#11
![]() Did the Imperial Japanese Army Air Force and the Imperial Japanese Navy Air Force operate any of the same make of aircraft? As a rule, no. The requirements were quite different up to 1941, when they sudden moved closer together. (That's why the Nakjima Ki-43 Hayabusa was suddenly yanked off the shelf and put into service: the army was told that it required a 500-mile-range fighter for the Malaya invasion.) I think both services operated Japan-built DC-2s and 3s, but even here I think of the Douglases as navy planes. The army used a Japan-built Lockheed Super Electra for dropping paratroops, and used bombers for heavy cargo. Army planes had French throttles: you pulled the throttle toward you for full power; the navy followed English-American style. So it would take some retraining before a pilot could fly an airplane from the other service. Army and navy radios couldn't communicate with one another. An army machine-gun bullet wouldn't fit a navy machine gun nominally of the same caliber. They made the famously contentious U.S. army and navy look like models of interservice cooperation. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
![]() Well, there was the Zero for one. The A6M Zero wasn't in service with the Japanese army air force. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
![]() The Nakajima Ki-43 Hayabusa 'oscar' was very similar in shape, and also used the same engines In fairness to the army plane, the Hayabusa came first. The army turned it down because of its perceived weaknesses in dogfighting. Then the Zero was having trouble meeting specifications. So Mitsubishi ditched its engine and borrowed the one Nakajima had developed for the Hayabusa, and which of course was available since the Ki-43 wasn't going into production. Then came 1941 and the Malaya invasion plans. The army dusted off the Ki-43, solved its slow-speed maneuver problem with "butterfly" flaps, and put it into production. Only 100 had been built by Dec 7/8, and only two fighter groups had been equipped with it. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
![]() Something fairly close to it. Right-wing Japanese nationalists aligned with parts of the Imperial Japanese Army had been using assasination and threats of violence against political leaders thoughout the 1930s. In roughly 1940-41, Admiral Yamamoto was rumored to be a target of assasination efforts for arguing against war with the United States. In some versions of the story, that's how he ended up in command of the Japanese fleet in December 1941; his bosses decided he was safer at sea than in a Tokyo office. To be precise. safer on the Battleship Yamato, which he used as his HQ -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
![]() "av8r" wrote in message ... The IJN and the Japanese Army were deadly rivals in the power struggles that characterised Japanese politcs of the 20's, 30's and 40's its unlikley they would ever co-operate on anything. Hi Keith The J.N.A.F. and J.A.A.F. did in fact co-operate out of necessity. The Mitsubishi J8M1 Shusui (Rigorous Sword) short-range interceptor was a prime example. The rocket propelled aircraft was based broadly on the Messerschmitt Me-163B Komet design, as the Japanese only had one simple instruction manual to use as a guide. The J.A.A.F. recieved a samll number of MXY7 Akigusa (Autumn Grass) gliders that had been built by the Maeda Koku Kenkyusho company to be used as trainers for the J8M1. The J.A.A.F. designation for their development of the J8M1 was Ki.200. After the Army Aero-Technical Research Institue (Rikugan Kokugijutsu Kenkyujo)got involved, it was developed as the Ki.202. There were five prototypes of the J8M1 built, but only the first one built flew. It made its maiden flight at Yokosuka Naval Aeronautical Engineering Arsenal on the 7th of July 1945. It crashed after reaching an altitude of 1,300 feet in a steep climb. It was determined that the accident was a result of the rocket motor failing. The hydrogen peroxide shifted to the rear of the partially empty tank which in turn cut off the fuel supply, and owing to air entering a fuel pipe and causing a blockage. Although the J.A.A.F. chose the aircraft as the priority interceptor project, no prototype was completed by the time Japan surrendered. Cheers...Chris Right but that was at the end of the war when all else had failed for most of the time they were deadly rivals. Yamamoto had to be sent back to sea in 1941 to avoid assassination by the army ! Keith |
![]() "Eric Moore" wrote in message om... "Keith Willshaw" wrote in message ... "JDupre5762" wrote in message ... Did the Imperial Japanese Army Air Force and the Imperial Japanese Navy Air Force operate any of the same make of aircraft? It seems to me that that at least with some combat aircraft the two services might have economically ordered from the same production lines and saved some money and opened up some factories for producing more of other types of aircraft? John Dupre' The IJN and the Japanese Army were deadly rivals in the power struggles that characterised Japanese politcs of the 20's, 30's and 40's its unlikley they would ever co-operate on anything. That said the requirements of shipborne aircraft tend to vary from those of land based aircraft and the USN and USAAF used different aircraft too as did the RAF and FAA. Keith "Deadly rivals"? Did the Army and IJN do assassinations on each other or something? Yes indeed they did, assassination was a prime tool of Japanese politics of the time. Here are just a few incidents May 15 "May Incident" (5.15)Assassination of Prime Minister Inukai Tsuyoshi by Navy-inspired extremists. 1934 Nov. "Military Academy Incident"assassination and coup plot by cadets discovered 1935 August General Nagata Tetsuzan cut down by a young army officer 1936 Feb. "February 26th Incident" (2.26)led by junior field grade officers in capital area with strong civilian inspiration seize area around Imperial Palace and downtown Tokyo. PM Okada escaped, Grand Chamberlain Suzuki wounded, Lord Privy Seal and former-PM Saitô and Finance Min. Takahashi killed. Collapses after the Emperor demands they be labeled rebels and loyal army units and the navy's big guns are arrayed against them. Most rebels executed without public trial. Keith |
![]() "Leadfoot" wrote in message news:qHOUa.18168$u51.6146@fed1read05... Something fairly close to it. Right-wing Japanese nationalists aligned with parts of the Imperial Japanese Army had been using assasination and threats of violence against political leaders thoughout the 1930s. In roughly 1940-41, Admiral Yamamoto was rumored to be a target of assasination efforts for arguing against war with the United States. In some versions of the story, that's how he ended up in command of the Japanese fleet in December 1941; his bosses decided he was safer at sea than in a Tokyo office. To be precise. safer on the Battleship Yamato, which he used as his HQ IRC his first flagship on returning to sea was the Nagato as the Yamato was still fitting out. Keith |
Hi Keith
I realize this was a last ditch effort but it counters your claim that they did not co-operate on anything. Cheers...Chris |
![]() "av8r" wrote in message ... Hi Keith I realize this was a last ditch effort but it counters your claim that they did not co-operate on anything. Cheers...Chris There are exceptions to every rule. Keith |
![]() There are exceptions to every rule. Keith "Absolutely!!!" |
WTD: ANC Manual (Army Navy Civil) for Air Traffic Control | [email protected] | Aviation Marketplace | 0 | October 20th 04 04:06 AM |
WTB: ANC Manual (Army Navy Civil) air traffic~1950's?(correctedpost) | [email protected] | Aviation Marketplace | 0 | February 27th 04 08:13 AM |
WTB: ANC Manual (Army Navy Civil) Air Traffic Control - 1950's? | [email protected] | Aviation Marketplace | 0 | February 25th 04 07:03 AM |
Army Aircraft Operator Manuals | TJ | Aviation Marketplace | 0 | January 13th 04 03:45 AM |
FS Books USAF, Navy, Marine pilots and planes | Ken Insch | Military Aviation | 0 | July 20th 03 02:36 AM |
