Grob Astir AD spar spigots
Old April 20th 07, 07:34 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Grob Astir AD spar spigots
On Apr 20, 7:44 am, wrote:
I saw a reference to a repair team in one of Bob Kuykendall's posts, a
team that did the 103's, but I suppose those were Grob guys Bob?
Gosh, it's been like a dozen years, I don't remember that much about
it. But as I recall it, it _was_ a team sent around by Grob, they'd
lined up several aircraft each at several shops around the country and
did a grand tour. I saw them briefly, I think at Steve Brown's Bay
Area Composite Repair.
As I recall the repair involved cutting through the spar stub shear
web to liberate the chunks of plywood to which the spigot was bolted
or riveted, leaving an ugly rectangular notch at the end of the stub
but not removing material from the spar caps. The beefier replacement
spigot and its support (probably plywood, but perhaps prefabbed
fiberglass plate, I don't recall) was placed into this notch, aligned
with a fixture that the team had brought with them, and floxed into
position. After the flox cured, the spigot and its support was secured
with several shear wraps of cloth. I don't recall if they ground away
the original shear wraps; they might have done so to keep the spar
stub within its original envelope.
As an aside, this series of repairs is one of the events where I first
started to comprehend that there's no particular magic to composite
aircraft structure. I remember spending quite a while looking at one
of the cut-open aircraft under repair after the guys had knocked off
for the day. I don't remember much of what I saw, but I do remember
thinking "What, is this all there is?" Of course, there's a lot of
careful engineering to it, engineering that I'm not qualified to
practice or for some of it to even understand. But I think that a lot
of it is just a mix of common sense plus stuff that people tried and
tested and found to work sufficiently, and the engineering came later
to figure out _why_ it worked.
Thanks, Bob K.
Old April 20th 07, 08:49 PM posted to rec.aviation.soaring
Werner Schmidt
Hello Stephen,
FYI - An AD for this issue was put out in Canada many years ago
(February 1991)!
looking at grob.aerospace.de I found this document:
http://www.grob-aerospace.net/filead...SB_Summary.pdf
And searching this document I found:
11.10.90
Überprüfung und Austausch der Holmstummelbolzen
Inspection and replacement of spar spigot assemblies
ASTIR CS, ASTIR CS 77, ASTIR JEANS, STANDARD II, CLUB II, CLUB III,
STANDARD III, CLUB IIIb
alle Werk-Nr. / all S/N
regards
Werner
Old April 21st 07, 01:20 AM posted to rec.aviation.soaring
JJ Sinclair
Todd,
The work must be done in a FAA certifid glider repair station, like
John Murry's or Gehrlein in your neck of the woods. it involves about
20 hours of work + the cost of the kit from Grob. It involves
assembling the ship with wax donuts on the old spigots to determine
the excess lateral slop that must be removed when the new spigots are
installed, then grind and remove the old, then fit the new with
factory jig, scarf spar but and lay up 8 layers of 92125 for the
replacement spar wrap. I would estimat $1800 to $2400 bucks.
JJ
Old April 22nd 07, 06:25 PM posted to rec.aviation.soaring
Brad[_2_]
JJ,
Would Rutan style 7725 be a similar cloth to the 92125 European cloth?
Brad
On Apr 20, 5:20 pm, JJ Sinclair wrote:
Todd,
JJ
Old April 22nd 07, 09:25 PM posted to rec.aviation.soaring
JJ Sinclair
On Apr 22, 10:25 am, Brad wrote:
JJ,
Brad
Yep, but when working with certified aircraft like the 102, one must
use the specified stuff. The kit I got from Grob had per-cut 92125
sections, everything but resin...............BTW, Williams Soaring
(Rex) just got 50 gallons of L285 epoxy at half the price that Spruce
& Seciality is getting.
JJ
Old April 23rd 07, 04:46 PM posted to rec.aviation.soaring
toad
JJ,
Thanks a lot for this information.
It was a factory supplied jig that was used for the replacement ?
Todd
On Apr 20, 8:20 pm, JJ Sinclair wrote:
Todd,
JJ
Old April 23rd 07, 05:07 PM posted to rec.aviation.soaring
dforrest
On Apr 23, 8:46 am, toad wrote:
JJ,
Todd
Todd,
JJ
Todd, Did you happen to notice the 3/21/05 response date on the
Airworthiness Concern Statement?
Old April 23rd 07, 06:11 PM posted to rec.aviation.soaring
toad
Yes, at least after it was pointed out :-) I think that there might
be a typo. The real deadline for comments in May 11th, I think.
Todd
Old April 24th 07, 05:01 AM posted to rec.aviation.soaring
Todd
Correct, 5/11/2007 is the deadline for comments into the AOPA.
Old May 19th 07, 07:01 AM posted to rec.aviation.soaring
Roger Worden
What the heck is a spar spigot?
Grob Twin Astir Tailshaking Peter Soaring 11 January 14th 07 11:54 PM
FS: Grob G104 Speed Astir II B KO Soaring 0 March 30th 06 12:09 AM
FS - Grob Speed Astir IIB Fred Soaring 3 February 18th 06 03:22 PM
FS - Grob Speed Astir IIB Steve Leonard Soaring 0 February 17th 06 03:42 AM
Grob Twin Astir 1 Manual / Flughandbuch Sebastian Schroeter Soaring 2 June 14th 04 11:41 AM
