Electric Sonex
Old July 25th 07, 11:22 AM posted to rec.aviation.homebuilt
Vaughn Simon
Default Electric Sonex
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
Fuel requirements for flight in VFR conditions.
(a) No person may begin a flight in an airplane under VFR conditions unless
(considering wind and forecast weather conditions) there is enough fuel to fly
to the first point of intended landing and, assuming normal cruising speed--
(1) During the day, to fly after that for at least 30 minutes; or
(2) At night, to fly after that for at least 45 minutes.
When I was instructing in gliders, it was routine to join the pattern with
(the energy equivalent) of perhaps three minutes of fuel! It always worked.
The difference is knowing precisely how much energy you have available.
The FARs say 30 minutes for airplanes partially because of the inaccuracy of the
average light plane fuel gauge and also because folks actually use their
airplanes to travel from one airport to another. Neither of those factors need
apply to an electric training airplane. First, it would operate from one field.
Second, technology exists to fairly precisely inform the pilot how much energy
remains in the batteries. (add a GPS-informed computer to the mix and you could
always be sure that you had enough energy to return to the field)
Vaughn
Old July 25th 07, 12:38 PM posted to rec.aviation.homebuilt
Dan Nafe
energy
could
[smacks myself on the forehead]
What a great idea!
Old July 25th 07, 10:33 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Dan Nafe" wrote in message
... (add a GPS-informed computer to the mix and you
could
What a great idea!
Yes it is a great idea, but not mine. Such computers have been used on
gliders for years.
Vaughn
Old July 27th 07, 12:30 PM posted to rec.aviation.homebuilt
Dan Nafe
In article
could
What a great idea!
gliders for years.
Vaughn
I'll bet the sailplane systems use the GPS as a pseudo-Air Data
Computer, too. (To account for winds aloft and help avoid landing out)
High-wing Sonex??? Montblack Home Built 9 April 8th 06 03:34 PM
Static thrust for Sonex with 54" prop Mel Home Built 3 November 2nd 05 12:31 AM
Electric DG Robbie S. Owning 0 March 19th 05 03:20 AM
Spicer Sonex/Jabiru [email protected] Home Built 1 January 4th 05 02:39 PM
