Soft field landings - low wing vs high wing aircraft
Old May 22nd 07, 09:28 AM posted to rec.aviation.piloting
Thomas Borchert
Default Soft field landings - low wing vs high wing aircraft
Justin,
I'm interested in hearing which configuration folks prefer for turf
strips
For "turf" it's not an issue at all. Most fields in Europe are "turf"
(meaning well kept gras, in my definition), and only in very wet times
after a lot of rain does operation on them become any issue.
Dirt strips on the other hand are much different. You can operate both
kinds out of them, but high wings do have the advantage you mention.
Also, many high wings seem to have shorter ground rolls than low wings.
Any lack of ground effect can be compensated with a little power.
Thomas Borchert (EDDH)
Old May 22nd 07, 10:12 AM posted to rec.aviation.piloting
Dylan Smith
On 2007-05-22, Mortimer Schnerd, RN mschnerdatcarolina.rr.com wrote:
I've landed Cherokees and Cessnas on grass and I prefer the Cessnas. It seems
to me that the elevator authority is greater, or becomes effective earlier than
in the Cherokee. It doesn't take much to hold a C-172 nose up, particularly
compared to an PA-28 or -32. YMMV.
That's just Cessna -vs- a Cherokee though, nothing to do with high or
low wing. The Diamond DA-40 has tremendous elevator authority, and you
can keep it rolling on the mains only for just as long as a C172. But it
is low wing.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old May 22nd 07, 12:52 PM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
is low wing.
I can't deny it. My comments are based strictly on my own experience... and 99%
of my flying has been in Piper and Cessna aircraft. That's what I had to fly;
not what I necessarily would have preferred to fly. Although I do like both
quite a lot.
Old May 22nd 07, 03:01 PM posted to rec.aviation.piloting
Matt Barrow[_4_]
"Orval Fairbairn" wrote in message
news
Newps wrote:
Then you're flying too fast. I put 1000 hours on a 182 and now with the
Bonanza I fly it basically the same. 70 MPH short final slowing to
about 65 over the edge of the runway. Just fly it right into the
ground. This is assuming a non paved but not a really soft field.
Paul kgyy wrote:
Ground effect can also lengthen the flair process, not a good thing
with most unimproved strips.
No -- his flare exhibits insufficient flair!
OH! NO! Not this carp again! :~)
Old May 22nd 07, 04:39 PM posted to rec.aviation.piloting
Newps
Robert M. Gary wrote:
On May 21, 6:10 pm, Justin Gombos
I was thinking low wing planes would be favorable for landing on a
grass strip, because the extra ground effect could mitigate hard
landings and keep the ride smooth. But I recently read that some
fields are rough enough that rocks, bushes and debris can hit or snag
on the flaps.
strips - as well as other factors that might make one plane more
suitable than another for grass strips. Or is everything negligable?
I've seen some planes fitted with quad runner off-roading type tires
for landing on very rough terrain.. but that would be overkill in my
case.
PM instructions: do a C4esar Ciph3r on my address; retain punctuation.
When I flew out of a rough grass strip the high wings were at a clear
advantage (I was flying an Aeronca and a Swift). The low wing planes
would often get rock dings on the leading edge but the high wings were
always fine.
How do you get rock dings on the leading edge of your wing? Never had
that happen, high or low wing. I've eliminated rock dings on the tail
now with the V tail. In the 182 I had to install the rubber leading
edge strips, it was getting pretty bashed up.
Old May 22nd 07, 07:54 PM posted to rec.aviation.piloting
Robert M. Gary
on the flaps.
case.
always fine.
edge strips, it was getting pretty bashed up.- Hide quoted text -
- Show quoted text -
My guess is that the prop blast lifted them and the movement of the
plane ramed them into the wing. I guess I never through about it much.
Of course dings were pretty obvious in the Swift because it was
polished aluminum.
-robert
Old May 22nd 07, 08:41 PM posted to rec.aviation.piloting
Paul kgyy
On May 21, 10:40 pm, Orval Fairbairn
I wish I could say that I always land with flair, but my flare usually
turns into a thud.
Old May 22nd 07, 11:03 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
I'll go with negligable. I used to fly my 172, and currently fly my
Cherokee from unpaved strips. Both were equally suitable.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200705/1
Old May 23rd 07, 12:47 AM posted to rec.aviation.piloting
john smith
A really importanat thing to think about when operating off of turf is
if the aircraft has wheel pants.
If the grass was allowed to grow long before it was cut, it is possible
for wet clippings to fill the space between the wheel pant and the tire,
locking the wheel and sending the aircraft in a direction you may not
want it to go and have no control over it going there.
I have seen it happen and it is not a pretty sight.
Old May 23rd 07, 05:21 AM posted to rec.aviation.piloting
C J Campbell[_1_]
On 2007-05-21 18:10:04 -0700, Justin Gombos
on the flaps.
Yes. Also, high wing aircraft can have bigger flaps and lower approach
speeds than low wing aircraft. Flap size is limited on many low wing
aircraft by the need for ground clearance.
For well-kept turf strips, it is about equal except for the slightly
higher approach speeds of some low wing aircraft. One of the nice
things about turf, though, is that it has greater rolling resistance,
so it actually tends to be a bit of an equalizer between low wing and
high wing aircraft in short field landings. Takeoff is another matter.
Low wing aircraft tend to get into ground effect a little quicker than
high wing aircraft.
case.
The big balloon-type tundra tires look like even more overkill. It
looks like fun and one of these days I will have to beg someone to
demonstrate them to me.
Waddling Eagle
World Famous Flight Instructor
Variations in soft field landings Maxwell Piloting 42 April 27th 07 05:12 PM
Short vs Soft Field Takeoff and Landings Ol Shy & Bashful Piloting 17 November 17th 06 10:32 PM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
High wing vs low wing temp Owning 11 June 10th 04 02:36 AM
End of High wing low wing search for me dan Home Built 7 January 11th 04 10:57 AM
