So do Boeing 787's need wing sand, wax, buff, reprofile, refinish?
Old July 13th 07, 02:37 AM posted to rec.aviation.soaring
Bullwinkle
Default So do Boeing 787's need wing sand, wax, buff, reprofile,refinish?
On 7/12/07 7:12 PM, in article
, "Jack"
I wonder if 747 pilots mumble about "glassholes" when the 787 pilots
walk by.
Depends on how the last merger skewed the seniority list, again.
Jack
Jack,
You left the "r" out of "skewed," and it's spelled with a "c" not a "k."
Bullwinkle
Old July 13th 07, 04:15 AM posted to rec.aviation.soaring
P. Corbett
Default So do Boeing 787's need wing sand, wax, buff, reprofile, refinish?
nimbusgb wrote:
Wander down the airport terminal and mumble 'I'm looking for crew'.
Watch crowds scatter
Surpassed only by the LAK-12 and the Caproni Calif.
Paul
ZZ
Old July 13th 07, 08:26 AM posted to rec.aviation.soaring
Actually, the 787 is built from basically the same material as the
SparrowHawk, so it is not likely to have much problem with that kind
of thing. A little bit different resin in the prepreg and it is laid
out by machine, but the fibers are exactly the same. Not likely to be
many bumps as there are many co-cured parts and the material is very
stable. 6 year old SparrowHawk number 1 is still very smooth.
Painted - gelcoat would turn brown in the oven!
Pretty much all of the other gliders are built with rather old
technology when it comes to resins and tooling. No one who wants
really accurate, repeatable parts does assembly in the molds or uses
wet lay-up. There are good reasons other gliders are built the way
they are. Tooling is very expensive. There has to be the right
number built to pay off the tooling. With the number of
Discus' (Discii?) or LS4's built, it would have probably been cheaper
in prepreg - assuming of course, that you were starting production
sometime since 1995. Typically, it is hard to make that bet in the
world of glider manufacturing.
On Jul 11, 9:55 pm, Stewart Kissel
I am intrigued by the construction of the Dreamliner...carbon
fiber makes it's way to commercial aircraft. This
got me wondering about the construction techniques
of glider wings vs how Boeing does it. Will the 787
have spar bumps after a few years? Are the wings pulled
out of molds? Do they buy gelcoat from the same German
manufacturer as SH or Schleicher? Or are they painted
in poly? Any Boeing types out there with some insights?
Old July 13th 07, 07:50 PM posted to rec.aviation.soaring
Jack[_4_]
PIKs were built in an autoclave, though I'm not sure they were done in
prepreg. My 31-year-old sailplane still doesn't have a spar bump...
unfortunately, the molds were't terribly stable...
Jack
Old July 13th 07, 10:02 PM posted to rec.aviation.soaring
ContestID67
Can you imagine being in a gaggle of these? ;-)
- John
Old July 13th 07, 10:47 PM posted to rec.aviation.soaring
Kloudy via AviationKB.com
- John
I have...frequently.
It's called "Class B"
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200707/1
Old July 17th 07, 04:44 PM posted to rec.aviation.soaring
Bert Willing
Guess you never rigged a Calif...
"P. Corbett " wrote in message
Paul
ZZ
Old July 18th 07, 04:49 AM posted to rec.aviation.soaring
P. Corbett
Paul
ZZ
Bert
Not quite right, Bert. I have assisted in that process many times. It
was almost always a 4-man task.
Paul
ASG-29/ASW-27 wing refinish [email protected] Soaring 23 November 14th 06 11:28 PM
Buff Driver Not BUFDRVR? Ed Rasimus Military Aviation 4 July 22nd 04 01:56 PM
May I suggest a new toy for you, old Buff drivers ? :-) Vicente Vazquez Military Aviation 8 July 11th 04 09:57 PM
Looking for any old BUFF crew Chiefs out there Bill and Susan Maddux Military Aviation 11 February 10th 04 06:52 AM
