Have you considered building the Skypup? Granted it's an ultralight,
but it has the advantages that it is simple to construct (wood, foam, fabric), it will likely be finished in the course of the students tenure at the school, and with a minimum of flight time can actually be flown. Disadvantages are few, it is not a kit, but is built strictly from plans and it has limited flight opportunities as it must be flown in light winds. Roger On Apr 25, 8:35 pm, Anthony W wrote: Have you considered the Rag Wing Aviation Storch? It's all wood and is supposed to be rather simple to build Also it's a 2 seater so you could take a students for a ride in the plane they helped build. Tony Andrew wrote: Dear Aviation Enthusiasts, I teach math in an inner city high school in Southern Illinois. I've been studying airplane projects to build myself alone but also have thought about forming a high school aviation club to build an SNIP |
You might want to check out a couple of the following:
EAA used to have something in their education division called "school flight". Give them a call. Kit Plane magazine carried a coupe of series about school kids building planes. One was a special ed group that built a 5151. Another was about Dr. Ben Milsbaugh of Colorado that put together a Fischer Celebrety at his high school in conjunction with his involvement as the head of the Rocky Mt division of the CAP aerospace education program. He used to have seminars at the AF academy in Colorado Springs for teachers and was a great inspiration and driving force in getting aerospace ed into the classroom (prior to the NCLB fiasco that has reduced classrooms into "teach to the test" process that has eliminated real world learning). Get a copy of "Plane Crazy" and watch what happens to someone who bites off more than they can chew. Keep it simple so the kids can see progress in short periods of time. Fisher products, Loehle stuff, maybe a KR2, Pietenpol, Teenie Two if you can get plans, Sonex, or restore a classic/antique. I got half way through a Baby Lakes before the upper administration found out and had to take it home. Funny. An Aviation Science class with an airplane? The building principal thought it was cool. School lawyer had problems with it. Check with admin first. |
Andrew wrote:
Dear Aviation Enthusiasts, I knew I'd seen this way back on the Zenith website but I couldn't find it until just now. They have a section for building aircraft as a school project. You may have already found it but here it is. http://zenithair.com/misc/school/project.html |
On 24 Apr 2007 17:08:13 -0700, Andrew wrote:
Dear Aviation Enthusiasts, I teach math in an inner city high school in Southern Illinois. I've been studying airplane projects to build myself alone but also have thought about forming a high school aviation club to build an airplane. There is at least one one high school building the Zenith 701 and Aircraft Spruce donated a Stolp Starduster kit to another high school. The airplanes that I have researched and would like to build myself include the following: Wittman Tailwind and Buttercup, Long-EZ, Cozy Mark IV, KR-2, Christavia, Sonex Vision, Bearhawk, Zenair Zodiac, Zenair 601 and Zenair 701, Thorpe T-18 , BD-4, and the Falconar to name a few. Many of these at some point I've convinced myself, "that's the airplane for me" and just before ordering the plans.....I change my mind. I've been studying homebuilt airplanes for a couple of years now and there probably isn't a homebuilt design that I haven't read about. I know the least about wooden airplanes but wouldn't exclude this type of building material in my choice. I've talked with the welding department at the high school and the instructor said he'd help weld a 4130 fuselage as they have a tig welder. Keep in mind though the idea that this is a group high school project. I'm not sure which type of project that would afford an opportunity for high school students (rather unskilled) to get involved with, to contribute to by using their hands. For example with a wooden wing, probably each student could make a rib for the wings. With an aluminum airplane students also each could make an aluminum rib, the type that are formed around a wooden template with a mallet. It seems like mistakes on a rib wouldn't affect a huge component and quality control could be managed. Ruin a rib, toss it aside and try again. I'm not sure if a mistake in welding a 4130 tube fuselage could be corrected easily. Basically you want students to contribute with simple tasks where mistakes could be fixed without costing too much. With an aluminum airplane students could drill holes, deburr and rivet. I'm not sure how easily mistakes in aluminum can be repaired, say someone who dents the skin when riveting. How do you fix a mistake on an aluminum skin, say someone drills some holes wrong? Can they be filled? Composite construction involves dangerous chemicals which wouldn't bother me as I used to be in the chemical and fume rich electroplating business, but you don't want students breaking out in rashes. However, on a composite airplane there might be opportunity for students to perform the labor intensive sanding, sanding and sanding. So the basic 2 questions are 1) Which type of airplane building method would provide the most opportunity for unskilled high school students to learn and contribute to .......aluminum, tube and fabric, composite or wood. 2) Based on your choice in #1 which specific airplane then would be the best candidate to build? Our high school is known as the East St. Louis "Flyers" being influenced by a close proximity to St. Louis made famous by Charles Lindbergh and the "Spirit of St. Louis Airplane." Thanks, Andrew Good on you for being interested in doing more than the minimum. You might want to check out the murphy Rebel kit. Murphy used to and may still offer kits to school groups at cost or less. Drew Dalgleish Murphy Rebel # 247 C-FHO |
