yet another annual story - day three (finished)
Old March 27th 07, 09:55 PM posted to rec.aviation.owning
Steve C
Default yet another annual story - day three (finished)
On Mar 27, 3:51 pm, "Jay Honeck" wrote:
We usually total about 40 man-hours - just spread out. If we did
it continuously, we'd be done in three days or less.
With the fixed expense of airplane ownership being what it is (high,
regardless of actual usage), making your plane unavailable for three
weeks every year seems awfully expensive.
Jay Honeck
Iowa City, IA
Pathfinder N56993www.AlexisParkInn.com
"Your Aviation Destination"
Agreed. But that's what fits my work schedule the best.
Old March 27th 07, 10:10 PM posted to rec.aviation.owning
Robert M. Gary
On Mar 27, 1:15 pm, "Jay Honeck" wrote:
Well, on a Mooney removing all the inspection panels itself is a day,
putting them back is another day. Lubing is almost an entire day, etc.
I just had a deja vu moment -- did we have this discussion last
annual?
So you're saying it takes a full, 8-hour day to remove inspection
panels from a Mooney?
Let's see, even if you can only remove one screw every 60 seconds (and
I hope your A&P isn't *that* slow), that would be 480 screws. Figuring
an average of eight screws per inspection panel (at least that's the
way it is on my plane), you're talking about 60 inspection panels.
60 is actually pretty close, at least the 480 screws is pretty close.
It may actually be more screws than that. This IA requires that all
the inspection panels be opened. I also do not have the one piece
belly.
-Robert
Old March 27th 07, 11:52 PM posted to rec.aviation.owning
Paul kgyy
On Mar 27, 12:27 pm, "Robert M. Gary" wrote:
On Mar 26, 5:40 pm, Bob Noel
Nothing to say except wrapped up the annual.
24 hours of time for the two mechanics, which included installing the
knots-2-U strobe (which is NOT a 6.5 hour job), plus some of my time
opening and closing the various panels.
A three day turn on an annual inspection plus an STC install is pretty good.
Now I'm looking forward to some flying weather and time off from work...
Bob Noel
(gave up looking for a particular sig the lawyer will hate)
WOW, My record for an annual is 3 weeks. Some have wondered if its
called an annual because it takes a year.
-Robert
I brought mine in January 12, and with luck will pick it up this
Friday... :-( Usually it's 2-3 weeks, but this has been a year of
"progressive revelation". They pulled the nose trunnion off because
it was damaged from somebody's airport tug. They had difficulty
removing it; it turned out that the engine mount structure to which it
was attached was twisted. So off comes the engine, prop, everything
firewall forward, ship to Kosola to reweld new tubing and straighten.
The drag link also turned out to be warped. I've made some pretty
hamhanded xwind landings, but this is making a severe dent in my
retirement money.
Old March 28th 07, 01:49 AM posted to rec.aviation.owning
Roger[_4_]
On 27 Mar 2007 10:27:31 -0700, "Robert M. Gary"
Bob Noel
I've had the Deb since around 92 or so. Most annuals have run about a
day and that includes a gear retraction on jacks. The last two were
two days as the mechanic had to work alone. They also have to pull
the seats (ever try to line up a Bo seat to get it back on the
tracks?) and spar cover to get at the retraction mechanism and inspect
the carry through. Oil change, set timing, check compression, check
and clean plugs, degrease engine, pull all access covers and check
controls and check all ADs. Mechanic keeps these on computer so it's
a relatively quick check and if you have an AD, annual time is the
best time to tackle it.
I do a progressive maintenance program so there is seldom much that
needs fixing. A few times we've changed brake pads.
-Robert
www.rogerhalstead.com
Old March 28th 07, 02:48 PM posted to rec.aviation.owning
Jay Honeck
What type aircraft do you fly?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 28th 07, 03:25 PM posted to rec.aviation.owning
Steve C
Jay Honeck
Iowa City, IA
2001 Diamond Star
Steve
Old March 28th 07, 06:34 PM posted to rec.aviation.owning
Tri-Pacer
I recently did an owner assisted annual in about 9 hours total.
Granted it was a very simple airplane that I have maintained for a number of
years and no major ADs or discrepencies were found.
The owner removed and replaced all the floor boards, inspection plates,
fairings, while I did my inspection, AD compliance, leakdown, lube etc.
I keep my ATP Navigator on a Laptop and print out new AD compliance logs and
stick on labels for log entries and he flew out while there was still
daylight.
Cheers:
Paul
N1431A
Old March 30th 07, 05:50 PM posted to rec.aviation.owning
Robert M. Gary
daylight.
Cheers:
Paul
N1431A
When I had the Aeronca the annuals were very straight forward. The
only hold up was waiting for another A&P to be in town who was small
enough to climb into the tail and inspect the control cables back
there. The A&Ps on the field wouldn't fit.
-Robert
yet another annual story - day one Bob Noel Owning 3 March 26th 07 02:32 AM
yet another annual story - day two Bob Noel Owning 0 March 26th 07 01:15 AM
Yet another annual story - nice short happy one Bob Noel Owning 3 April 2nd 06 02:04 PM
About Finished [email protected] Home Built 8 July 8th 05 08:59 PM
Yet another annual story Bob Noel Owning 2 March 21st 05 01:54 AM
