#11
On Jul 28, 12:24 am, "Matt Johnson" wrote:
I recently took my commercial ASEL ride and must retake a few parts of the practical portion, but the complex single I've been using is no longer available to me. A CFI friend suggested that I could start my multiengine training now, then take a combined ASEL/AMEL commercial ride, whereby the complex requirement would be satisfied by the twin, and I could do the areas I need to retake in a non-complex single. Is this permissible? Once you have the commercial multi, you don't need a complex airplane at all for the commercial single. I did mine in a TriPacer. So there would be no need for a combined ride. You could take the commercial single in a non-complex airplane at any time after passing the commercial multi. This is assuming it was in a complex multiengine airplane - but I can only think of a few of those, and only the Partenavia would be reasonable. The Lancer is disallowed, the Cessna 336 gets you a rating limited to centerline thrust, and the Islander and Twin Otter are way too expensive. The problem is that you have already taken the commercial single test in a complex and failed it. Now there is a judgment call involved. There is no rule that says that you can't continue the test in a non- complex, but you ought to check with the DE and make sure he is OK with it. If not, choose a different DE. Michael |
On Jul 28, 3:17 pm, Mark Hansen wrote:
On 07/28/07 10:26, Luke Skywalker wrote: On Jul 28, 12:24 am, "Matt Johnson" wrote: I recently took my commercial ASEL ride and must retake a few parts of the practical portion, but the complex single I've been using is no longer available to me. A CFI friend suggested that I could start my multiengine training now, then take a combined ASEL/AMEL commercial ride, whereby the complex requirement would be satisfied by the twin, and I could do the areas I need to retake in a non-complex single. Is this permissible? -- Matt Yes...be careful with the dates (ie how long from the test to the retest) but the ME would easily satisfy the complex aircraft part of it. Well ... so long as the multi-engine airplane is a "complex". Not all of them are. -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA My Champion Lancer is about 90 percent done! That one wont work, but a friends restored Apache will! take care Robert |
On Jul 28, 3:49 pm, Michael wrote:
The problem is that you have already taken the commercial single test in a complex and failed it. Now there is a judgment call involved. There is no rule that says that you can't continue the test in a non- complex, but you ought to check with the DE and make sure he is OK with it. If not, choose a different DE. Michael what I would asked if I were the CFII/MEI or the DE is "what manuevers were failed". If there was a failure related to the complex airplane then that would be one thing, if it were one of the manueers...then that would be another. It has been so long since I took mine but as I recall the FAA examiner (that long) had no real problems with it. She spent the vast majority of the Multi part of the ride on single engine ops including shooting an "approach" of sorts in a psuedo engine out condition. Robert |
Yet another PP-ASEL privileges question | Yossarian | Piloting | 1 | September 21st 05 07:28 PM |
Glider cross-country time toward commercial SEL requrements? | Matt Michael | Soaring | 17 | November 25th 04 04:45 PM |
Glider to ASEL Conversion | solo89 | Piloting | 7 | July 10th 04 02:23 AM |
Amel;ia Aerhart | Bruce Wodetzki | Piloting | 5 | April 23rd 04 03:05 AM |
Part 91 Commercial Glider Rides to be Outlawed? | Vaughn | Soaring | 9 | October 27th 03 09:26 PM |
