#11
Compared to a 20k' airplane, even a tsunami would be flat to a first
approximation. Jim "Jon Woellhaf" wrote in message news ![]() Jim, I was going to ask where we'd find that "perfectly flat" ocean, but thought better of it. g Jon |
![]() I was once told that the KY97A is actually an ICOM IC-A200 that is OEM'ed for King with a different faceplate and knobs but the exact same innards. Is this true? Those two radios sure look a lot alike. That's a fact |
![]() No wasn't it those garmmin early gps coms were 6 watts and people had range problems. Now they are 10 or 12 watts. |
Roger wrote:
Actually all I need is to fix the orange/yellow plastic window over the display. Some where in the past (before I purchased the Deb) I'd guess some one used the wrong stuff to try and clean the window. Combined with age that has rendered the plastic window almost opaque. I wonder if the stuff they use to fix scratched plastic glasses would work on that? Trying would certainly be cheaper than purchasing another radio or even front panel. The KY197s are going for as much on E-bay (yellow tagged) as a new KY97. If the plastic window is all that is wrong with it, you're a lucky man. Most old KY-97s have a problem with the LCD display going wacky (particularly when the unit is cold). You have to push on the face of the radio to make it read correctly. This is such a common problem that I'd shy away from a used KY-97, unless I could verify that it was still fairly young. If it's just the window plastic, you could just undo the two screws on each side of the radio that hold the faceplate on. The plastic piece will fall right out. It shouldn't be too hard to find something that'll work in there (or maybe leave it out altogether). Since my display went crazy, I decided to go with an ICOM IC-A200 as a slide-in replacement. Pacific Coast Avionics was selling them for $800. Not bad when you consider the price of a new KY-97A. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200704/1 |
![]() KY97A 5Watt LCD KY197A 10Watt LED Will they both fit the same tray? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger wrote:
KY97A 5Watt LCD KY197A 10Watt LED Will they both fit the same tray? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Yes. My tray is marked both KY-97A and KY-197A. John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
On Wed, 04 Apr 2007 00:42:56 GMT, "JGalban via AviationKB.com"
u32749@uwe wrote: Roger wrote: KY97A 5Watt LCD KY197A 10Watt LED Will they both fit the same tray? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Yes. My tray is marked both KY-97A and KY-197A. John Galban=====N4BQ (PA28-180) Thanks, Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Clear and Amber window for KY197 | Roger | Owning | 5 | June 11th 06 10:56 PM |
Clear and Amber window for KY197 | Roger | Home Built | 5 | June 11th 06 10:56 PM |
What is the difference between... | expresstechonsite | Home Built | 7 | June 5th 06 03:00 PM |
what a difference! | Chris | Piloting | 3 | January 12th 06 11:52 PM |
Anyone know the weight difference? | Lou | Home Built | 4 | January 5th 06 09:33 PM |
