"Waldo" wrote in message ... radar. |
"Ray O'Hara" wrote in message ... "Waldo" wrote in message ... radar. Yes, the Germans never figured out the cavity magnetron so for airborne radar they had to muck around with arrays. Remember the old Airfix model of the Uhu with the aerials on the nose? They were a bugger to get straight while the glue was still soft. |
radar they had to muck around with arrays. While they never did figure out the magnetron, they did capture one that lead hem to develop a copy of it when they shot down a Stiling with H2S. Toward the end of the war they did field upwards of ten AI Radars on Junkers aircraft called the Berlin RADAR that operated in the centimeter wavelength. I am not so sure that the picture that I posted is a test radar. These kind of things really but me when I don't learn the answer for certain. Waldo,. |
On Tue, 03 Jul 2007 09:32:33 GMT, Waldo wrote:
Yes, the Germans never figured out the cavity magnetron so for airborne radar they had to muck around with arrays. While they never did figure out the magnetron, they did capture one that lead hem to develop a copy of it when they shot down a Stiling with H2S. Toward the end of the war they did field upwards of ten AI Radars on Junkers aircraft called the Berlin RADAR that operated in the centimeter wavelength. I am not so sure that the picture that I posted is a test radar. These kind of things really but me when I don't learn the answer for certain. Waldo,. Those look like hoses to me, if they were waveguide they would be much higher frequency than any one was using at the time or for a long time after WW2. JakeInHartsel |
On Tue, 3 Jul 2007 04:50:06 -0600, Jake wrote:
On Tue, 03 Jul 2007 09:32:33 GMT, Waldo wrote: Yes, the Germans never figured out the cavity magnetron so for airborne radar they had to muck around with arrays. While they never did figure out the magnetron, they did capture one that lead hem to develop a copy of it when they shot down a Stiling with H2S. Toward the end of the war they did field upwards of ten AI Radars on Junkers aircraft called the Berlin RADAR that operated in the centimeter wavelength. I am not so sure that the picture that I posted is a test radar. These kind of things really but me when I don't learn the answer for certain. Waldo,. Those look like hoses to me, if they were waveguide they would be much higher frequency than any one was using at the time or for a long time after WW2. JakeInHartsel I have seen pictures of somewhat similar setups used for testing deicing equipment. The deicing equipment being on a plane following the one with the spray setup. JakeInHartsel |
I think you are on to it here. It looks like snow on the ground. The techs
all look civilian instead of military. They might be testing the deicing boot on the tailfins? |
Turns out the mystery is solved.
An answer was supplied to myself on another board by a participant with the handle of Heliopause The image originated in a German propaganda magazine dating from January 1941 called Der Adler. Turns out there was a caption on the page that I didn't think was associated with the image. (I read and translated every damn thing on the page EXCEPT for the crucial caption. DOH! Here is the caption and the rough translation. Zum bilden unten: Um stromungsgeschwindigkeiten und anströmrichtung am leitwerk des flugzeugs zu messen, wird ein grosser verspannter mast mit zahlreicher messdüsen, scherzhaft "weihnachtbaum" genannt, angebracht. Von den düsen führen rohrleitungen nach dem manometerbrett vorn in bezatzungsraum. Roughly this means: To measure (air)flowspeeds and flowdirection at the tail of the airplane a big mast is attached with numerous measurement equipment, nicknamed "Christmas tree". From the openings pipes lead to the manometerplate in the cockpit. So unless the caption is an effort at wartime deception - that appears to be the answer! I had also though of another possibility, that perhaps it was some sort of equipment for laying smoke. I have seen such equipment on a Stuka and on a P-38. But it appears not. Thank you all for trying with your suggestions. Waldo. P.S. About waveguides. I didn't think that they were waveguides, but did think it possible that they were insulated wiring. The cabling of the period was quite robust. But I guess not. |
The technology of the time would indicate radar for night fighter use. The
signal, radio frequency energy, would have been carried to the radiating units, the small three prong things, by a wire. The wires were enclosed in a metal tube or jacket up to the radiating element. The last part was apparently a rigid copper or steel tube meeting the requirements of the engineering design. The radiator extended from that. The wire was inside the shielding to prevent stray radiation. The row of radiating antenna assemblies would have created a directional signal. There are other things that would have made the signal more directional but drag and weight quickly becomes a large factor, especially in aircraft of that era. Don't think in terms of contemporary electronics. Think in terms of rather large vacuum tubes and antenna systems closer in design and technology to a big TV antenna on the roof. "Waldo" wrote in message ... |
Charlie
Thanks for your post. I am well aware what the physical qualities, tubes etc. that a RADAR of the period had. In fact I have been researching the topic (with an eye toward writing a book on the AI Radars of the war) for a couple of years now doing my best to use original training documents, and "Notes on the use of material", or manuals which were often not produced at all. Anyway I though I may comment on your description of a wave guide. The description I will quote is from a great little obscure book called The Radar Army bt Reg Batt page 44. "The next question was how to transfer this power to an aerial. Coaxial cables of the type and quality then in existence were considered too lossy. The possibility of using a waveguide was considered. This was a whole new untried technique. The waveguide consisted of a hollow metal tube having a critical diameter along which the short radio waves could be propagated. It was decided to try one. We needed several yards of metal tubing of about two inches diameter which for the purpose of the experiment was sufficiently close in terms of wavelength to what was required. At the time we were given to understand that we had acquired house gutter piping (in those days zinc) bought from Edgar's ironmongers' shop in Swanage. But many years later I was to learn from Jimmy Atkinson that it was vent piping belonging to Elsan chemical toilet kits. These were stocked in main stores, Elsans being the necessary form of sanitation at the Worth Matravers site. It was a typical example of the Atkinson flair for procurement, but since a number of kits had to be drawn in order to provide sufficient piping, he was left with a somewhat bizarre problem. The fact that we knew nothing of this at the time was doubtless in order not to offend the sensibilities of those involved with the experiment!" All you need is some plumbing! Waldo. |
| Thread Tools | |
| Display Modes | |
| Anyone know what these guys are testing???? - any information please.jpg (0/1) | Waldo | Aviation Photos | 1 | July 3rd 07 03:30 AM |
| SSA: Good Guys & Bad Guys | [email protected] | Soaring | 1 | October 5th 06 05:11 AM |
| Testing the Testing of Mogas | Jay Honeck | Piloting | 22 | July 24th 06 10:38 PM |
| Guys, guys, guys -- the party is TOMORROW night! | Jay Honeck | Piloting | 3 | July 24th 05 06:26 AM |
| Guys | Dummy | Soaring | 6 | August 31st 04 03:46 AM |
