#11
On Apr 9, 10:40 am, "Snowbird" wrote:
"Mxsmanic" wrote ... Can someone tell me why vacuum power is popular for certain instruments? Historical. Aircraft electrics tended to be a) more unreliable than today and b) add unnecessary weight. Of course, one shouldn't forget that a usable vacuum "supply" was available without a pump when an external venturi was installed. |
available without a pump when an external venturi was installed. I was wondering how long it was going to take for someone to divulge the REAL reason for vacuum instruments. External venturi tubes were the only form of energy available to drive gyros on airplanes in the 30'3 and 40's which had no electrical systems. After WW2 here were so many vacuum instruments out there nobody had the courage to change. Rod |
Aircraft of old use venturies mounted on the fuselage to
power vacuum gyros. They were fairly reliable and did not require any source of electrical power. The disadvantage was that the AC had to be moving before the gyros would spin up. Later on vacuum pumps replaced the venturies for more consistant vacuum, but one could argue the reliability over a venturi... other than icing up perhaps. The advantage of Vacuum instruments is that you could still have a venturi as a backup vacuum source in case the pump failed. Alternatively you could use some manifold pressure (vacuum) as a backup source. Until recently electrical instruments and electrical systems were not considered as reliable. Nowadays you can easily have battery backed up electrical gyros. Either way, if a gyro-power source fails there are systems that can immediately identify that fact to the pilot. The gyros of course would spin down slowly and without some immediate way to alert the pilot hwe my get erronious information until the fail in an apparent way. Usually, a gyro will show signs of needing a rebuild before is actually "fails" such as slow to spin up/recet, excessive precession, etc., but not always. |
ktbr writes:
The advantage of Vacuum instruments is that you could still have a venturi as a backup vacuum source in case the pump failed. Alternatively you could use some manifold pressure (vacuum) as a backup source. Why not use manifold vacuum as the primary source, instead of a separate vacuum pump that provides an additional point of failure? The manifold vacuum would be there as long as the engine were running, without the need to rely on a pump. Usually, a gyro will show signs of needing a rebuild before is actually "fails" such as slow to spin up/recet, excessive precession, etc., but not always. What type of bearings do the gyros use, and how long do the bearings last? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: Can someone tell me why vacuum power is popular for certain instruments? I cannot see any special reliability of a vacuum pump as opposed to an electric motor. Of course you can't Bertie |
Mxsmanic wrote in
: Robert M. Gary writes: If I tell you are you going to tell me I'm wrong?? If it conflicts with other information I have, I may question it, but I don't have much other information. If it sounds odd I may ask for further explanation. Send me fifty bucks and I'll explain it to oyu. bertie |
"rod" wrote in
: Of course, one shouldn't forget that a usable vacuum "supply" was available without a pump when an external venturi was installed. I was wondering how long it was going to take for someone to divulge the REAL reason for vacuum instruments. External venturi tubes were the only form of energy available to drive gyros on airplanes in the 30'3 and 40's which had no electrical systems. After WW2 here were so many vacuum instruments out there nobody had the courage to change. No, actualy, that's not it. Bertie |
Mxsmanic wrote in
: ktbr writes: The advantage of Vacuum instruments is that you could still have a venturi as a backup vacuum source in case the pump failed. Alternatively you could use some manifold pressure (vacuum) as a backup source. Why not use manifold vacuum as the primary source, instead of a separate vacuum pump that provides an additional point of failure? God you;'re an idiot. No wonder you can't fly. Bertie |
Mxsmanic wrote:
Why not use manifold vacuum as the primary source, instead of a separate vacuum pump that provides an additional point of failure? The manifold vacuum would be there as long as the engine were running, without the need to rely on a pump. It sounds like a free lunch doesn't it? :^O Well, tt works in a pinch of course, but having to maintain a power setting that produces a manifold pressure difference (between MP and outside static pressure) just so that the gyros can spin sort of limits your flexibility. |
kontiki writes:
It sounds like a free lunch doesn't it? :^O Well, tt works in a pinch of course, but having to maintain a power setting that produces a manifold pressure difference (between MP and outside static pressure) just so that the gyros can spin sort of limits your flexibility. Yes. I guess I got confused, thinking there would always be vacuum available from the engine. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Wet vs Dry Vacuum Pump | Fastglasair | Owning | 7 | December 17th 04 11:46 PM |
Wet Vacuum Pump | smackey | Owning | 6 | February 24th 04 07:03 PM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
