Any pireps for PCAS MRX collision avoidance system?
Old June 5th 07, 09:43 AM posted to rec.aviation.piloting,rec.aviation.soaring
Thomas Borchert
Default Any pireps for PCAS MRX collision avoidance system?
Andrew,
Since mid-air collisions occur near traffic patterns at low altitudes
this is where I would want the system to be most responsive. It seems
as if the opposite is true.
Two points:
1. Except at very remote fields, the likelyhood of airliners with TCAS
being above the pattern is high at most busy GA fields, since they will
be near major cities.
2. In a busy pattern, I would not want you to look at a fancy display
giving you traffic information, I want you to look out.
To expand: My experience with these simpler devices is that if you have
more than, say, two close-by targets (a typical situation in a busy
pattern), they become useless since you'll be busy looking outside. I
turn our voice alerting off on the Monroy in these cases, since it will
just say "traffic nearby" all the time and show a distance of a mile. I
know that already, so I look outside.
These units are great for alerting you at times where you don't expect
traffic to be around, e.g. at that lonely field where it finds you that
one other plane in the pattern you have missed, or during cruise when
you are busy programming the GPS.
Thomas Borchert (EDDH)
Old July 1st 07, 11:23 PM posted to rec.aviation.piloting,rec.aviation.soaring
Eric Greenwell
I'm not familiar with the Monroy, but it's threat determination doesn't
sound as good as the MRX. To quote from a post I made:
"I'm also using an MRX. I believe it's warnings are also based distance
and altitude trends, not just distance and altitude. For example,
consider two aircraft the same distance from you and the same altitude
above, one descending and one ascending. Only the descending one will
trigger the alert signal."
In other words, the MRX "advisory" and "alert" warnings are not based
just on traffic being nearby, but actually approaching your position. In
addition, it displays distance down to 0.4 mile.
Old June 4th 07, 12:29 AM posted to rec.aviation.piloting,rec.aviation.soaring
JJ Sinclair
A couple of week ago I heard; Glider-Glider-Glider, this is twin umpt-
upm, descending through 20,000 over the Pinenuts for landing at Carson
City.I responded that glider Jay Jay was descending through 10,000 on
the west side of the Pinenuts. About 3 minutes later the twin said,
Jay Jay, I have you on my TCAS and just got a visual on you about 500
feet below and 1 mile east of me. I responded, Roger that, I have you
on my PCAS and just got a visual on you also. We both agreed that this
was the way its supposed to work.
JJ
On Jun 3, 11:34 am, Mutts wrote:
Crossposting over to soaring...
worth 500 clams?..............http://www.zaonflight.com/content/view/2/13/
Some have commented that the lack of bearing info is a limitation,
others not so much.
Anyone with lots of experience using this unit or similar, thoughts?
Thanks!
On Fri, 1 Jun 2007 19:18:47 -0400, "Capt. Geoffrey Thorpe" The Sea
Hawk at wow way d0t com wrote:
"Mutts" wrote in message
Ax over on r.a.soaring - they seem to be more popular over there.- Hide quoted text -
- Show quoted text -
Old June 4th 07, 02:14 AM posted to rec.aviation.soaring
Rick Fuller
JJ
I agree, that's the way it should work. I'm not real
familiar with TCAS. How did he detect you? PCAS is
strictly passive as I understand it. Did you have
a transponder on board?
Rick 'CL'
this is twin umpt-
landing at Carson
through 10,000 on
the twin said,
on you about 500
that, I have you
agreed that this
JJ
iew/2/13/
is a limitation,
others not so much.
similar, thoughts?
Thanks!
On Fri, 1 Jun 2007 19:18:47 -0400, 'Capt. Geoffrey
Thorpe' Hawk at wow way d0t com wrote:
'Mutts' wrote in message
Old June 4th 07, 03:52 PM posted to rec.aviation.soaring
JJ Sinclair
Did you have
Yep, I installed a Becker transponder, encoder and PCAS, last winter.
