Karl-Heinz Kuenzel wrote:
I did not believe it either. Maybe I am getting to old. For me a diesel would run forever until you cut the fuel. not with a common rail fuel supply. The injectors won't open without power. The main point as far as I'm concerned is, that this is not a particular problem of the thielert or aerodiesels in general, it's a problem you get with engines depending on electrical power. This dependancy on electricity is somehow the price you pay for better fuel efficiency, more comfort and, as far as the engine itself is concerned, less "finger problems" and therefore more reliability. As the article itself states, it is not a big issue to create a redundant system that will eliminate the risk of a single point electrical failure shutting down an engine, let alone both. What those people did. They just started #1 and #2 (which was NOT ok) on external power. And everything looked ok. Until they retracted the landing gear.... I posted that story in our German newsgroup and nobody seemed to be interested in that issue. I was just curious, if someone here is interested. I'm not a pilot, though I enjoy flying in small aircraft and I have some technical interest in aviation. As a development engineer in automotive I particularly like to learn about aeroengines and I somewhat follow the development of the aerodiesels. I'm mainly lurking here... regards, Friedrich |
Recently, Friedrich Ostertag posted:
Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. Regards, Neil |
On Apr 23, 12:51 pm, "Neil Gould" wrote:
Recently, Friedrich Ostertag posted: Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. Regards, Neil I just received an e-mail today from Diamond explaining the situation. Since the engines are FADEC controlled, the dead battery did not have enough power to retract the landing gear and keep the engines going. The e-mail also stated that Diamond is looking into making some changes. Cary (DA42 owner) |
Recently, Cary posted:
I just received an e-mail today from Diamond explaining the situation. Since the engines are FADEC controlled, the dead battery did not have enough power to retract the landing gear and keep the engines going. The e-mail also stated that Diamond is looking into making some changes. Cary (DA42 owner) The actual wording of that email would be interesting. I'd think that the FADEC keeps the fuel flow and props configured, and that the current draw of the landing gear motor(s) probably shut the FADEC down due to low voltage. While that could be addressed with a different power configuration (a separate battery for the FADEC, for example), it may also introduce more failure modes and more factors to take into consideration during pre-flight. Neil (NOT a DA42 owner) |
"Neil Gould" wrote in message
.. . Recently, Cary posted: I just received an e-mail today from Diamond explaining the situation. Since the engines are FADEC controlled, the dead battery did not have enough power to retract the landing gear and keep the engines going. The e-mail also stated that Diamond is looking into making some changes. Cary (DA42 owner) The actual wording of that email would be interesting. I'd think that the FADEC keeps the fuel flow and props configured, and that the current draw of the landing gear motor(s) probably shut the FADEC down due to low voltage. While that could be addressed with a different power configuration (a separate battery for the FADEC, for example), it may also introduce more failure modes and more factors to take into consideration during pre-flight. Neil (NOT a DA42 owner) I have to admit that I am a little surprised that (or if) they did not include a little magneto/generator in/on each engine, sufficient to power the FADEC and pumps, to prevent the sort of incident described. OTOH, I am trying to remember whether larger aircraft systems behave in a similar way, and I must admit that I do not recall. In any case, it is very interesting and most unfortunate for those involved, and we will all know a lot more is the investigation progresses; and a lot of what we learn will be equally applicable to FADEC equipped spark ignition engines. It will obviously be worth the effort, over the longer term, since fuel savings translate readily into payload and range--which is usually worth more than the fuel savings. Peter |
The message came as a PDF file. I don't think I can post such a file
to the newsgroup, so if you would like to see the file, let me know where to send it. Cary On Apr 23, 1:28 pm, "Neil Gould" wrote: Recently, Cary posted: I just received an e-mail today from Diamond explaining the situation. Since the engines are FADEC controlled, the dead battery did not have enough power to retract the landing gear and keep the engines going. The e-mail also stated that Diamond is looking into making some changes. Cary (DA42 owner) The actual wording of that email would be interesting. I'd think that the FADEC keeps the fuel flow and props configured, and that the current draw of the landing gear motor(s) probably shut the FADEC down due to low voltage. While that could be addressed with a different power configuration (a separate battery for the FADEC, for example), it may also introduce more failure modes and more factors to take into consideration during pre-flight. Neil (NOT a DA42 owner) |
