available for you). If I change your clearance before you takeoff I will make the change in the computer. It is the centers responsibility to get those updates. If I clear you direct after takeoff I am locked out of making changes in the computer and have to coordinate over the landline. Do controller's "own" their own areas or does the computer? A controller owns his own airspace. No computer owns anything. Can the computer approve a clearance through a controller's area w/o his acknowledgement? The computer does not approve/disapprove a clearance other than not accepting a clearance that doesn't work. For example trying to input going from one airway to another when those two airways don't cross or otherwise meet. You can always clear someone direct. |
On Mar 26, 7:33 pm, Newps wrote:
Robert M. Gary wrote: I'm curious, how does one controller secure a direct clearance through mulitple other controllers' areas? Sometimes it seems that after a handoff the receiving controller doesn't know what your clearance is (but certainly must have that area available for you). If I change your clearance before you takeoff I will make the change in the computer. It is the centers responsibility to get those updates. If I clear you direct after takeoff I am locked out of making changes in the computer and have to coordinate over the landline. Do controller's "own" their own areas or does the computer? A controller owns his own airspace. No computer owns anything. So, last night my updated direct clearance affected my route through 4 controller's airspace ( I have 4 handoffs since). Did the issuing controller have to call all 4 of those controllers before giving me the clearance? -Robert |
![]() Robert M. Gary wrote: So, last night my updated direct clearance affected my route through 4 controller's airspace ( I have 4 handoffs since). Did the issuing controller have to call all 4 of those controllers before giving me the clearance? -Robert If a controller has to make a landline call because he isn't able to update the computer he only calls the next sector. He wouldn't have any idea what guy to call after that and probably isn't able to anyways. |
On Mar 27, 12:03 pm, Newps wrote:
Robert M. Gary wrote: So, last night my updated direct clearance affected my route through 4 controller's airspace ( I have 4 handoffs since). Did the issuing controller have to call all 4 of those controllers before giving me the clearance? -Robert If a controller has to make a landline call because he isn't able to update the computer he only calls the next sector. He wouldn't have any idea what guy to call after that and probably isn't able to anyways. Sorry if I sound dumb but I really have no idea how this works. So, when the controller working the San Jose arrivals issued me a direct clearance, I know he spoke with the next controller (who was working Stockton area), but the updated clearance also affected the controller working south of Sacramento, etc. Since my updated clearance affected this Sacramento controller too (since it affects my route through his airspace), doesn't he need to be in on the updated clearance as well?? -Robert |
![]() Robert M. Gary wrote: Sorry if I sound dumb but I really have no idea how this works. So, when the controller working the San Jose arrivals issued me a direct clearance, I know he spoke with the next controller (who was working Stockton area), but the updated clearance also affected the controller working south of Sacramento, etc. Yes. The strip would be updated by whichever controller has control of the flight plan. Since my updated clearance affected this Sacramento controller too (since it affects my route through his airspace), doesn't he need to be in on the updated clearance as well?? No. He takes what is given to him. He has a 30 minute advance notice of arrivals. If there's something he doesn't like he can call the sector where the airplane will come from and slap on a restriction. |
Big Debts are costing troops their Security clearances | Tiger | Naval Aviation | 8 | October 28th 06 01:53 AM |
Obtaining IFR clearances in Canada | Andrew Sarangan | Instrument Flight Rules | 10 | July 22nd 04 03:47 PM |
Question: civilian contractors and security clearances | Charlie Wolf | Naval Aviation | 5 | July 6th 04 03:54 AM |
Clearances for Practice | Jerry Kaidor | Instrument Flight Rules | 1 | March 28th 04 07:00 PM |
Where is approach good about multiple approaches and clearances in the air? | Andrew Gideon | Instrument Flight Rules | 29 | February 14th 04 02:51 AM |
