Coordinated turns without rudder, and autopilots
Old May 29th 07, 12:20 PM posted to rec.aviation.piloting
Matt Whiting
Default Coordinated turns without rudder, and autopilots
Ron Natalie wrote:
Luke Skywalker wrote:
Ron...
oh my goodness...get some time with a good book on the subject and
then a CFI.
Robert
I have plenty of good books and practice on the subject.
You should find an aeronautical engineer and find out how
planes are designed to work.
Then you should know that the vertical stab can't prevent yaw, it can
only help eliminate yaw once it occurs as it can't provide any restoring
force until some degree of yaw occurs. A rudder an prevent yaw from
occurring in the first place. Fundamental difference here.
Matt
Old May 29th 07, 08:58 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Ron Natalie wrote in news:465c026d$0$30412
Ron...
then a CFI.
Robert
Me too.
You're wrong.
Bertie
Old May 30th 07, 02:33 AM posted to rec.aviation.piloting
Luke Skywalker
Ron...
then a CFI.
Robert
..Well...you build them, I will fly them and we need the rudder to
coordinate turns particularly but not exclusivly with ailerons.
Robert
Old May 28th 07, 04:10 AM posted to rec.aviation.piloting
John Theune
Mxsmanic wrote:
How do autopilots make coordinated turns even when they cannot control the
rudder?
What makes you think they do not control the rudder?
Old May 28th 07, 10:52 AM posted to rec.aviation.piloting
gpaleo
Ο "John Theune" έγραψε στο μήνυμα
news:KKr6i.8843$zN5.5464@trndny05...
rudder?
Mine (KFC-150) does not.
Old May 29th 07, 03:37 AM posted to rec.aviation.piloting
Mxsmanic
John Theune writes:
The absence of rudder movement, and the expense of providing servos for the
rudder as well as the ailerones. It's possible that autopilots on transport
aircraft do control the rudder, but the small ones for small aircraft
apparently do not.
Mxsmanic wrote in
John Theune writes:
for the rudder as well as the ailerones. It's possible that
autopilots on transport aircraft do control the rudder, but the small
ones for small aircraft apparently do not.
Uou're a fjukkwit and you know nothing about airplanes.
bertie
Old May 28th 07, 01:30 PM posted to rec.aviation.piloting
Bob Moore
the rudder?
Swept wing and some straight wing aircraft have independent Yaw Damper(s)
that control the rudder(s). Their primary function is to control (prevent)
dutch roll. They operate with the autopilot on or off.
From Wikipedia, the free encyclopedia
A yaw damper is a device used on many aircraft (usually jets and
turboprops) to damp (reduce) the rolling and yawing oscillations due to
Dutch roll mode[1]. It involves yaw rate sensors and a processor that
provides a signal to an actuator connected to the rudder. The use of the
yaw damper helps to provide a better ride for passengers, and on some
aircraft is a required piece of equipment to ensure that the aircraft
stability remains within certification values.
The term is often mis-pronounced as a "yaw dampener".
Bob Moore
Old May 29th 07, 03:40 AM posted to rec.aviation.piloting
Mxsmanic
Bob Moore writes:
I'm thinking along the lines of small aircraft such as a C172 or Baron. They
do not have AP control of the rudder, and yet the AP can still execute
coordinated turns.
Old May 29th 07, 08:59 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Bob Moore writes:
Damper(s) that control the rudder(s). Their primary function is to
control (prevent) dutch roll. They operate with the autopilot on or
off.
Baron. They do not have AP control of the rudder, and yet the AP can
still execute coordinated turns.
No it can't, fjukkkwit.
Bertie
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
Coordinated turns and the little ball Mxsmanic Piloting 51 October 11th 06 10:17 PM
Is rudder required for coordinated turns? Mxsmanic Piloting 41 September 24th 06 06:40 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coordinated turning stall and spins Chris OCallaghan Soaring 20 November 18th 03 08:46 PM
