#11
![]() The OP's original mechanic is a manipulative weasel who was determined to make a profit off selling a new set of mags... I made the opposite decision on my twin... I remained with Bendix and traded the 4 mags off on a remanufactured set... They are properly timed and the carbs are right and I have a good battery... No Lycoming with magnetos starts better than my pair - hot or cold... If I have a problem at a distant airport, any airplane mechanic worth the name will have the common Bendix parts on hand - and usually some donor mags for the less common parts... With Slick I will be down while they order a new mag and wait for delivery... denny |
Hi Steven,
I once owned a T207 that had Slicks on a TSIO520. During one annual, my mechanic suggested that I upgrade to newer ones, as the ones on there were "very old". I was a new owner and took his suggestion. I don't recall problems prior to this. In any event, I had trusted his judgement. I also had a Mooney M20C with the Lycoming O360 and Bendix mags. I had no mag probems in 400 hours of flying when I owned the plane, and the engine ran beyond its 1800 hour TBO. Current plane is a C310 and have Bendix mags on the IO470s. I've had it for 7 years and the engines just made it to TBO for the second time - they are the original engines. Mag drops are always consistent, the engines are eager to start. I plan on exchanging the Bendix mags for overhauled units of the same type when I have the engines overhauled in 2008. I bought the magneto overhaul kits from Aircraft Spruce and carry them with a few other spare parts in the plane, just in case. That's proven to be good insurance, as I haven't needed to use them yet. The equipment on there is what's worked on the plane and I'm inclined to stick with it. That's my 2 cents worth. Brian |
I think your two cents are worth about a million bucks. Thanks for the info
Brian. I do the same and carry the box of mag parts in the plane. My O320 starts on the first half a prop spin now that the engine and mags are right. This of course is one of the reasons I bought the plane. FlyWithTwo wrote: Hi Steven, I once owned a T207 that had Slicks on a TSIO520. During one annual, my mechanic suggested that I upgrade to newer ones, as the ones on there were "very old". I was a new owner and took his suggestion. I don't recall problems prior to this. In any event, I had trusted his judgement. I also had a Mooney M20C with the Lycoming O360 and Bendix mags. I had no mag probems in 400 hours of flying when I owned the plane, and the engine ran beyond its 1800 hour TBO. Current plane is a C310 and have Bendix mags on the IO470s. I've had it for 7 years and the engines just made it to TBO for the second time - they are the original engines. Mag drops are always consistent, the engines are eager to start. I plan on exchanging the Bendix mags for overhauled units of the same type when I have the engines overhauled in 2008. I bought the magneto overhaul kits from Aircraft Spruce and carry them with a few other spare parts in the plane, just in case. That's proven to be good insurance, as I haven't needed to use them yet. The equipment on there is what's worked on the plane and I'm inclined to stick with it. That's my 2 cents worth. Brian -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200707/1 |
Thanks Denny, thats why I wrote here. I was thinking about calling the FAA
when this ordeal with getting my money back from the first AP. I truely hate when someone tries to run a scam, unfortunately I only look like an idiot I guess. Thats ok, I'll get em. I will remain with my perfect running Bendix. My log books confirm that the mags are not yet ready for overhaul. Denny wrote: The OP's original mechanic is a manipulative weasel who was determined to make a profit off selling a new set of mags... I made the opposite decision on my twin... I remained with Bendix and traded the 4 mags off on a remanufactured set... They are properly timed and the carbs are right and I have a good battery... No Lycoming with magnetos starts better than my pair - hot or cold... If I have a problem at a distant airport, any airplane mechanic worth the name will have the common Bendix parts on hand - and usually some donor mags for the less common parts... With Slick I will be down while they order a new mag and wait for delivery... denny -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200707/1 |
![]() "SteveN wrote My O320 starts on the first half a prop spin now that the engine and mags are right. This of course is one of the reasons I bought the plane. You do realize that it starting easy like that is butter. (smooth) The bread is having it continuing to run without stopping - until you command it to do so ! ! ! VBG -- Jim in NC |
My bread and butter is not going to the first mechanic again.
Morgans wrote: "SteveN wrote My O320 starts on the first half a prop spin now that the engine and mags are right. This of course is one of the reasons I bought the plane. You do realize that it starting easy like that is butter. (smooth) The bread is having it continuing to run without stopping - until you command it to do so ! ! ! VBG -- Message posted via http://www.aviationkb.com |
A coworker of mine........... | Mark and Kim Smith | Military Aviation | 13 | June 25th 14 06:57 PM |
I'll have mine well done pic32050.jpg [1/4] | Andrew-S | Aviation Photos | 0 | June 1st 07 04:56 AM |
Lyc O-235 How much room needed between mags and firewall to remove mags | DonMorrisey | Home Built | 5 | October 29th 06 04:01 AM |
VW1834 and Slick 4001 Mags | M J Veary | Home Built | 4 | March 4th 05 11:23 PM |
FA: Slick Mags (used) 600 series with harness | BFC | Aviation Marketplace | 0 | June 24th 04 04:21 PM |
