Charging for tach time in a fixed pitch airplane
Old May 1st 07, 03:21 PM posted to rec.aviation.piloting
Default Charging for tach time in a fixed pitch airplane
On Apr 30, 3:02 pm, Andrew Sarangan wrote:
On Apr 30, 4:53 pm, Jose wrote:
Because all the time on taxiing and all the time abeam when you pull
power are virtually free.
No, it's not "free". It's half price, maybe. (1200 rpm?) The rest of
it is full price.
Jose
1200 sounds a bit too high for taxiing.
Naw. I know of lots of pilots who use the brakes to
control speed with RPM way too high. Good business, replacing brakes
and discs. Tires, too, since they get scrubbed.
Dan
Old May 2nd 07, 01:09 AM posted to rec.aviation.piloting
Brian[_1_]
On May 1, 7:18 am, Dylan Smith wrote:
On 2007-04-30, Brian wrote:
It makes sense to me to charge by Hobbs on constant speed props
because charging by Tach encourages running High MFP and Low RPM. Low
RPM is ok but need to keep the MFP in line with it as well.
That's an old wives' tale, I'm afraid. The best regime to operate an
engine (most efficient and least maintenance) is the lowest RPM and
highest MP for the desired power setting. There are some caveats (some
aircraft have a range of RPMs which you should not continuously operate
the engine), but generally speaking, using the lowest RPM possible for
the desired power setting results in less noise, less vibration and less
wear on the engine.
The thing about operating engines (specifically normally aspirated flat
engines like most of us use) 'above square' is hogwash, I'm afraid.
Agreed, But how do you make a simple rule of thumb for this for pilots
with less then 100 hours or like my latest student that is starting
his primary instruction an an airplane with a constant speed prop.
The problem with your statement is that with new, or low time pilots,
as is often typical in clubs, that are going to take it literally and
is you will end up with a few pilots running around WOT and 1500 RPM.
I doubt that is what you ment and the cyinder pressures have got be
quite high in this configuration, especially if they don't lean
properly either.
The "above square rule" is a great simplifcation of how you "can"
operate constant speed props. It certainly is not a hard and fast rule
but you have to understand what you doing operate otherwise safetly.
For a pilot that barely knows how to operate the throttle and mixture
properly they probably ought to just stick with the "over square rule"
Brian
CFIIG/ASEL
Old May 2nd 07, 01:16 AM posted to rec.aviation.piloting
Bob Noel
In article .com,
Lou wrote:
Doesn't this also bring up the question of when is an overhaul due
(according to hours)?
At 2000 hobbs hours or 2000 tach hours?
Lou
Tach
Bob Noel
(goodness, please trim replies!!!)
Old May 2nd 07, 04:31 AM posted to rec.aviation.piloting
Ron Natalie
Bob Noel wrote:
In article .com,
Lou
Tach
BZZT Wrong answer. Time in service. Tach is acceptable,
so are elapsed time meters. I don't even have a recording
tach in my plane.
Old May 2nd 07, 10:29 AM posted to rec.aviation.piloting
Bob Noel
Lou
Tach
tach in my plane.
argh, I knew better than that too.
Bob Noel
Old May 2nd 07, 11:17 AM posted to rec.aviation.piloting
Dylan Smith
You don't. You tell them to use the power setting tables in the POH. If
they are incapable of this, they aren't really cut out for aviation.
You won't because they won't make enough power to maintain altitude.
properly either.
Cylinder pressures will be in the same order of magnitude as 'normal'
operation. You will neither climb nor go fast though in this regime.
They probably ought to have some remedial training if they can't set the
throttle and mixture correctly! It's not even hard to do these things.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old May 3rd 07, 09:24 PM posted to rec.aviation.piloting
On May 2, 3:29 am, Bob Noel
Lou
Tach
tach in my plane.
In Canada, at least, the time used for such things as engines
is Air Time, described in the regs like this:
"air time" - means, with respect to keeping technical records, the
time from the moment an aircraft leaves the surface until it comes
into contact with the surface at the next point of landing.
