Fred J. McCall wrote:
Peter Skelton wrote: :On 8 Aug 2003 04:42:50 -0700, (Moggycat) wrote: : :Correction on behalf of Peter Rieden and co: : :"The Harrier is flown by some of the most dangerous pilots in the U.S. :military today." : :It's a training problem - marines don't have to take perisher. Then explain how over 2/3 of the major accidents are mechanical failures and not human failures, if it's a pilot training problem. well, there's no need to limit the blame to pilots, from the article in question: "The accident inquiry concluded that a circlip, a semicircular fastener, was incorrectly installed by mechanics on the gas turbine starter, setting off a chain reaction that led to the engine failure." |
military today." That's what they'd say, too. |
In article , Stephen D. Poe
writes Anytime you develop a totally new type of aircraft and have to also develop new operational concepts you get fatal accidents. Go back and review the early days of everything from the Harrier to the early jets and helicopters. The Harrier didn't do too badly in US service at the start, they had a period of nearly two years accident free. Also note the operational requirements are inherently more dangerous than, say, circumstances where you rarely, if ever, fly below several thousand feet. The Harrier regularly operates in an environment unique to itself, basically zero air speed very close to the ground. If anything happens it's game over, all the pilot can do is pull the handle. No other aircraft is intentionally put in the same situation (choppers can auto- rotate if needed). STOVL JSF has a more complicated system with more failure points. It's not that the Osprey is more dangerous or has resulted in more fatalities than many of the older planes, it that we've become less tolerant of failures during R&D T&E. The problem with the Osprey is the inability to demonstrate the problems have been fixed. It's a very complex creature and Bell/Boeing are determined to try to fix it (tilt-rotor being their pet technology) rather than look at other alternatives which may have fewer built in problems. -- John |
John Halliwell wrote: The problem with the Osprey is the inability to demonstrate the problems have been fixed. It's a very complex creature and Bell/Boeing are determined to try to fix it (tilt-rotor being their pet technology) rather than look at other alternatives which may have fewer built in problems. I'm aware I've said this before, but it seems an awful complicated way of avoiding building a Rotodyne.. -- Andy Breen ~ Interplanetary Scintillation Research Group http://users.aber.ac.uk/azb/ "Time has stopped, says the Black Lion clock and eternity has begun" (Dylan Thomas) |
![]() Tony Williams wrote in message m... (ANDREW ROBERT BREEN) wrote in message ... In article , John Halliwell wrote: The problem with the Osprey is the inability to demonstrate the problems have been fixed. It's a very complex creature and Bell/Boeing are determined to try to fix it (tilt-rotor being their pet technology) rather than look at other alternatives which may have fewer built in problems. I'm aware I've said this before, but it seems an awful complicated way of avoiding building a Rotodyne.. Ah, the Rotodyne. I don't know if you saw it but there was an article in June 'Air International' saying that the gyrodyne may be on the way back. A company called Groen Brothers Aviation are proposing this as a low-cost, low risk approach,initially by converting existing fixed-wing aircraft to have a rotor on top. Believe it or not, one of their key targets for such a conversion is the C-130 Hercules! Saw some film a few nights back on the TV of a WWII era jeep with boat tail and rotor a few feet off the ground. Looks like the idea was to tow them in separate during air assaults. |
![]() John Halliwell wrote: have been fixed. It's a very complex creature and Bell/Boeing are determined to try to fix it (tilt-rotor being their pet technology) rather than look at other alternatives which may have fewer built in problems. The problems can be traced back to the fact that its a compromise design based around the ships it'll be operating from primarily. The physical size limits of the V22 are totally restricted by the flight deck and elevator clearance issues for the wasp-class LHDs. Rotor diameter was restricted by needing a minimum blade-tip clearance of 12 feet with the island and a 5 foot clearance between the edge of the deck and the osprey's wheels. The blade, wing and naccele folding procedure were limited by the elevator size on the LHDs. Bigger elevators would have meant more room for useful things like bigger engines, 4 blade rotors and a longer wingspan (all of which would have improved the type's performance in both the hover and more importantly, single-engine operation). The previous XV-15 program operated so well for over a decade because it wasn't tooo much airframe for too little installed power/rotor lift. |
Osprey 2 modifications | Terry Mortimore | Home Built | 5 | October 23rd 04 11:46 PM |
Amphib: Coot vs Osprey II | Greg Milligan | Home Built | 9 | December 29th 03 01:48 AM |