Cost me less than $3000 bucks and I feel a whole lot better about
aviating around Reno, NV. I'm amazed at whats going on out there that
I didn't know about, I let Reno approach know where I'm at and they
seem appreciative, I see other sailplanes before they enter my thermal
and I see the occaasional Cessna pass too close every now and then.
Beats being bent around the nose of a Hawlker! I'm running a 12v,12ah
battery with everything on Im pulling less than 1 amp and don't drop
below 12v for 5 hours. Got a back-up 7ah, just in case and everything
fits in my panel. Life is good.....................Minden regionals in
2 weeks...................come join us.
JJ
Old June 5th 07, 04:00 AM posted to rec.aviation.piloting,rec.aviation.soaring
Our club, Black Forest Soaring Society (BFSS) now has five members
with the MRX PCAS. Mine is doing exactly what it is supposed to do:
detect transponder or TCAS equipped aircraft being interrogated near
my glider. two common things interrogate: a ground-based radar or
airborne TCAS. It is also portable so we can take it with us when we
teach or do intro rides in other planes.
There are two modes: advisory and alert.
Advisory is a two-beep warning that something is nearby and within my
preset altitude and distance criteria. Alert is a four-beep sound that
means the traffic is even closer.
I have been operating my PCAS with the screen at its lowest brightness
because it really is not important to me to know about traffic that is
relatively far from me. All I need is the noise: two-beeps or four;
that is, near or nearer.
That noise says it all since the criteria for activating those sounds
are set by the pilot, me.
When MRX beeps, my eyes sweeps (added the extra "s" to complete the
rhyme).
In the nine months I've owned the MRX, there have been four cases of
four-beeping. In all four cases, the traffic came from behind. And, in
all four cases I had plenty of time to search and locate the traffic.
The surprise traffic came from behind because MRX trained me to be
better at spotting traffic ahead and to my sides.
When I get rich, I'll also add a transponder. But for now, and
recognizing that jet guys are flying heads-down more often than even
they realize, PCAS is helping me a bunch. Oh, for a living I fly large
jets equipped with TCAS. I watch my fellow crewmembers and they don't
look out the window as often as they should.
So, I'd rather know that I can see most of them, then to hope that
they see me, and to hope that the Bonanza guys are talking to a radar
controller who will alert them to my presence.
Raul Boerner
LS6-B "DM"
Old July 1st 07, 11:18 PM posted to rec.aviation.piloting,rec.aviation.soaring
Eric Greenwell
In practice, I've found another glider can fly close to me going in the
same direction and not trigger the alert, but a more distant glider
coming at me will trigger the alert. Similar response when thermalling:
if we are both ascending at the same rate, no alert; if the lower glider
begins to gain on the higher glider, an alert may occur.
This more sophisticated threat determination seems to make it work well
in the traffic pattern when there are other aircraft around. My
experience in busy patterns is limited, however.
Old July 3rd 07, 03:20 PM posted to rec.aviation.piloting,rec.aviation.soaring
Eric wrote: I'm also using an MRX. I believe it's warnings are also
based distance and altitude trends, not just distance and altitude.
For example, consider two aircraft the same distance from you and the
same altitude above, one descending and one ascending. Only the
descending one will trigger the alert signal.
This "trend" clarification is a very important distinction. Thank you
for pointing it out. It helps to explain why sometimes aircraft are
within the MRX parameters, but don't trigger the beep-beeps.
Any pireps for PCAS MRX collision avoidance system? Mutts Piloting 21 July 3rd 07 03:20 PM
PCAS - Portable Collision Avoidance System [email protected] Soaring 13 October 14th 06 08:21 PM
Collision Avoidance and ATC Bubba Soaring 5 September 1st 06 05:31 AM
Collision Avoidance Systems [email protected] Products 0 May 21st 06 11:15 PM
Collision avoidance device Jim Hendrix Soaring 1 October 19th 04 10:24 AM
