For Want of $10 in Parts
Old July 25th 07, 03:44 AM posted to rec.aviation.homebuilt
Kyle Boatright
Default For Want of $10 in Parts
"Kyle Boatright" wrote in message
Saw a fuel stain on the belly of the RV-6 today. After investigating, it
turns out that the carb bowl is loose and I need to replace the gasket
between the bowl and the body of the carb.
The problem is that my local source - Aircraft Spruce, only has the
gasket. They don't have the little bent-tab washers that are required to
safety the bolts holding the carb bowl. With only 3 working days until I
head to Osh, I need some suggestions on a source for those washers.
By the way, I'm near Atlanta.
KB
As it turned out, I ordered the parts from Aviall and installed 'em this
evening. Hopefully the carb bowl will stay nicely attached for a long
time...
KB
Old July 25th 07, 06:02 AM posted to rec.aviation.homebuilt
Ed Sullivan
On Tue, 24 Jul 2007 22:44:38 -0400, "Kyle Boatright"
KB
time...
KB
In order to make sure the bolts didn't turn, I used a nail set to
punch the ears down tight around the bolt head flats. Next time I
intend to use drilled fillister head screws and safety wire.
I was going through the pass between Flagstaff and Kingman and when I
reduced power the engine quit cold. fortunately I was still at 10,000
ft. It would restart and run at full power, but not at a lower
setting, so I had to fly downhill fast to Kingman and land dead
stick... don't want to do that no mo!
PIK 20 D, OR E parts [email protected] Soaring 0 July 8th 07 03:06 AM
109 parts 109 Restoration 0 August 2nd 05 03:14 PM
RV-3 parts Brett Home Built 0 February 20th 04 07:34 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 02:20 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Aviation Marketplace 0 January 10th 04 02:20 AM