On Apr 28, 8:38 am, (Drew Dalgleish)
wrote: On 24 Apr 2007 17:08:13 -0700, Andrew wrote: Dear Aviation Enthusiasts, I teach math in an inner city high school in Southern Illinois. I've been studying airplane projects to build myself alone but also have thought about forming a high school aviation club to build an airplane. There is at least one one high school building the Zenith 701 and Aircraft Spruce donated a Stolp Starduster kit to another high school. The airplanes that I have researched and would like to build myself include the following: Wittman Tailwind and Buttercup, Long-EZ, Cozy Mark IV, KR-2, Christavia, Sonex Vision, Bearhawk, Zenair Zodiac, Zenair 601 and Zenair 701, Thorpe T-18 , BD-4, and the Falconar to name a few. Many of these at some point I've convinced myself, "that's the airplane for me" and just before ordering the plans.....I change my mind. I've been studying homebuilt airplanes for a couple of years now and there probably isn't a homebuilt design that I haven't read about. I know the least about wooden airplanes but wouldn't exclude this type of building material in my choice. I've talked with the welding department at the high school and the instructor said he'd help weld a 4130 fuselage as they have a tig welder. Keep in mind though the idea that this is a group high school project. I'm not sure which type of project that would afford an opportunity for high school students (rather unskilled) to get involved with, to contribute to by using their hands. For example with a wooden wing, probably each student could make a rib for the wings. With an aluminum airplane students also each could make an aluminum rib, the type that are formed around a wooden template with a mallet. It seems like mistakes on a rib wouldn't affect a huge component and quality control could be managed. Ruin a rib, toss it aside and try again. I'm not sure if a mistake in welding a 4130 tube fuselage could be corrected easily. Basically you want students to contribute with simple tasks where mistakes could be fixed without costing too much. With an aluminum airplane students could drill holes, deburr and rivet. I'm not sure how easily mistakes in aluminum can be repaired, say someone who dents the skin when riveting. How do you fix a mistake on an aluminum skin, say someone drills some holes wrong? Can they be filled? Composite construction involves dangerous chemicals which wouldn't bother me as I used to be in the chemical and fume rich electroplating business, but you don't want students breaking out in rashes. However, on a composite airplane there might be opportunity for students to perform the labor intensive sanding, sanding and sanding. So the basic 2 questions are 1) Which type of airplane building method would provide the most opportunity for unskilled high school students to learn and contribute to .......aluminum, tube and fabric, composite or wood. 2) Based on your choice in #1 which specific airplane then would be the best candidate to build? Our high school is known as the East St. Louis "Flyers" being influenced by a close proximity to St. Louis made famous by Charles Lindbergh and the "Spirit of St. Louis Airplane." Thanks, Andrew Good on you for being interested in doing more than the minimum. You might want to check out the murphy Rebel kit. Murphy used to and may still offer kits to school groups at cost or less. Drew Dalgleish Murphy Rebel # 247 C-FHO- Hide quoted text - - Show quoted text - If you want to build in metal the Thatcher CX4 looks fairly easy and not too many $$$ . Just my $0.02. Frank M Hitlaw At my Secret world HQ |
![]() If you want to build in metal the Thatcher CX4 looks fairly easy and not too many $$$ . Just my $0.02. Frank M Hitlaw At my Secret world HQ Be aware that when I googled "thatcher cx-4" i received a warning that there was a trojan virus when the site was clicked on. I use avg antivirus. Pat |
("patrick mitchel" wrote)
Be aware that when I googled "thatcher cx-4" i received a warning that there was a trojan virus when the site was clicked on. I use avg antivirus. I use AVG and, like you, Googled "thatcher cx-4". I received no such warning. YMMV. Montblack http://www.warbirdalley.com/t28.htm T-28 Trojan (just like this one) is in the hangar across from where I was yesterday + will be today. g |
"Montblack" wrote in
: ("patrick mitchel" wrote) Be aware that when I googled "thatcher cx-4" i received a warning that there was a trojan virus when the site was clicked on. I use avg antivirus. I use AVG and, like you, Googled "thatcher cx-4". I received no such warning. YMMV. If you agree to the "Active X" payload, this is Trojan Virus you'll get: See Attachment: Thatcher Trojan.jpg |
