Old, but interesting topic
Old March 30th 07, 07:07 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Old, but interesting topic
Mxsmanic wrote in
Sammy writes:
The issue we were debating was indeed whether or not the scenario was
silly.
No, we were debating whether or not it's possible. And it is
possible.
Assessments of silliness are subjective and have no place here.
If this were considered a significant risk by the risk management
experts of the world, we'd have a standing procedure on what happens
if both pilots are incapacitated just as we have procedures for water
landings etc. I'm not about to ignore the experts and listen to you.
The absence of a procedure doesn't mean that a given procedure won't
work.
How's it better if a non certified ILS ploughs you into the ground.
It is unlikely to do that.
However even then you'd
be wrong because chances are almost 100% it wouldn't be calibrated
well enough.
How great would the error be, exactly?
Yes again, the experts are wrong and you're right.
No, they simply assume that the A380 will be a reality soon, whereas I
do not.
Ahhhhhh so now you are going to change that set in stone FMC
programming are you?
The FMC is not programmed for a notorious approach to begin with.
Another pathetic generalisation. In what part of the world are you
talking?
All of the developed world now.
Yes but it only takes one to kill everyone on board.
One of that gravity is statistically unlikely.
Failures on aircraft aren't one in a million things. They happen
every day.
Even engines can run several hundred thousand hours without a failure.
And jet engine cores run even longer than that.
Too bad the small part of the flight we are talking about is landing.
Take-off is the only relevant part here, and it is already in the past
when the non-pilot takes over. Landing can be automated.
Only in some circumstances.
In the majority of circumstances.
Yes, because many emergencies end in disaster.
Most do not.
and the cluelessness continues..
Bertie
Old March 30th 07, 07:21 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Sammy writes:
Nope I don't think they could have. If they were used doors that lock
electrically rather the mechanically sound rather like a bad choice to
ward off terrorists.
Not only would the methods I've described allow the flight attendant to land,
but in this case the flight attendant also had had pilot training.
Old March 30th 07, 07:24 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Peter Dohm writes:
I did not read anything to suggest that the cockpit door of the Helios 737
was ever locked. Admittedly, I did not see fit to research this incident at
length--and I also am not familiar with Helios procedures.
In the detailed official report, the circumstances of the accident were
reproduced and recorded. It was possible to verify that sounds on the flight
deck included the sound of the cockpit door unlocking (after an electrical
power loss subsequent to flameout of the engines).
The flight deck was locked. The purser presumably had a code with which to
enter the flight deck, but he was unconscious. The people still conscious did
not have the code. They were unable to enter the flight deck until the
engines flamed out due to a lack of fuel, at which point the loss of
electrical power unlocked the cockpit door. By then, however, they were only
a few minutes away from a crash, and they had no power at all.
The Helios case, however, seems much more interesting as an argument against
fully automated passenger carrying aircraft. Presuming that the report was
correct, regarding the outflow valve being left in manual/open; then there
is further reason to suppose that other flight crews may have found and
corrected similar errors before they became incidents or accidents.
As I recall, a leaky door caused gradual depressurization. The flight deck
confused the low pressure alarm with another alarm and ignored it. Soon
thereafter everyone had passed out from hypoxia, including the pilots. A lack
of automation would not have helped.
Old March 30th 07, 07:45 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Sammy writes:
Calibration off by a small tolerance will do that.
How much of a tolerance, exactly?
Great enough that it's considered an unacceptable risk to auto land
unless the equipment is certified.
How great is that, exactly?
I'm sorry. The A380 has landed in Sydney airport. That landing
required the runway to be lengthened. I was unaware that it was a
fictitious aircraft and that everyone is hallucinating it.
It is not in regular service yet, nor has it been delivered in quantity.
That's rubbish. You said the FMC is programmed from the start
(Incorrect, the approach is usually input en-route, but never mind).
The approach can be entered into the FMC at any time. It is also optional.
Now we know that planes do use these notorious approaches.
But notorious appraoches are rare, and it's unlikely one would be programmed
in the scenario under discussion. If it were, and if this risked being a
problem, another one could replace it.
Absolute rubbish. Take a look at a few air crash reports some time.
The crash reports logically address only the cases in which it was enough to
kill everyone on board. The other cases in which it was not do not cause
crashes, and thus do not generate crash reports.
They still fail, particularly when you have many thousands of flights
every day and an aging fleet of aircraft.
They rarely fail.
Landing isn't usually automated.
But it can be, in the scenario under discussion. It would be safer than a
landing flown by hand.
There is no reason to assume that an autoland is programmed in
if a pilot becomes incapacitated.
Since that cannot be done in advance, it certainly would not be programmed in,
but a few presses of a few buttons would fix that.
Most? That's a statistical statement.
Yes. Good.
Want to provide me with stats on
what proportion of declared emergencies end in loss of life for large
aircraft? Any idea at all what the number is?
There were 91 accidents investigated by the NTSB in February. Of these, 23
involved a loss of life. Only a very small fraction of declared emergencies
lead to an accident that is investigated by the NTSB, but essentially all
accidents resulting in loss of life are investigated. Therefore the
percentage of declared emergencies that result in loss of life is very small
indeed.
And when you consider that none of the fatalities occurred on airliners, the
percentage diminishes by at least another order of magnitude.
Look you hold a bunch of truly bizzare opinions and once stated try to
tell people you've provided facts. They're not facts they're
unsubstantiated supposition.