Neil Gould schrieb:
Recently, Friedrich Ostertag posted: Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. Regards, Neil OK Neil. You find it in the article. POH - Under - abnormal operating procedures - 4B.7 STARTING ENGINE WITH EXTERNAL POWER - #13 Opposite engine ..... START WITH NORMAL PROCEDURE That is it. Karl |
Recently, Karl-Heinz Kuenzel posted:
Neil Gould schrieb: I have a somewhat different take on this event. [...] I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. OK Neil. You find it in the article. My Deutsch is far too rusty to find it in the article. ;-) POH - Under - abnormal operating procedures - 4B.7 STARTING ENGINE WITH EXTERNAL POWER - #13 Opposite engine ..... START WITH NORMAL PROCEDURE That is it. That's fine for starting the engines, but that isn't the only issue, is it? Is there nothing in the POH about the electrically powered items (landing gear, FADEC, etc.)? If there is, it shouldn't require an EE degree to realize that one should be concerned about the condition of the batteries, charging, etc. if one has to "jump start" the engine, or to realize that something critical is in need of attention. Maybe I'm just an overly cautious type. ;-) Neil |
Neil Gould wrote:
Recently, Karl-Heinz Kuenzel posted: Neil Gould schrieb: I have a somewhat different take on this event. [...] I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. OK Neil. You find it in the article. My Deutsch is far too rusty to find it in the article. ;-) POH - Under - abnormal operating procedures - 4B.7 STARTING ENGINE WITH EXTERNAL POWER - #13 Opposite engine ..... START WITH NORMAL PROCEDURE That is it. That's fine for starting the engines, but that isn't the only issue, is it? Is there nothing in the POH about the electrically powered items (landing gear, FADEC, etc.)? If there is, it shouldn't require an EE degree to realize that one should be concerned about the condition of the batteries, charging, etc. if one has to "jump start" the engine, or to realize that something critical is in need of attention. Maybe I'm just an overly cautious type. ;-) Neil I agree that if you are flying what is basically an all electric aircraft and you have an electrical problem on the ground that you should take extra care before flight BUT, there should be some system in place that doesn't allow the gear switch, landing lights or any other electrically operated item to become an OFF switch with out some damn significant warning. |
On 2007-04-23 11:20:24 -0700, "Neil Gould" said:
Recently, Karl-Heinz Kuenzel posted: Neil Gould schrieb: I have a somewhat different take on this event. [...] I don't find it surprising that the props feathered in this situation, and would even say that it would be the expected behavior, rather than a fluke of some kind. I would find it surprising if Diamond doesn't have adequate information about their flight systems in the POH to inform the pilot of this possibility. OK Neil. You find it in the article. My Deutsch is far too rusty to find it in the article. ;-) POH - Under - abnormal operating procedures - 4B.7 STARTING ENGINE WITH EXTERNAL POWER - #13 Opposite engine ..... START WITH NORMAL PROCEDURE That is it. That's fine for starting the engines, but that isn't the only issue, is it? Is there nothing in the POH about the electrically powered items (landing gear, FADEC, etc.)? If there is, it shouldn't require an EE degree to realize that one should be concerned about the condition of the batteries, charging, etc. if one has to "jump start" the engine, or to realize that something critical is in need of attention. Maybe I'm just an overly cautious type. ;-) Neil No, you are not overly cautious. Every pilot should be taught that if the battery is dead and you start the plane with external power, the first thing you check is to see if the alternator(s) is charging. If it isn't, either the alternator is broken or the battery did not excite the alternator. Now, if the excitation system did not excite the alternator, why didn't the remote starting system do it? It should have. I would want a look at the power cart, its cables, and the wiring to the port on the airplane. In fact, especially the latter, as it could provide a clue as to why the excitation battery died in the first place. -- Waddling Eagle World Famous Flight Instructor |
F6F accident | Larry Cauble | Naval Aviation | 4 | October 14th 05 06:19 PM |
Accident db? | [email protected] | Owning | 3 | July 25th 05 06:22 PM |
C-130 accident | Jay Honeck | Piloting | 28 | January 11th 05 06:52 PM |
MU2 accident | Big John | Piloting | 16 | April 13th 04 03:58 AM |
KC-135 accident | Big John | Piloting | 3 | November 19th 03 04:36 PM |
