IFR GNS 430 with expired database
Old April 17th 07, 02:01 AM posted to rec.aviation.ifr
Dave S
Default IFR GNS 430 with expired database
Peter Clark wrote:
On 16 Apr 2007 07:11:13 -0700, "paul kgyy"
There might be restrictions for GPS approaches, but I would think that
flying non-GPS approaches with the 430 should be fine since you're not
really using the database.
What about using it for locating missed approach holding points (a-la
NDB or DME substitution)? Since the database is out of date, you
can't use it for approaches, even non-GPS.
Yes.. you can.
If you can fly a plain ILS, LOC or VOR approach, you can use a 430
without a current database. You can still confirm cross radials and such
without an IFR GPS.
Dave
Old April 17th 07, 06:06 AM posted to rec.aviation.ifr
Yes.. you can.
Indeed. The usual verbiage is
"IFR enroute and terminal navigation is prohibited unless the pilot
verifies the currency of the data base or verifies each selected
waypoint for accuracy by reference to current approved data."
NDB and DME substitution on non-GPS missed approaches is a terminal
operation.
Old April 17th 07, 04:03 PM posted to rec.aviation.ifr
Paul kgyy
It depends on the HP - often it's a return to the OM using a
backcourse, or a nearby VOR, or intersection of 2 VOR radials. None
of these requires the database. Even an NDB would work if you have
ADF on board.
Old April 17th 07, 04:50 PM posted to rec.aviation.ifr
Al G[_1_]
"Dave S" wrote in message
k.net...
Jose wrote:
I have been told that it is illegal to fly IFR in an aircraft that has an
operating IFR rated GNS 430, whose database is out of date, =even= if it
is placarded INOP, placed in the OFF position, and the airplane, even
without the 430, is otherwise legal for IFR.
True?
Jose
You've been told wrong. You can still fly ILS, LOC and VOR approaches
without regard to the status of the GPS database. You can even use the out
of date database for situational awareness. You just cant file /G, since
you are not capable of legally accepting or executing an IFR GPS approach,
assuming that the out of date box is the sole source of IFR GPS
certification.
Dave
That's how I understand it, and how it is explained by Jeppesen. You
can't file /G with an expired database.
Al G
Old April 17th 07, 05:04 PM posted to rec.aviation.ifr
ADF on board
From the Garmin manual: ( I have similar verbiage in my AFM
supplement. Yours could conceivably differ.)
"You may file your flightplan as /G if your GNS430 is a certified A1
(approach approved) or A2 (enroute and terminal only) installation. If
you are flying enroute, you may file /G with an expired database only
after you have verified all route waypoints. Non-precision approaches
may not be flown with an expired database. See your approved Airplane
Flight Manual for more information."
So to comment on an earlier point, you can still file /G, even with
an expired database, under the restrictions pointed out earlier. Note
you can file /G with a C129(A2) installation for which approaches are
never approved!
It's hard to imagine anyone thinking an expired GPS database would
prevent you from using the *other* navigational equipment in your
airplane - like an ADF or the independent VOR/ILS in the 430.
Old April 17th 07, 06:27 PM posted to rec.aviation.ifr
Jose
I don't think anyone does,
Actually, somebody influential in our club does think this.
Jose
Get high on gasoline: fly an airplane.
Old April 17th 07, 08:46 PM posted to rec.aviation.ifr
Bob Gardner
"Jose" wrote in message
t...
operating IFR rated GNS 430, whose database is out of date, =even= if it is
placarded INOP, placed in the OFF position, and the airplane, even without
True?
Jose
Jose, let me repeat what I have said many times: When you are told something
like this, ask for documentation. There are far too many pilots who are
willing to swallow a story whole without question, and far too many
instructors who simply pass on what they have been told by someone else.
Bob Gardner
Old April 17th 07, 10:10 PM posted to rec.aviation.ifr
On Apr 17, 10:18 am, Peter Clark
I don't think anyone does, except in the cases where you are required
to substitute because you don't have an ADF or DME and the precision
or VOR/DME style approach requires the GPS be used as a substitute for
ADF or DME. AIUI at that point you have to have the real equipment or
a current database.
Yes and no. To use the GPS to substitute for DME on a VOR-DME
approach is an approach operation. It requires a C129(A1) certified
box with a current database. However, if the *missed approach*
requires say, for you to navigate to an NDB for which you are
substituting GPS, that is a terminal operation which only requires
C129(A2) certification and can be flown with an expired database,
provided you have validated the NDB lat/lon.
Earlier in the thread you specified substituting GPS for the MAPH
HP. That is the second situation.
Old April 17th 07, 10:39 PM posted to rec.aviation.ifr
Peter Clark
a current database.
I don't have my supplements or manuals handy, but does that apply even
if the NDB blah is loaded as part of the approach procedure?
396/496 database ? karl gruber[_1_] Piloting 0 April 12th 07 06:24 PM
expired articles?? Off Topic... Gary Emerson Soaring 2 February 21st 07 06:11 AM
Expired helicopter parts. John Rotorcraft 7 December 10th 04 05:19 AM
Expired WAC Charts AXA General Aviation 2 December 19th 03 08:56 PM
Expired WAC Charts AXA Piloting 2 December 19th 03 08:56 PM