![]() "Andrew" wrote in message oups.com... Dear Aviation Enthusiasts, I teach math in an inner city high school in Southern Illinois. Thanks, Andrew Andrew, Come on down to Pinckneyville for the flyin in May just after schools out for the summer. May 18, 19, and 20. We have some homebuilts at the flyin of various types. I have been working with school projects for many years. We were having high school shop classes build airplanes forty years ago. They did very well also. As for a plane for a school project I would recommend a Pietenpol Air Camper. It is all wood and can be built with simple tools. Lots of parts for lots of kids to make and quality control is pretty simple. Materials are relatively inexpensive so the mistakes can be consigned to the trash without great pain in the wallet. The Piet will even fly with a Model A Ford engine if you wish, although a little Continental A-65 would be a better choice. You can pick up a good A-65 for under $4000 and build t he entire airplane ready to fly for under $10,000. Hard to do that with any other airplane these days. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) I-64 east to Exit 50, south of Route 127 28 miles to Pinckneyville Airport. Right alongside the highway. Highflight Aviation is the southernmost hangar, Hangar D. Cheers. |
Andrew
This kind of a project was discussed several years ago and it was pointed out the liability associated with a project like this. As I recall, the school let them build the bird with the proviso that it never be flown ![]() May be some others that remember the prior discussion on this subject and can add more detail? Also a number of years ago (may still be there?),there was a program in Seattle that used inner city youths under a A & E to build 49.9% of your airplane. You bought the material and did 50.1% of work. Boeing helped support the program and hired some of the individuals after they learned some airplane skills I was told. Possible some of our Seattle types might comment on this program and have a contact you could contact for info on it and how they got around the liability? Big John *************************************** On 24 Apr 2007 17:08:13 -0700, Andrew wrote: Dear Aviation Enthusiasts, I teach math in an inner city high school in Southern Illinois. I've been studying airplane projects to build myself alone but also have thought about forming a high school aviation club to build an airplane. There is at least one one high school building the Zenith 701 and Aircraft Spruce donated a Stolp Starduster kit to another high school. The airplanes that I have researched and would like to build myself include the following: Wittman Tailwind and Buttercup, Long-EZ, Cozy Mark IV, KR-2, Christavia, Sonex Vision, Bearhawk, Zenair Zodiac, Zenair 601 and Zenair 701, Thorpe T-18 , BD-4, and the Falconar to name a few. Many of these at some point I've convinced myself, "that's the airplane for me" and just before ordering the plans.....I change my mind. I've been studying homebuilt airplanes for a couple of years now and there probably isn't a homebuilt design that I haven't read about. I know the least about wooden airplanes but wouldn't exclude this type of building material in my choice. I've talked with the welding department at the high school and the instructor said he'd help weld a 4130 fuselage as they have a tig welder. Keep in mind though the idea that this is a group high school project. I'm not sure which type of project that would afford an opportunity for high school students (rather unskilled) to get involved with, to contribute to by using their hands. For example with a wooden wing, probably each student could make a rib for the wings. With an aluminum airplane students also each could make an aluminum rib, the type that are formed around a wooden template with a mallet. It seems like mistakes on a rib wouldn't affect a huge component and quality control could be managed. Ruin a rib, toss it aside and try again. I'm not sure if a mistake in welding a 4130 tube fuselage could be corrected easily. Basically you want students to contribute with simple tasks where mistakes could be fixed without costing too much. With an aluminum airplane students could drill holes, deburr and rivet. I'm not sure how easily mistakes in aluminum can be repaired, say someone who dents the skin when riveting. How do you fix a mistake on an aluminum skin, say someone drills some holes wrong? Can they be filled? Composite construction involves dangerous chemicals which wouldn't bother me as I used to be in the chemical and fume rich electroplating business, but you don't want students breaking out in rashes. However, on a composite airplane there might be opportunity for students to perform the labor intensive sanding, sanding and sanding. So the basic 2 questions are 1) Which type of airplane building method would provide the most opportunity for unskilled high school students to learn and contribute to .......aluminum, tube and fabric, composite or wood. 2) Based on your choice in #1 which specific airplane then would be the best candidate to build? Our high school is known as the East St. Louis "Flyers" being influenced by a close proximity to St. Louis made famous by Charles Lindbergh and the "Spirit of St. Louis Airplane." Thanks, Andrew |
Build an RV of ??? | William Snow | Owning | 12 | September 8th 06 03:12 AM |
Build an RV of ??? | Jim Logajan | Home Built | 1 | September 8th 06 03:12 AM |
How to build a P-38 ? ? ? | Hans-Marc Olsen | Home Built | 42 | December 11th 04 04:06 PM |
RV Quick Build build times... | [email protected] | Home Built | 2 | December 17th 03 03:29 AM |
