Vapor lock question????
Old April 6th 07, 06:05 AM posted to rec.aviation.homebuilt
jerry wass
Default Vapor lock question????
Bryan Martin wrote:
In article 7044e0f5b02bc@uwe,
"flynrider via AviationKB.com" u32749@uwe wrote:
If you're going to get vapor lock running mogas, spring is probably the
time it'll happen. Oil companies formulate mogas for different seasons.
Winter mogas has a low vapor pressure which allows it to vaporize more easily
in lower temperatures. Summer blends have a higher vapor pressure to resist
vapor lock in warmer temperatures. The problem exists when using a winter
blend of mogas when temperatures have warmed up. If you're going to get
vapor lock, that's when it's most likely to happen.
It's not a problem in cars, since a typical gas station turns over its
stock one or more times a week. It can be a problem if you get your mogas
from an airport. It can take weeks or months to turnover a full load of fuel.
This was a problem with a friend of mine that runs an FBO in the southwest.
He used to have a self-serve mogas pump at his relatively small airport, and
it would take him a couple of months to sell a 2,000 gallon load of it.
Invariably, when the hot weather hit, he would get reports of vapor lock from
pilots who were buying his winter mogas. Eventually, he considered it too
much of a potential liability and shut down the mogas pump.
I think you got that backwards. Mogas is blended for a HIGHER vapor
pressure in Winter than in Summer. High vapor pressure = easier to
vaporize = easier to start your car in the winter.
Bryan Martin
John has it right, Bryan--and your statements are correct also--i.e.
winter gas = high vapor pressure--get winter gs in spring/summer=vapor
lock!! Jerry
Linden Accident - Question about "Droop Lock" Bob Chilcoat Rotorcraft 6 October 6th 05 11:11 AM
Two Lock Rule? Robert M. Gary Piloting 62 June 16th 05 05:00 AM
Cherry Lock Rich Home Built 0 March 20th 05 11:33 PM
Vapor Lock Dale General Aviation 3 August 8th 04 03:50 PM
Ubisoft Lock On. Pilot Pete Simulators 3 January 26th 04 03:54 AM
