I wrote this short article on what I think the problem is, based on
the DG advisory and the photos at segelflug.de: http://www.hpaircraft.com/misc/dg300spars.htm It is only my guess at what the issues are, please view it with some skepticism. Please alert me to any factual errors. Thanks, and best regards Bob K. |
On Fri, 06 Apr 2007 23:34:52 -0700, Marc Ramsey wrote:
You should take a look at this: http://www.dg-flugzeugbau.de/holm-dg300-e.html Marc Just finished reading this and the related thread. This is a nightmare for the affected owners and many others in the industry! However as a suggestion: Would it be possible to determine if any one aircraft has the defect by measuring wing deflection under a known load? From my understanding of the defect, the misaligned fibres would not only reduce the strength of the spar, but also it's stiffness. By measuring the deflection of a sample of wings under load and then opening them up to determine whether they have the defect or not, it might be possible to draw up a non invasive procedure which can be used to determine if the defect exists in a particular aircraft, and if it does, to what extent. Anybody from DG reading this? Ian |
Ian wrote:
On Fri, 06 Apr 2007 23:34:52 -0700, Marc Ramsey wrote: You should take a look at this: http://www.dg-flugzeugbau.de/holm-dg300-e.html Marc Just finished reading this and the related thread. This is a nightmare for the affected owners and many others in the industry! However as a suggestion: Would it be possible to determine if any one aircraft has the defect by measuring wing deflection under a known load? I don't know about your deflection suggestion, but how DG handles this spar-cap situation for all of the DG-300 owners should have a significant bearing on whether, and how much, the market will discount all of their products in the future. A few dollars spent now to shore up what had been a good reputation can pay big dividends. We shall soon see if DG is to remain a desirable marque. Jack |
Are all DG300 certified "experimental" (in the U.S.) ?
PeterK "Ian" wrote in message news ![]() On Fri, 06 Apr 2007 23:34:52 -0700, Marc Ramsey wrote: You should take a look at this: http://www.dg-flugzeugbau.de/holm-dg300-e.html Marc Just finished reading this and the related thread. This is a nightmare for the affected owners and many others in the industry! However as a suggestion: Would it be possible to determine if any one aircraft has the defect by measuring wing deflection under a known load? From my understanding of the defect, the misaligned fibres would not only reduce the strength of the spar, but also it's stiffness. By measuring the deflection of a sample of wings under load and then opening them up to determine whether they have the defect or not, it might be possible to draw up a non invasive procedure which can be used to determine if the defect exists in a particular aircraft, and if it does, to what extent. Anybody from DG reading this? Ian |
Peter wrote:
Are all DG300 certified "experimental" (in the U.S.) ? Yes, but the operating limitations usually (always?) require that they be maintained according to the published factory technical notes... Marc |
I would think an ultrasonic inspection could get
a good enough picture of the undulations to know if it's serious. Problem is what deviation from ideal is acceptable? If anybody knows a glider pilot who is in the USAF they could check with the NDI Lab at their base and see if someone could inspect the spar. Long, long ago I was an AF NDI Technician and we X-Ray'd car batteries, mag particle tested cam and crankshafts and would have jumped at the chance to inspect a glider wing. Nothing they did could be official, but for peace of mind it might be something to try. You might get some new students at your club. I first saw a soaring site when I was stationed at Zweibrucken AB in Germany. |
EASA has now published an emergency AD (saying essentially the same
thing as DG's Tech Note), available at: http://ad.easa.europa.eu/blob/easa_a..._2007-0100-E_1 I know about this only because a friend saw the link on the BGA website. As a long-time DG-300 owner, I am extremely disappointed to have heard NOTHING from Glaser-Dirks about this situation. There is simply no excuse for this. They have all or most owners' e-mail addresses already (for their monthly newsletter). This situation cries out for proactive announcements, explanation, clarification, etc. from the manufacturer. Instead, we are left to scavenge whatever "information" we can (possibly not all accurate) from R.A.S. and other sources. DG did put the Tech Note draft on its website last week but that helps no one unless they know about it or accidentally stumble across it. What is missing is any official notification from the manufacturer. I can abide the limitations required by the AD more easily than I can this pitiable lack of proper communications and support from Glaser-Dirks. Almost two weeks ago, when the R.A.S. thread first appeared, I sent an e-mail inquiry to Glaser-Dirks with copies to the North American dealers. I received no response. No excuse for that, either. |
At 13:18 16 April 2007, Mike Yankee wrote:
EASA has now published an emergency AD (saying essentially the same thing as DG's Tech Note), available at: http://ad.easa.europa.eu/blob/easa_a...orrected.pdf/E AD_2007-0100-E_1 I know about this only because a friend saw the link on the BGA website. As a long-time DG-300 owner, I am extremely disappointed to have heard NOTHING from Glaser-Dirks about this situation. There is simply no excuse for this. that would be because Glaser-Dirks went bankrupt several years ago |
Beech Duke Owners/ex-Owners ple help... | Stanley | Owning | 12 | June 10th 16 12:36 AM |
SHK Owners | [email protected] | Soaring | 1 | February 7th 06 06:37 PM |
R22 owners please help with AD 2004-06-52 | rotortrash | Rotorcraft | 20 | April 28th 04 04:33 PM |
ASW20 owners | Andrew Henderson | Soaring | 0 | April 10th 04 12:28 PM |
Any UH-1 owners in here? | Jim | Rotorcraft | 7 | October 6th 03 02:33 AM |
