Question to Mxmanic
Old April 13th 07, 08:04 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Question to Mxmanic
Little Endian writes:
Ok. So its much less realistic than I thought because wake turbulence
avoidance is a very important concern for real pilots.
True, but it's not something that requires practice. In real life, you simply
take care to avoid wake turbulence; in the sim, you can take the same
precautions if you wish, but you don't have to.
Old April 14th 07, 06:45 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip
On Apr 13, 8:04 am, Mxsmanic wrote:
Snowbird writes:
How does MS flight simulator simulate the symptoms of hypoxia?
No provision is made for simulation of hypoxia of altitude. If the aircraft
is accelerated, the simulator does simulate the visual effects of positive and
negative Gs.
No it doesn´t you moron.
Bertie
Old April 14th 07, 06:53 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
Snowbird writes:
aircraft
and
negative Gs.
The VISUAL effects of positive and negative Gs. Priceless!
Lay off the simulated hypoxia sauce, you moron. You need to loose some
simiulated altitude real fast.
Old April 15th 07, 08:18 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Maxwell writes:
Vision goes first when a pilot experiences positive Gs. It goes dark. The
simulator darkens the screen when this happens.
The simulator does the same for redouts with negative Gs. The first time I
saw it, it took a while to figure out what it was. It only happens in
high-performance aircraft such as the Extra 300s, because small GA aircraft
and jetliners simply can't reach those accelerations without breaking up.
Old April 15th 07, 01:34 PM posted to rec.aviation.piloting,rec.aviation.student,alt.disasters.aviation
Bertie the Bunyip
On Apr 15, 9:18 am, Mxsmanic wrote:
Maxwell writes:
Yes, they can, fjukkwit.
Wrong again..
Don´t you ever get tired of being wrong?
Bertie
Old April 13th 07, 10:45 AM posted to rec.aviation.piloting,rec.aviation.student
buttman
HUUUUURRRRRR
Old April 13th 07, 03:35 PM posted to rec.aviation.piloting,rec.aviation.student
karl gruber[_1_]
Half a bottle of Jack Daniel's
"Curator"
"Snowbird" wrote in message
.fi...
Old April 13th 07, 03:36 PM posted to rec.aviation.piloting,rec.aviation.student
Matt Barrow[_4_]
"karl gruber" wrote in message
Wimp!!
"Curator"
.fi...
Old April 14th 07, 02:40 AM posted to rec.aviation.piloting,rec.aviation.student
george
On Apr 14, 2:36 am, "Matt Barrow"
Wimp!!
He meant the bottom half.
After he'd drank the top half to get to it :-)
Old April 13th 07, 09:09 PM posted to rec.aviation.piloting,rec.aviation.student
Jay Honeck
How does MS flight simulator simulate the symptoms of hypoxia?- Hide quoted text -
It's funny you should say that. I have flown our MSFS-based "Kiwi"
flight simulator
(see it he http://www.alexisparkinn.com/flight_simulator.htm ) at
the end of a very long day, after consuming three 16-ounce Sprecher
Ambers (within the span of a 114-minute movie), and can vouch for the
fact that alcohol is a pretty good mild hypoxia simulator.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
