![]() "Stuart & Kathryn Fields" wrote in message ... Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Perhaps a few metal baffels would be a better choice. |
I have a couple of baffles already, but having 28 gal 100LL just behind my
head makes my nerves twitch just a bit. Having the foam is supposed to make explosive conflagration less likely in case of a prang. Thanks -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vkss.com "Maxwell" wrote in message ... "Stuart & Kathryn Fields" wrote in message ... Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Perhaps a few metal baffels would be a better choice. |
I wonder how the safety of the foam would compare to a bladder? It would
certainly complicate the slosh issue, but might provide greater safety in case of an incident. I have a couple of baffles already, but having 28 gal 100LL just behind my head makes my nerves twitch just a bit. Having the foam is supposed to make explosive conflagration less likely in case of a prang. |
Try searching for explosafe foam but do you think that a crash sever
enough to cause your fuel tank to explode would be survivable anyways. Also fuel from a cracked tank can still catch fire with or without the foan. On Tue, 26 Jun 2007 11:06:02 -0700, "Stuart & Kathryn Fields" wrote: I have a couple of baffles already, but having 28 gal 100LL just behind my head makes my nerves twitch just a bit. Having the foam is supposed to make explosive conflagration less likely in case of a prang. Thanks -- Stuart & Kathryn Fields, Publishers Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell (760) 608-1299 technical cell www.experimentalhelo.com www.vkss.com "Maxwell" wrote in message ... "Stuart & Kathryn Fields" wrote in message ... Is there anyone out there using fuel tanks filled with open cell foam? I've heard that explosions are tamed as well as fuel slosh. I've also heard that the foam must be replaced periodically. How often is the replacement necessary? I'm using 100LL Av gas. Perhaps a few metal baffels would be a better choice. |
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:33 AM |
Fuel tank balance | Mxsmanic | Piloting | 101 | October 3rd 06 07:56 AM |
fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 04:54 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
blue foam, pink foam, yellow foam? | Corrie | Home Built | 26 | September 1st 03 05:01 PM |