Technical records include engine logs. So a tach could be way
off if you spend a lot of time taxying or running up or doing other
non-flying stuff.
Dan
Old May 10th 07, 01:25 AM posted to rec.aviation.piloting
Charlie Axilbund
On Tue, 01 May 2007 07:20:32 -0700, Dan_Thomas_nospam wrote:
Remember your training: check the POH. The setting you want
is the best range setting, which will give you the best distance for RPM
in a fixed-pitch airplane. If the airplane is really old and doesn't
have a range column in the cruise chart, you can find it by reducing the
power in cruise 100 RPM at a time, then allowing the airspeed to
stabilize and trimming for level flight. Keep track of the airspeed
decrease each time until you get a really large ASI drop, then go back
to the last setting.
You are right in the real world, but my purpose was to question whether
fixed pitch airplanes should be charged by tach time. From my
understanding, though, best range is defined in terms of fuel consumed
not tach time; i.e. given 38 gallons of usable fuel, the best range speed
is the one that will get you the farthest. My somewhat whimsical scenario
was to propose a method, given that the charge for the airplane is wet,
that would minimize the cost to the renter. I was trying to think of how
I could get from point a to point b with minimum time on the tach, not
with minimum fuel. I can think of alternatives such as doing the whole
distance at Vx, but I was trying to think how I could keep the rpms at a
minimum. In the end, the best method to minimize rental charges would be
to minimize average rpms x time in flight. Since I have absolutely no
intention to try my method (or a flight at Vx), I have no idea what would
really work best.
Old May 10th 07, 09:02 AM posted to rec.aviation.piloting
Jim Macklin
Wait until you have a tailwind.
"Charlie Axilbund" wrote in message
want
distance for RPM
and doesn't
by reducing the
airspeed to
the airspeed
drop, then go back
question whether
my
fuel consumed
best range speed
whimsical scenario
airplane is wet,
to think of how
the tach, not
doing the whole
the rpms at a
charges would be
absolutely no
idea what would
| really work best.
Old May 10th 07, 01:00 PM posted to rec.aviation.piloting
Denny
There is a reason that most rental airplanes have a Hobbs Meter, and
this discussion is it,..
Now, in the real world with a fixed pitch prop it almost doesn't
matter..
RPM determines tach time, fuel burn, and wear on the engine - which
are the greater items of cost to the FBO than the clock... So, tach
time is merely the substitute for measuring fuel burn and engine
wear... Lets think about a nominal 1 hour tach run for an engine
calibrated for 2400 RPM cruise...
#1 - If you run the intended 2400 rpm the tach time and the clock time
will be about the same, and like wise the fuel burn and wear on the
engine will be the nominal value for an hour.. You will land at 1 hour
on both that tach and the clock, with a nominal 1 hour of both fuel
burn and engine wear...
#2 - If you run 2700 RPM your tach time will grow faster than clock
time, but so will fuel burn and wear rate... In the end you bring the
plane back at 1 hour of tach time, it will sooner than the nominal 1
hour of clock time, which reduces the fuel burn and the engine wear
compared to having run the engine at 2700 for a full 1 hour of clock
time...
#3 - If you run the engine at 2100 RPM the tach runs slower than the
clock, but you are burning less fuel and creating less wear on the
engine.. You will bring the plane back at 1 hour of tach time, but
longer than that on the clock... The lower RPM over the longer time
period will make the fuel burn and the engine wear roughly the same as
case #1...
TANSTAAFL
denny
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Logging Time Consistently - Hobbs AND Tach Carl Orton Piloting 11 June 29th 04 09:52 PM
First time airplane buyer, First time posting Jessewright8 Owning 3 June 3rd 04 02:08 PM
Tach Vs. Hobbs Time John Roncallo Owning 33 January 7th 04 12:42 AM
Next Time I Do Fabric Work on an Airplane Larry Smith Home Built 11 November 22nd 03 06:23 AM