Only if you consider the NTSB reports to be unsubstantiated.
Your world view does not tally with the
majority of accepted evidence, or with what experts report.
I got it from the experts.
If you want me to take you at all seriously you need to provide solid
reference material.
I don't care if you take me seriously or not. And others can look up the data
for themselves.
Old March 30th 07, 10:05 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Iain Smith
"Mxsmanic" wrote in message
And
Not true. One of the longest running jet engines in service on a commercial
airliner was a CFM56 attached to the port wing of an easyJet Boeing 737 a
couple of years ago which had clocked up about 86,000 hours and at that
point had never been removed from the wing. However, that was acknowledged
to be an exception by a large margin.
Iain
Old March 30th 07, 10:46 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Sammy
According to you since the whole thing should have been automated, no
intervention should have been necessary. The flight should have
autolanded safely.
Old March 30th 07, 10:48 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Sammy
On Mar 31, 4:21 am, Mxsmanic wrote:
Sammy writes:
You seem to have some detailed information about this incident. Please
cite your references so we can all argue based on the same facts.
Old March 30th 07, 10:49 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Sammy
On Mar 31, 4:45 am, Mxsmanic wrote:
Sammy writes:
You tell me. You're making the claim that it's good enough. If you're
wrong and people were to do what you say people would die. If I'm
wrong they're inconvenienced. So the burden of proof is on you.
You tell me. You're making the claim that it's good enough. Show me
proof that it's an acceptable risk. You might think you know better
than your local air safety regulators but you don't.
So what you're saying is that you don't believe it will ever be in
service or delivered in any quantity? Quite a bold claim you're
making. Care to tell me based on what evidence/knowledge you're making
that claim?
....and since the approach changes due to conditions at the airport
including weather and traffic, there is no reason for a pilot to
program in an approach so far in advance.
As I've said there's no reason to believe any approach would have been
programmed in yet. Regardless you can just choose another approach.
Unfortunately that means programming it in, which completely
contradicts your little scenario that the entire flight to autoland
has been laid into the computer before takeoff. That just doesn't
happen.
Yes they get filed as incidents. I seem to remember at least one well
documented case of takeoff thrust being calculated incorrectly and
causing a plane (a 747 freighter I think) to crash because the pilot
neglected to double check the weight entered into the FMC. It does
only take one mistake, and it has happened. That's what makes check
lists critical.
They rarely fail.
Rarely is enough when you're talking about tens thousands of flights a
day. That's an excellent argument for giving those pilots all that
extra training you seem to think is unnecessary.
Possibly but it wouldn't have been programmed in from before takeoff.
There's no reason to believe that it would have. Therefore your
inexperienced non-pilot has to learn to follow instructions to enter
the autolanding into the automated systems. Over a radio link there's
a good chance a mistake could be made.
How many presses and what buttons? Does your PMDG addon simulate
autolanding? How accurately does it claim to? How many button presses
are required to select a STAR and enter in an autolanding? What
assumptions must be made about what's already been entered?
Yes. Good.
indeed.
Wow your grasp of stats is even worse than your grasp of aviation.
Incidents in February may not have been fully investigated. One
month's data from one country isn't a large enough sample size to draw
any conclusion. Your data must include a lot of GA aircraft where you
keep harassing me to stick to a very specific scenario dealing only
with a large automated jet.
Your statement doesn't even attempt to answer the question, but
instead answers another. I asked how many declared emergencies ended
in loss of life (since you claim most don't end in anything
catastrophic). Instead of telling me you give me some statistic about
how few fatalities were caused when an emergency had been declared
which. This is a completely irrelevant statistic to our discussion. We
were not discussing anything about fatalities that occurred when no
emergency had been declared. Do you know anything about set theory?
You're dealing with two sets of data with the only overlap being
emergencies declared that did end in loss of life. This is typical of
your style of argument. Complete misdirection, and failure to actually
address questions or counter claims in any meaningful way.
An extrapolation based on a small data set not even relevant to the
discussion. Again typical of your severely flawed logic.
Lets look at the facts shall we? You've taken a small incomplete (too
new to be complete) data set, presented a flawed argument that fails
to address the issue, and tried to force that into fitting your
argument because there is a lack of data. Your analysis is rubbish. If
you do this for a living in any capacity I wonder how many jobs you've
been sacked from.
No, you've demonstrated that you can unconvincingly twist incomplete
data in a flawed an indefensible way to support a nonsense argument.
Pathetic really.
reference material.
for themselves.
Yes they can. Others will probably be more sensible about drawing
conclusions from it that you will. They'll probably take a more
complete less recent data set and actually make an analysis that's
logical and consistent. Something you seem incapable of.
Old March 30th 07, 11:19 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Darkwing
"Peter Dohm" wrote in message
Peter Dohm writes:
737
incident at
flight
electrical
to
conscious
did
only
against
was
there
deck
lack
Google is your friend!
Not even Google will be MX's friend...
DW
Old March 30th 07, 11:37 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Sammy writes:
to ward off terrorists.
to land, but in this case the flight attendant also had had pilot
training.
You are an idiot.
Bertie
Off-topic, but in need of help dennis Aviation Photos 0 January 4th 07 10:40 PM
Almost on topic... Richard Lamb Home Built 22 January 30th 06 06:55 PM
off topic, just a little--maybe? L.D. Home Built 5 August 27th 05 04:56 PM
off topic Randall Robertson Simulators 0 January 2nd 04 01:29 PM
