Air Compressor Horsepower/Wattage/Amperage
Old June 26th 07, 05:51 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Default Air Compressor Horsepower/Wattage/Amperage
On Jun 24, 5:20 am, Ron Rosenfeld wrote:
Ron, what peak starting current should I expect on a single-phase,
240V, 3/4h.p., running current=7.8A motor used to lift my hangar door?
I want to rig up a genny to lift the door during a power failure. The
gear train on the door is rigged so that all of the cables are slack
(i.e. only motor inertial) when the motor starts.
Old June 27th 07, 02:56 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Ron Rosenfeld
mgm17160, I really don't know. I'd be surprised if it were as much as
double the running amps, but there's no good way of telling without
measuring.
With no measurement, I would size the generator to be able to handle a
surge equal to the Locked Rotor Amps as calculated by the nameplate code
rating on the motor. Or just try a genny that can handle a surge of
15A/240V.
A problem with small, inexpensive, gasoline fueled generators is that,
unless you are religious about exercising them, they usually won't start
when you need them. And, unless you have a mission-critical situation,
it's overkill to put in something that you can set and forget.
I, too, have a door that is not amenable to any kind of mechanical backup.
I happen to have an extra 120V inverter I could hook up -- but the cost of
batteries and a step-up transformer to set up the system is excessive,
especially given that I've only been stymied by a power outage at the
hangar once or twice in the past seven years.
--ron
Old June 27th 07, 06:05 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
when you need them.
An exception to that rule is a Honda generator. I'm not a foreign car guy,
or anything like that; quite the opposite. My dad had one that would sit
for a couple of years, and it would start on the first or second pull, with
fresh gas in the tank.
It is amazing how many other uses come up, once you have a generator sitting
around.
Old June 27th 07, 06:25 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Roger (K8RI)
On Wed, 27 Jun 2007 01:05:26 -0400, "Morgans"
when you need them.
around.
Mine is 9500 watts continuous. It doesn't even have the option of a
pull starter. I don't think I could pull it even if it did. I keep
the tank full. When I shut it down I turn the gas off and let it dry
out the carb. It's on wheels, but it'd take a truck to haul it so it
could be called portable. OTOH it'd take three and preferably four men
to put it in the truck. If it were in the shop I could do that with
an engine hoist. I fire it up about every other month and let it run
for about 10 minutes. In the winter I have to keep a small heat lamp
on the battery. It'll run about 10 to 12 hours powering the whole
house sans air conditioner (except for the little spare one stuck in
the bedroom window) on 10 gallons. I had a little 4000 watt Coleman
that used twice as much gas, but it was kinda portable and made a
whole lot more noise.
I purchased it new, *after* Y2K when there were lots of them available
at half price and less. In the last 6 1/2 years I have well over
100 hours on it powering the house. Lots of power outages due to poor
line maintenance and we are about 2 miles from the city limits and
just over a mile from the substation.
As for other uses, with help I some times pull it out of the generator
shed and use it to power my 180 amp MIG welder. It's been a while but
IIRC the engine doesn't even change pitch when welding.
Old June 27th 07, 11:28 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Ron Rosenfeld
when you need them.
around.
One problem is that frequently, after sitting around for a few years, there
isn't fresh gas in the tank! (I should have been more specific as to the
reasons).
--ron
Old June 27th 07, 07:26 PM posted to rec.aviation.homebuilt,rec.aviation.owning
On Sun, 24 Jun 2007 07:20:40 -0400, Ron Rosenfeld
On Mon, 18 Jun 2007 13:49:59 -0700, "RST Engineering"
I thought I had this compressor power thing down to a pretty good science
until they started screwing around with "rated watts" and "peak power" and
all that crap that makes their compressor look really good until you go to
use it.
Back when we were using "real" horsepower I used a figure of 750 (to make it
easy to calculate, I believe 746 is the actual number) watts per horsepower
and an efficiency factor of 85% so that a one horse motor would take 860
watts to do the actual work.
But then you multiplied that times two for "starting" wattage for a couple
of seconds to give 1725 watts under start and then times three for starting
under some volume of air left in the compressor reservoir or about 2600
watts.
That presses my 2200 watt continuous duty (2800 watts peak) fairly close to
the load limit, but certainly gives a margin for error that seems
reasonable.
I happen to have a Sears 1HP compressor (1.5HP Peak). Mine has a nameplate
rating of 10.5A @ 120V. I could not see/locate the nameplate on the motor
itself, so I figured a 52.5A startup surge (5X). My inverter has a 78A
peak capacity (46A continuous) so I figured things would work -- and they
have.
Your 2800W peak generator translates to 23.3A at 120VAC. If you have the
same Sears compressor as I do, I'm not surprised that the generator will
have a problem starting it.
I just measured my little suitcase compressor. It's a dry pump with a
nameplate rating of 115V, 15A, 7.9cfm and 4cfm (presumably at 40 and
90psi). Running off an inverter - tank empty starting current 33.8A.
Running current 11.6A. Normal starting current (after tank drops to
about 80psi, 32.4A (reflects warmed up compressor I guess). Despite
the startup current, this compressor runs fine off my $300 cheapie
3500W rated generator, which in reality is only good for about 2000W
continuous. (inflated rating plus 4500' elevation)
more horsepower T-Bone Piloting 11 March 20th 06 10:56 PM
Lycoming Horsepower Calculation? Mark Doble Home Built 1 June 20th 05 10:46 PM
Thermals and Horsepower Ken Kochanski (KK) Soaring 14 January 9th 05 05:50 PM
Air Compressor for RV Builder John Bundy Home Built 5 March 27th 04 01:47 PM
Horsepower Andre Home Built 3 July 18th 03 10:50 AM
