![]() "chris" wrote in message ups.com... Hi peoples.. Hopefully this is an easy one for you experts out there... Hot start on a fuel injected Lycoming commonly seems to call for leaving the mixture at ICO and cranking. The POH for the Arrow II (Lycoming IO-360-CIC) states for "Starting Engine When Hot" 1. Open the throttle approx 1/2 inch 2. Turn the master switch ON 3. Turn the electric fuel pump on. * -- hand-written footnote says "Will probably flood" 4. Put the mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and move the throttle to desired setting. That doesn't make any sense; it floods. I have better luck starting it flooded, though, so I end up using the next section, "Starting Engine When Flooded" 1. Open the throttle full 2. Turn the master switch ON 3. Turn the electric fuel pump OFF 4. Put mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and [then] retard the throttle. That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedown-row BS", but I finally got the hang of making it work. -c |
![]() "gatt" wrote in message ... "chris" wrote in message ups.com... Hi peoples.. Hopefully this is an easy one for you experts out there... Hot start on a fuel injected Lycoming commonly seems to call for leaving the mixture at ICO and cranking. The POH for the Arrow II (Lycoming IO-360-CIC) states for "Starting Engine When Hot" 1. Open the throttle approx 1/2 inch 2. Turn the master switch ON 3. Turn the electric fuel pump on. * -- hand-written footnote says "Will probably flood" 4. Put the mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and move the throttle to desired setting. That doesn't make any sense; it floods. I have better luck starting it flooded, though, so I end up using the next section, "Starting Engine When Flooded" 1. Open the throttle full 2. Turn the master switch ON 3. Turn the electric fuel pump OFF 4. Put mixture control in IDLE CUT-OFF 5. Engage the starter... When the engine fires, advance the mixture control and [then] retard the throttle. That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedown-row BS", but I finally got the hang of making it work. -c This happened to an Arrow at KGKY (Arlington, TX) some time ago. The pilot was used to flying with toe brakes; this one had only a handbrake. Chewed a hole through a chain link fence and hit a car. They found one of the propeller blades several days later imbedded in the roof of the fire station 1/2 mile away. |
![]() "Allen" wrote in message ... That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedown-row BS", but I finally got the hang of making it work. This happened to an Arrow at KGKY (Arlington, TX) some time ago. The pilot was used to flying with toe brakes; this one had only a handbrake. Chewed a hole through a chain link fence and hit a car. That's unfortunate. I wonder how much of an insurance hit he/we will take for something like that. The very first item in the "STARTING ENGINE" checklist in the POH is: 1. Set Parking Brakes ON. Managing the throttle and mixture while simultaneously applying toe brakes and making sure you're not rolling forward would make me nervous. I amended my run-up checklist to say "Verify no movement" immediately after setting the throttle to 2000 RPM 'cause the last thing I'd want to do while verifying mag drops and engine instruments is to look up and realize I'm moving. -c |
On May 18, 5:05 am, "gatt" wrote:
"Allen" wrote in message ... That gets us right to Scott's "that 3000 RPM-panicky-grab-the-throttle-quick-before-we-go-flying-into-the-next-tiedo*wn-row BS", but I finally got the hang of making it work. This happened to an Arrow at KGKY (Arlington, TX) some time ago. The pilot was used to flying with toe brakes; this one had only a handbrake. Chewed a hole through a chain link fence and hit a car. That's unfortunate. I wonder how much of an insurance hit he/we will take for something like that. The very first item in the "STARTING ENGINE" checklist in the POH is: 1. Set Parking Brakes ON. Managing the throttle and mixture while simultaneously applying toe brakes and making sure you're not rolling forward would make me nervous. I amended my run-up checklist to say "Verify no movement" immediately after setting the throttle to 2000 RPM 'cause the last thing I'd want to do while verifying mag drops and engine instruments is to look up and realize I'm moving. -c That sounds good, but I would rather use my toe brakes when starting and doing a runup. Why?? At least twice while doing a runup in an Archer the park brake has mysteriously unlocked itself, leaving the aircraft with the meat grinder spinning at 2000rpm to lurch forward while I leap on the brakes ![]() I used to use park brake but it just makes me nervous - at least with leaning hard on the toe brakes I am sure it ain't going anywhere! |
![]() "Allen" wrote They found one of the propeller blades several days later imbedded in the roof of the fire station 1/2 mile away. Whoa, there, back up! That sounds like the "big fish" story. It gets bigger every time it is told. A half mile is way too far to be believable, if the prop is thrown from ground altitude. Two, three hundred yards, maybe. You would need to show me some documentation for me to believe much more than that. -- Jim in NC |
I saw the pictures of that. 100 yards, maybe.
Morgans wrote: "Allen" wrote They found one of the propeller blades several days later imbedded in the roof of the fire station 1/2 mile away. Whoa, there, back up! That sounds like the "big fish" story. It gets bigger every time it is told. A half mile is way too far to be believable, if the prop is thrown from ground altitude. Two, three hundred yards, maybe. You would need to show me some documentation for me to believe much more than that. |
Going IFR from the start | Dylan Smith | Piloting | 9 | May 23rd 05 11:47 PM |
Hopefully not the start of a new trend ... | Cockpit Colin | Piloting | 4 | February 5th 05 06:11 AM |
Cold Start Question | Andy Shane | Piloting | 7 | January 12th 05 01:35 PM |
I want to start | Carlos Estopier | Owning | 16 | May 12th 04 07:09 PM |
