#11
Jose wrote:
What's your home airport? I'm at Danbury, you too? Home of the coolest approach in CT on 35. G |
Jim Jones wrote:
I went up today to practice crosswind landings. The wind was about down the runway at my home airport so I went to Sky Manor (N40). This airport has a 2500x50 foot runway and requires vigilence in gusty winds. I did 2 landings and 1 go around (due to the gusty wind) using runway 25 at Sky Manor with a 90 degree crosswind of about 12-15 knots gusting to about 18-20kt. The landings here were pretty good. What aircraft were you flying? What is its max crosswind component? Congratulations on taking on crosswinds for practice; on handling the scary situation back home. Well done. |
EridanMan wrote:
The situation you describe strikes me as being a very clear diversion scenario. In the absence of that option, my instructor suggested that (at least in my stout-legged PA-28) in an emergency, during a heavy, gusty crosswind beyond the aircraft's rudder capacity, your best bet is simply to go with the "crab-plant' approach, and associated repair bills. I in no way vouch for this approach, I'm just relaying what I was told. That's probably a good thing, because the bills associated with such an approach could very well be a large part of the aircraft's total value. The PA-28 may have stout legs, but they are not designed to handle a large sideloads. I have seen this attempted in another stout legged Piper and the result was a main gear leg that departed and ripped off the horizontal stabilzer on it's way. Even Cessnas, with their sturdier spring steel gear, can get in trouble with sideloads on the main gear. Go to this page and scroll to the bottom for an illustration: http://members.cox.net/jgalban/id60.htm John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200704/1 |
Hehe, please note I said 'exhausted all other options', as in, your
out of fuel and you need to get on the ground now, this runway, this attempt ![]() In that case, the associated repairs bills of ripping the gear off but almost assuredly living are a probably a better bet than trying some uber-crosswind landing, and either stalling out due to windshear, wing striking, or otherwise loosing control on short final. At least planting in a crab, you're on the ground when the **** hits the fan ![]() |
Whoops, wrong account - the above was me.
") in an emergency, during a heavy, gusty crosswind beyond the aircraft's rudder capacity, your best bet is simply to go with the "crab-plant' approach, and associated repair bills. Lots of people bad mouth the Ercoupe as a sissy airplane. Yet it is landed in a crab. Makes any crosswind landing a no brainer. I owned one for a number of years and only checked the windsock to make sure I wasn't landing against the traffic flow. :-) Now I have to check the wind sock again. Cheers: Paul N1431A |
"Tri-Pacer" wrote Lots of people bad mouth the Ercoupe as a sissy airplane. Yet it is landed in a crab. Makes any crosswind landing a no brainer. I owned one for a number of years and only checked the windsock to make sure I wasn't landing against the traffic flow. :-) Now I have to check the wind sock again. Does the main gear caster on those? I think I heard that it does, but I have no confirmation of that. -- Jim in NC |
On Fri, 13 Apr 2007 13:46:28 -0400, "Morgans"
wrote in : Does the main gear caster on those? I think I heard that it does, but I have no confirmation of that. I don't think so. It's a trailing link design IIRC. |
"Morgans" wrote in message ... : : "Tri-Pacer" wrote : : Lots of people bad mouth the Ercoupe as a sissy airplane. Yet it is landed : in a crab. Makes any crosswind landing a no brainer. I owned one for a : number of years and only checked the windsock to make sure I wasn't : landing against the traffic flow. :-) : : Now I have to check the wind sock again. : : Does the main gear caster on those? I think I heard that it does, but I : have no confirmation of that. : -- : Jim in NC : No |
| Thread Tools | |
| Display Modes | |
| ++NEW++3 DVD SET 'ON LANDINGS' +Much More | Pilot Publications | Products | 0 | June 26th 04 04:42 PM |
| ++NEW++3 DVD SET 'ON LANDINGS' +Much More | Pilot Publications | General Aviation | 0 | June 26th 04 04:42 PM |
| ++NEW++3 DVD SET 'ON LANDINGS' +Much More | Pilot Publications | Aviation Marketplace | 0 | June 26th 04 04:42 PM |
| Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 07:38 AM |
| off airport landings | Stan Gosnell | Rotorcraft | 8 | September 13th 03 05:49 PM |
